Question about Garden
I have a blower/vac pro24ccbva without manual. I need to know fuel mix instructions. and bag fixing details
Noggin
  • 944 Answers
SOURCE: Need to change bag
here's the link to the instruction manual; http://sanyoservice.com/pdf/images/SC-180E.PDF (it is for the sc-150 and sc-180) Check page 8 for details. Hope this helps :)
Posted on Aug 01, 2007
  • 132 Answers
SOURCE: Replacement bag for Ryobi blower/vac
http://www.ryobi.com.au/ within this web site if you look under service outlets gives you the stores that are closest to you that sell ryobi equipment i looked and found dubbo mowers and chainsaws ph 68823122 they might be able to find one for you hopefully bestaluck glenn
Posted on Nov 15, 2008
SOURCE: replacement bag for sovereign blower vac
Balmers Garden Machinery. Burnley Lancs.
Tel 01282 453900.
Have these bags available,
Posted on Dec 11, 2008
  • 83 Answers
SOURCE: Need 3.5 HP Craftsman vacuum-shredder-bagger-blower manual
Without seeing it I don't know but it should show you in the manual. You can order it from Sears.
They have a great online parts site.
Here is the link
SearsPartsDirect.com
Posted on Mar 30, 2009
  • 272 Answers
SOURCE: Ryobi RY08576 25.4cc was started without mixed fuel
If the engine is sticky ie harder to pull it might have to be pulled apart new piston and honing of cylinder. not difficult just a pain. If it doesn't seem any harder to pull, Drain all of the unmixed fuel. Put a few drops of 2cylinder oil in the spark plug hole and pull the starter a few times with the plug out of it. Put a few more drops in repeat. Replace the plug (new plug) Put in mixed fuel prime the system cross your fingers and it should start up for you.
Posted on May 12, 2009
I want to know if my weed eater sb180bv blower/vac is 2cycle or 4cycle
Most weed eater products are two cycle. if you have to mix oil with the gas they are two cycle. If there is no place to add the oil like a four cycle then its two cycle. Do not run a two cycle engine without adding oil to the gas or you will burn it out fast
Jun 29, 2016 | Weedeater Garden
Need to change bag
Jul 31, 2007 | Sanyo Transmax SC-150 Bagged Upright...
What is fuel mixture on a 25cc craftsman weedwacker
I always mix it 40:1 so that the piston will always be lubricated and after I finish cutting I empty the gas tank and then restart machine so as to keep the fuel filter clean.
David
Sep 21, 2014 | Poulan Pro BVM200VS 25 cc Gas Powered...
Just cleaned out my father's garage and came up with a Toro 524 snowblower this unit has not been running for over 6 years what should i do to get it up and running? can't find an owner manual online...
You need to clean the carb, make sure fuel lines are not cracked and brittle (replace if necessary) , clean fuel tank thoroughly, especially if there was still fuel in tank. Check for spark, mix a new batch of fuel (if mix is required) and start that mother it will probably run as good as new. Good Luck...
Nov 07, 2010 | Toro Blowers Rake and Vac - Electric...
I have a Craftsman electric Blower/Vac with no operatorers/instruction manual. I would have liked to use the vac option but have no idea how to couple the pipes together and attach the bag for this...
For maybe getting a manual, go to:
http://www.manualsonline.com/
You will find that you open the bottom vent, put a large suction tube in the recess and remove the blower tube and attatch a collection bag on the housing that held the blower tube. That's all there is to it.
Aug 13, 2010 | Craftsman 4 Cycle Blower/Vac
This product is my elderly fathers and he has lost the instructions of how to use and what mix of petrol to use. would it be possible to email a copy of the manual/instruction leaflet thankyou...
Mix your fuel in a 1 gallon gas can. you can buy a predetermined little bottle of oil for your fathers leaf blower anywhere with a lawn and garden department. use 40:1 2 stroke oil.
Aug 04, 2010 | Garden
Wht is the gas to oil ratio for a homelite vac
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
1 quart fuel:3/4 ounces of oil = 1 Gallon fuel:3 ounces of oil or slightly less than 43:1. Not what a current manual recommends.
If properly adjusted your blower will operate fine on 50:1 regardless of what the manual reads. HTH
Lou
Jan 31, 2010 | Homelite Leaf Vac Attack
Need to know gas mixture
GasolineLubricant
If properly adjusted your blower will operate fine on 50:1 regardles of what the manual reads. HTH
Lou
Jan 29, 2010 | Homelite Consumer Products Backpack...
I bought a Toro ultra electric blower vac (model 51599 a year ago but never used it. Now that I need to use it I can't find what I did with the instructions. What do I have to do to attach the vacuum bag?
Common sense tells me it is not that hard you probably do not need an instruction manual, does life come with a instruction manual O Yeah the Bible. Believe in yourself review the situation, think it over you can do it!!!!!!!!!
Nov 25, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
Craftsman 4 cycle leaf blower/vac #71-79731
Solution offered by MrFixIt Jerr solved my problem. Thanks for the help. This is a great service. Mr. G.
Feb 08, 2009 | Craftsman 4 Cycle Blower/Vac
Garden Logo
368 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
