Question about Zanussi Washing Machines
How do you remove back panel on zanussi fls-1183w so i can replace belt
You only need to remove the top of the machine but be carefull when fitting new belt
Posted on Oct 05, 2010
Zanussi fls 1284 - how is it possible to make the right belt fit - I have tried and tried - it will not fit. What can I do?
It is elastic drive belt 1196 J5 which means that 1196 mm is the working length based on the belt mounted on the pulleys. "J" and "H" means shape of the drive belt and finally number after word (J5) means number of teeth (could be: 4,5,6,8) .The length marked on the drive belt (1196,1217,1280 etc.) is the working length based on the belt mounted on the pulleys. For a given working length, the belts - which consist of different materials - have a different degree of elasticity. This means that, when not fitted to the appliance, their lengths may be different. It is normal that the length of a plastic belt not fitted to the pulleys is three or four centimeters greater than that of a rubber belt. Also, both types of elastic drive belt are shorter than the working length and therefore it is a little more difficult to replace but not so much that you have to lossen motor.
Please follow this link:
https://www.youtube.com/watch?v=yC21q2-eAfI
Dado
Sep 13, 2015 | Zanussi Washing Machines
Washing Machine leak underneath the machine - Zanussi FLS-579C
have checked the door seal
send the 91------------- no this is on a label in the door
Feb 05, 2014 | Zanussi Washing Machines
My Zanussi fls 1183 is not washing the clothes, they are not completely wet and are not clean
This usually means that the drum is not rotating during wash or spin.
If this is the case the most common causes are a broken drive belt or the motor brushes worn out
Always remove the plug before investigating
Jan 22, 2011 | Zanussi Washing Machines
Zanussi aquatic FLS 674 C manual
I need zanussi aquatic FLS 674 C manual and I want to know the number of its belt. thank you
Dec 29, 2009 | Zanussi Washing Machines
I think the bearings have gone on my zanussi aquacycle fls 1183w. can i do this myself, or do i need a new machine.
I have just done this myself and to be honest it was quite easy.
you will need bearings l replaced both front and rear as the cost of each was nothing, a new bearing seal and a drum gasket as the drum has to come apart.
Tools are a digital camera ,socket set, torx key set, set of spanners a cold chisel and a hammer. And you need the old bearings to put the new ones in
Jun 06, 2009 | Zanussi ZWF1420W Front Load Washer
My door handle on my zanussi fls 1183w washing machine has broken and ive bought a new handle but dont know how to get old one out can you help please
normally on zanussi doors they have 5 or 6 screws around the edge on the inside of the door if you try to undo them and take apart the door the handle should come out be carefull not to drop the glass
Nov 11, 2008 | Zanussi Washing Machines
I have FLS 1183W Zanussi washing machine. The drum no longer rotates and does not spin. Rgds
check motor brushes for continuity (you will need a multi-meter for that) or instead, take the brushes out and examine them. this is the usual cause
Jun 21, 2008 | Zanussi Washing Machines
Door
it probabbly broke somewhere.
if it is possible to take the handle out, I would investigate the problem further.
not worth fixing the handle, you may have to get a replacement.
Mar 16, 2008 | Washing Machines
Washing Machines Logo
135 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
