Question about Nokia N70 Cellular Phone
My usb connector malfunctioning - Nokia N70 Cellular Phone
    Guru:
  • 166 Answers
Instructions
  1. 1
    Turn off your computer.
  2. 2
    Unplug the power supply, remove your laptop batter, and wait at least 30 minutes before returning the battery and power chord to the laptop. As explained by Trouble Fixers, a cache of data from your USB device is stored on the motherboard. This cache is not completely erased until the motherboard fully discharges following power-down. Once the cache is cleared, most USB errors will be fixed.
  3. 3
    Turn on your laptop computer.
  4. 4
    Try to use the malfunctioning USB port. In most cases, simply turning off and unplugging the laptop will help remedy the problem. If a problem persists, continue with Step 5.
  5. 5
    Click on the "Start Menu."
  6. 6
    Click to open the "Control Panel."
  7. 7
    Click on "System and Maintenance."
  8. 8
    Click on the "Device Manager." A new window will open that lists all hardware and external devices currently installed on your laptop computer.
  9. 9
    Scroll the list until you notice the heading "USB Root Hub." Click on this option.
  10. 10
    Select the USB port that reads "Unknown Device." All other, functioning USB ports should say "unused port" or list a specific external USB device.
  11. 11
    Right-click on the Unknown Device port and then select "Update Driver." According to the tech-help website, Amit Bhawani, this will trigger an automatic update of the USB drivers. If no new drivers are found, the old driver will also refresh and repair. In many cases, a malfunctioning port is simply caused by outdated driver software. With the latest drivers, your port can be used with current USB devices without any problems. If problems do reoccur, then the port may be physically damaged and you'll need to take the laptop computer to a computer repair technician to get a new USB port installed.
dont forget to leave a comment and state how helpful this post is to you
Posted on Oct 05, 2010
USB device not compatible but nothing in port
Either's there's dust causing a shortcircuit in the mainboard or the front connectors, or one of your usb devices is malfunctioning(the mouse, webcam, printer, usbstick etc )
Nov 08, 2011 | HP Photosmart Premium C309A All-In-One...
Reset my Dell 926 all in one printer
The Dell 926 printer is an All-In-One model that you can use as a printer, scanner and a fax machine. When the printer becomes unresponsive there may be a communication problem between the printer and your computer. To correct this type of problem you need to first verify that the USB connector cable is not malfunctioning. You can do this by resetting the communication settings between the computer and the printer.
y1 Press the "Power" button to turn off the printer. Unplug the power cord from the electrical outlet or the power strip.
    • 2
      Disconnect the USB connector cable for the printer from the computer.
    • 3
      Turn off your computer from the Windows "Start" menu or by pressing the "Power" button.
    • 4
      Plug the USB connector cable back into a USB port on the computer.
    • 5
      Plug the power cord for the printer back into power strip or electrical outlet.
    • 6
      Press the "Power" button to turn on the printer. Press the "Power" button to turn on your computer.
Oct 22, 2011 | Dell Photo 926 All-in-One Printer
When i plug the player into my computer it says it does not recognize the compotent or it has malfunctioned?? I looked online and can't find anything to help me with this problem..
this kind of problem usually occurs when a faulty USB cord is use to connect to the PC replacing the USB cord will solve the problem
in some cases this problem happens when a poor contact of the USB connector from the input terminal of the USB device.You can clean the contacts by removing dust and corrosion from the terminal...
Dec 24, 2010 | Polaroid Audio Players & Recorders
My computer can not read data card. os is vista...can u plz helpme in this regard?
Three things can be at fault here:
1 the card itself might be dead - test it in another pc with another card reader.
2 the card reader might be malfunctioning - test it by using another card, a different type of card(if it has that capability) and in a different USB (if it's removable)
3 USB connectors are faulty - check them by connecting some other USB device.
Replace the faulty part.
Mar 23, 2010 | Computers & Internet
My pc is showing that the usb cable connected to the printer has malfunctioned or has not been recognised
Simplest thing to try is another USB cable. Still not working, then problem could be in the USB connector on printer.
Possible it could be a conflict with another connected USB device. Try unplugging all USB devices and wait for the PC to drop those connections. You can see these in the Device Manager. Then plug in just the printer.
Oct 22, 2009 | Office Equipment & Supplies
Wd portable hd - device attached to this system is malfunctioned
It could be that the Hard Drive inside the enclosure still works, not sure if you care about voiding any warranty as opening it up will likely do, but there is a very slight chance that the Hard Drive itself will let you get the data off it. I am not sure what the connector to the drive is on the inside though as I have not taken one apart myself, :).
Sep 09, 2009 | Western Digital WD Passport 250GB Portable...
Usb not recognised
the connector of you usb port of your unit kinston is need to re_soldering by using a soldering iron.or need to re-heat by hot-air unit.
kira_ryuk@yahoo.com
Jan 11, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
SanDisk 2.0GB will not open- computer says "USB connector has malfunctioned"
check on other computer if it says same then check virus, otherwise ur computer's usb port gone bad
Oct 21, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
USB to Ps2 keyboard adapter
i think your usb to ps2 connector is faulty.
change it and try again
Apr 01, 2008 | Computers & Internet
Nokia N70 Cellular Phone Logo
198 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
