Question about Refrigerators
Hi, My problem is with an Electrolux ER7926/1B fridge freezer. The fridge part is not cold but the freezer is working fine. The tempertaure adjustment for the fridge makes no difference when moved. There is no air coming from the duct but the fridge is making all the normal noises. We are currently defrosting it as someone on another site suggested the duct could be blocked with ice. If this is not the resolution what could the problem be caused by. Chris
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
  • 378 Answers
SOURCE: fridge is not cold and freezer is not cold
the vents might have glogged by some thing or maybe there is some airleaking from the doors and preventing the freezer to reach the necessary freezing temprature.check out.
Posted on Jan 10, 2009
appldoctom
  • 311 Answers
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Posted on Jan 30, 2009
  • 219 Answers
SOURCE: Fridge on Zanussi ZX56SI has stopped working but freezer fine
check in your frezzer on the back wall if its all frosted up u have a defrost problem u can unplug and let thaw fgor 4 or 5 hrs plug back in and wilkl work till u can have it serviced if no frost u might a bad fan or a damper control
Posted on Mar 19, 2009
mgprice
  • 744 Answers
SOURCE: fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Posted on Jun 23, 2009
FRIDGE TEMPERATURE IS TOO HOT FAULT
There is a conduit from the freezer that feeds cold air into the refrigerator compartment. Make sure that the conduit is not blocked in the freezer area nor the refrigerator area. You should also have a control inside the refrigerator that regulates a sort of trap door inside the conduit. Make sure it is open or increase the opening by moving it to a higher number. Do not confuse that control with the thermostat.
Apr 01, 2014 | Fisher and Paykel Refrigerators
Electrolux Inspire ENB35405W fridge freezer faulty
Empty it and defrost it completely (24 hours with door open) restart it and check the fridge has cold air again. check the defrost setting on the controller. Also check the drain pan on the back of the unit as it may be overflowing or have a crack in it. Is it still under warranty?
May 01, 2017 | Electrolux Refrigerators
Model# FRT045GM Freezer ice cold fridge warm?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 09, 2011 | Electrolux Refrigerators
Fridge freezer works but fridge element back of fridge does not defrost completely leaving lump of ice
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 16, 2011 | Electrolux Freezers
The Fridge on Electrolux fridge freezer is not working, not cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Nov 02, 2010 | Electrolux ER7926B Bottom Freezer...
Freezer working fridge not cooling?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 29, 2010 | Electrolux E23CS75DSS Stainless Steel
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
My fridge freezer comprises of the top one being the fridge and bottom is the freezer. its Zanussi by Electrolux . problem is the fridge is not functioning and its warm (its not cold at all) but freezer is...
It sounds like the fan in your freezer is not working so it can't get the cold air to the frig or your coils are not defrosting and it is stopped u and cant blow air into te frig, One way to check if you hear the fan and know that it is working open the frig and put your hand up near the vent to see if you can fill cold air if you can't now open the freezer door if you can feel the cold air or more air r coils then you could before then your coils are stoped up the unit is not defrosting.
Apr 03, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
