Question about Ricoh - 2020SPF DIGITAL COPY/PRINT/SCAN/FAX Copier
Error sc544 ricoh aficio - Ricoh - 2020SPF DIGITAL COPY/PRINT/SCAN/FAX Copier
  • Ricoh Master
  • 525 Answers
Fusing overheat error (center) 2
Symptom:
The fusing temperature is over 250°C
for 1 second (detected by the fusing
temperature monitor circuit).
Possible Cause:
• Fusing thermistor defective
• Power supply board defective
Posted on Jan 22, 2011
Error sc544
sc544 refers to heating unit failure to heat, could be bad heat lamp, blown thermostat , very dirty thermistor.
Feb 13, 2014 | Ricoh Aficio 3232c 3214c 1232c 1224c Oil...
Gestetner 3225 error code SC544 - functional problem
SC544 indicates low fuser temperature during the warm up process. This means you have a problem with the fusing unit heating up. The fusing unit is located right where the paper exits the machine. Most common failure on these Ricoh's (Your Gestetner 3225 is made by Ricoh model aficio 250) is the fuser thermistor. This is a small electronic part that measures the temperature of the fusing roller. When they go bad they do not "see" the heat and therefor the code pops up. You are going to need to have a tech look at this for you as you will need to determine for sure which part is bad then you have to go into the service mode to reset this SC code before the machine will run.
Good Luck and Thank You for using Fixya.
Sep 07, 2010 | Gestetner Copier
Have an aficio 1018 copier with an error code SC544 any ideas ?
that's a fuser unit error do an Sc reset and restart the machine if not replace the fuser unit
May 19, 2010 | Ricoh Aficio 1018 Printer
Ricoh 1022 service sc544 i need to reset can anyone help
This is a code for the fuser, which indicates a very serious overheating condition. Your machine has something _seriously_ wrong with it, and should be looked at by a service technician.
SC544 - Fusing overheat error 2
A fusing temperature of over 251°C is detected by the fusing temperature monitor circuit in the SBCU board.
Potential Causes:
• SBCU board defective
Oct 29, 2009 | Ricoh Aficio 1022 All-In-One Laser Printer
Error code SC 544
Relates to fuser unit. Needs to be reset from service mode.
Mar 21, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh - 2020SPF DIGITAL COPY/PRINT/SCAN/FAX Copier Logo
944 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
