Question about Monitor Audio Radius R360 Subwoofer
My Monitor R360 is not working. I have inspected all the Monster cables to my speaker system; they seem fine. Could be a blown fuse, but I am hesitant to open up the subwoofer due to the warnings on the back panel. I live in Northern Virginia (Sterling) and I would like to know where I could find someone to work on the subwoofer.
3 Suggested Answers
landsend
  • 1066 Answers
SOURCE: subwoofer stopped working
You have a bad connection to the subwoofer.
Posted on Mar 08, 2009
ErusTownsend
  • 592 Answers
SOURCE: The subwoofer is only putting out about 10% of it's capacity
if the speaker is actually receiving signal and has sound, the next question is if the sub is self amplified or not. if it is check the amp in it. if not then check your unit to make sure the bass is not turned down and that the correct surround setting are there. there is also possibility that the show or item your listening too isn't outputting correct channels.
Posted on Mar 29, 2010
Radio and cd player works but there is no sound coming out? all factory.
one of you speakers may be blown......in alot of the newer models the factories have added a safety feature which dont allow the other speakers to work if one of the speakers are blown.....remove them one by one and wire them to a little stereo system and see what happens....good luck!!!
Apr 16, 2014 | 2006 Chrysler Pacifica Touring
Loud buzzing when turn on, no input signal
put a song onto play using either tape, vinyl, cd or mp3.
once playing follow the wires from the speaker that doesn't work bending it until you hear it crack or become clear if it does either of those it is the wire between the head unit and the output.
if not you can try attaching the speakers to a different head unit if it doenst work it could be the driver (the cone doesn't have to go to blow a speaker)
Jan 02, 2014 | Mackie MR5-MK2 5" Powered 2 Way Reference...
Main Speaker Not Working
IS there a circuit board inside that speaker? You are correct about the general loss of sound quality that usually occurs with speaker failure. Best way to check is with a meter or a scope
May 04, 2013 | Mackie SRM-450 System
Our View Sonic VG810 LCD Monitor just stopped working. No green indicator light, changed out both the cable and the AC wire, no change. Plugged in another monitor using the same cable/wire and that monitor...
Probably failed caps in the power supply/inverter boards.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 15, 2010 | ViewSonic VG810 (Black) 18.1" LCD Monitor
Help! My acer ferrari 20 inch monitor has worked perfectly for the year and a half I have owned it. Yesterday the screen just went blank.. no warning. I have checked all the cables and even plugged an old...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jul 01, 2010 | Acer Ferrari F-20 20" LCD Monitor
I now have several Hanns G 174A monitors that have gone dark, power light on, and a quiet, but distinct "clicking" sound from the monitor about every second or so. Any ideas? (no video source plugged in,...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Jun 09, 2010 | Hannspree HW191D LCD Monitor
Mar 29, 2010 | Monitor Audio Radius R360 Subwoofer
Sub works then turns off
You're dancing around the clues. The position of the monster cable seems to affect it. What shuts off - the receiver (need to know make/model) or the sub? Just connect the cable deep enough to make contact with the metal parts you can see of the clips and/or binding posts. Don't let any conductor touch more than one metal surface. Now what?
How is it attached - RCA cables or speaker output from the receiver? Need specific info to make a good diagnosis.
The time factor is curious. Again, what's turning off? The receiver? There should be no reason for it to overload since it just supplies either Line Level to the sub amp's Low Pass Input or speaker level to the sub's Speaker In terminals. Are you slaving your Front Speakers out the back of the sub or are they on the receiver? Experiment with them disconnected.
May 21, 2009 | JBL PSW-D110 Speaker
Subwoofer stopped working
Mar 07, 2009 | Monitor Audio Radius R360 Subwoofer
Stereo display works fine, but no sound to speakers.
The wires may have gotten wet and fried something in the sound output in the stereo.
Jun 16, 2008 | Pioneer DEH-1900MP CD Player
Monitor Audio Radius R360 Subwoofer Logo
76 people viewed this question
Top Monitor Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Monitor Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
