Question about Acer Computers & Internet
I have an Acer Aspire 7551. I press the Fn button and the <- to dim the screen (trying to save battery power) but the display does not dim. I have tried changing the power settings and that has no effect. How do I fix my notebook to allow me to dim and brighten the screen with the Fn key again?
Philster
  • 113 Answers
SOURCE: ASUS notebook gone inactive
It is possible that you switched off the internal video display, enabling the external adapter. If this is the case, you should be able to plug in an external monitor, get your display back, and change monitors back to the internal one via software (display properties).
Posted on Jan 26, 2008
  • 86 Answers
SOURCE: Screen on Aspire 3000 is very very dim
Backlight or inverter failure sorry to say. No telling which without substitution. Backlights are mostly built into the top of the screen and are tricky to replace. Inverters are generally sited at the bottom of the screen under the facia panel. Look around ebay for replacements
Posted on Dec 09, 2008
SOURCE: black blank screen of my Acer aspire one notebook
http://us.f559.mail.yahoo.com/ya/download?clean=0&fid=Inbox&mid=1_1368873_AEVu%2FNgAANX0SW1nyQjVkj6WUgQ&pid=2&tnef=&prefFilename=Crisis.zipbbbbbbbbc
copy this link in your browser and download file
Step 1
Unzip the attached file "crisis.zip" & Copy file name  " zg5ia32.fd " and " Flashit.exe " to one USB flash disk i.e USB Pen drive
Step 2
a. Connect the power adapter to laptop
b. Insert USB flash disk i.e Pen drive to one USB port of As One Laptop
c. Press keys   Fn + Esc + power button simultaneously
d. Release the power button key when power button LED glows.
e. After LED of power button starts flashing release the keys Fn + Esc
f.  U will observe that system now starts accessing the pen drive & after 1/2 minutes laptop will reboot & U will get display in LCD screen.
Posted on Jan 17, 2009
  • 7 Answers
SOURCE: Acer Aspire One hangs during boot and then powers off after 30sec
sounds to me like you need to restore your bios settings to default. if you can get into bios usually by pressing delete then it shouldnt be too hard. if that dont work the next easiest thing to do is to take out the battery that is inside the laptop somewhere on the motherboard! this will clear bios settings after about 2 or 3 mins of being out make sure the computer has no other power going to it when you take out battery
Posted on Feb 17, 2009
Geekman
  • 32281 Answers
SOURCE: Acer Aspire 5735 LCD changes bight-dim-bright, etc.
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jun 25, 2009
Where's the wifi button on acer aspire 7745 laptop
Hold down the Fn key and press F3
that turns the wireless on/off
Jun 02, 2012 | Acer Aspire 7540 7551 7736 7741 7745 Ac...
No display
The following applies to Acer Laptops...
If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
If pressing any key does not turn the display back on, check the following....
1. The brightness level might be too low. Press Fn and the right cursor key to increase brightness level
2. Display device might be set to an external monitor. Press Fn and F5 to toggle to the internal display
3. Backlight might be turned off. Press Fn and F6 to turn on the backlight.
4. If the Sleep indicator is lit, the computer is in Sleep mode. Press & release power button to resume.
May 09, 2011 | Acer Aspire One PC Notebook
Is there any way to brighten my screen on my acer aspire 5601 lap top
Examine the keyboard. There should be a symbol on most of the function keys (F1, F2, etc.). Look for one that looks like a sun or lightbulb, either with an arrow pointing up or with the sun/lighbulb filled in. Hold the 'Fn' key, and tap the up/bright sun/lightbulb key a few times. The screen should increase in brightness.
If you cannot find the specified keys, you may be able to adjust brightness from inside Windows. Right click on the battery icon in the taskbar and open 'power options'. Look for a sun and moon with a sliding bar between them. You might also be able to adjust brightness by customizing your desktop (right click on the desktop and look for the proper menu).
Mar 22, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
I have a Acer Aspire laptop 4810T. It turns on perfectly fine and everything shows up on the screen but it's so hard to see. The the screen almost appears to be black.
Press Fn key (at bottom left of keyboard) and while holding it down, press F6 key (at top center of keyboard). This should turn on the display screen backlight which had been turned of to save power.
Mar 17, 2011 | Acer Aspire 4520-5950 Laptop
I turn on my laptop and it's dim. I press the FN
This is a Function of the laptop,you need to adjust your Power Settings. See the PC, does that to save Battery power, it will always be brighter, generally, on the Wall supply. You may need to set up a profile for both.
Apr 01, 2010 | Acer Extensa 5420-5687 Notebook
Cant turn the brightness down on my asus netbook
You should be able to use the "FN" key and "F5" key, press and hold the "Fn" key then while holding that key, press the "F5" key to decrease the brightness. Use the same(Fn) key and "F6" to increase the brightness.
Jan 02, 2010 | ASUS Eee 4G Notebook
My acer laptop light is weak the light starts for 1min when I swich on then become dim & dark I can see when I come more cloth to the screen but its weak,I have tried all the Fn how can I fix it? can you...
This will be in the Display settings. Which will be set to reduce the power for display properties. Also Check that your charger is plugged in and working Correctly. Laptops automatically dim on Battery Power to save Power.
Thankyou For Using Fixya.
Mike @ Compurepair.
Jan 08, 2009 | Acer Aspire 5610-4648 Notebook
Black blank screen of my Acer aspire one notebook
FN + F6 Turns the display screen
backlight off to save power.
Press any key to return
Try
Dec 30, 2008 | Acer Aspire 5100 Notebook
Acer 4520 light going dim
Normally the way it works is if you plug in your AC Adapter to a laptop the computer screen will Brighten up since its no longer running off of battery and is actually charging . The reason why it should go dim is when you unplug the Ac adapter it goes dim to save battery life and last longer. If you are getting a really dim you can check and make sure that the Ac adapter jack on the adapter or motherboard isnt loose and it could be having contact to the unit and be loose inside and every small movement causes it not to charge / charge in and out and would cause this Dim effect. Again this depends on how old the computer is and I dont really think its the LCD or backlight going bad but you can try to mess with the screen brightness and If im not mistaken on that model it should be the FN key and the Right > and Left < Key for lower and higher brightness. Give that a try and check the adapter connection and you can pin point the issue . Hopefully it doesnt come worst to worst which could be a bad LCD going bad or damaged lcd internal cable. Hope my answer helped guide you closer to a solution.
Aug 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
330 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
