Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Hi my Sony kp51ws510 is stop no picture no sound it look like something to do with power supply problem can someone tell me what to do thank you
  • Sony Master
  • 5,138 Answers
FBT flyback Transfomer, CK Hori output Transistor and small blue Capacitor that Feed to Hori Transistor,Cap is 2Kv
Acme Has good Deals on FBT 1-800-575-9833
Posted on Oct 05, 2010
Rca model 132wd22 no picture and no sound
Hi Carl
Good... nice to see someone knows about Caps.
If Switch Mode Power Supply is working OK
Then it can only be bad Connectors orMotherboard failure.
Warranty???
Feb 18, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a 60" Sony
It seems lamp/ bulb popped again, check lamp inside tv.
If tv does not show red blinking light then it would be lamp that knocked off, replace lamp in tv to fix its problem, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Jan 15, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
The picture will be okay one minute and then it will go green off and on
It seems green picture tube in this Sony KP51WS510 rear projection became defective and causing this problem. Replacement of green picture tube will fix this issue but it would be costly fix and professional will do it as it requires lots of adjustments after tube replacement.
Please check with local vt repair shop and ask an estimate of repair.
Thanks.
Nov 15, 2010 | Sony KP-51WS510 51" Rear Projection...
HI I have a 1998 Sony Videoscope XBR 53 in. Projection TV. When you turn it on the sound is fine but sometimes the picture comes right on and sometimes it can take hours. Can anyone give me some advice....
hello well it's and old tv, my guess it could be capacitors in the power supply or even dry joints on the power supply board, it would be best to have someone with electronic experience to have a look at it
regards
shaun
Oct 06, 2010 | Sony KP-53S65 53" Rear Projection...
Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Dec 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kv-32fx68k............Hi, I wonder if someone can help me. The stand-by light is flashing in groups of 8 flashes. On start-up the sound comes on for less then a second and then all is silent. There is...
The main supply power board is blocated.Chek the power tranzistor in this parts.Cut the power alimwntation circuit to the horizontal drive section and across on 40W bulb in the circuit.If it work The problem in the HD circuit,change the power tranzistor(BU 508).
Aug 27, 2009 | Sony Televison & Video
Sony-kp51ws510 picture turns to a blue hue with flickering colors
hello there this is an easy fix unplug the tv and take the back of the set, once inside the set you will see 3 coloured bulbs and a big mirror in the back theses over time get dusty and dirty and if you smoke it can get really bad you simply just need to clean the bulbs and the mirror with computer screen wipes or some sort of window cleaner be sure not to get everything wet inside this should sort if for you nice and clear again!
Thanks For Using FixYa
Feb 07, 2009 | Sony KP-51WS510 51" Rear Projection...
Best picture and sound
connect coaxial cable connector from your cable service company to cable box-----in jack.
2-using coaxial cable connect cable box out to tv-vhf/uhf jack.
connect projection tv audio out (var-fix)jacks to avr 230 line in.
Aug 22, 2008 | Audio Players & Recorders
Kp51ws510
Did the set have convergence problems before picture left? If so then you can unplug the conver. Bd and see if set comes up then this will tell you where the problems lies. Or you can check IC902, Q800-810 D655
Dec 05, 2007 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
77 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
