Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Dishes come out with white soapy residue and glasses in top rack are very cloudy. I don't think the center spray arm is turning.
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Posted on Oct 06, 2010
We have a built in GE dishwasher. It has worked fine for about 4 years but now the glasses in the top rack will not come clean. I have cleaned all the holes where the water comes out but I think the...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Dec 13, 2010 | Maytag Dishwasher
Help! Same white residue and even pro can't figure it out!
It sounds like a washability problem. A couple of things to check.
See if the bottom and top spray arms are free turning. Then look closely at the holes to make sure they are not plugged with anything.
The rest of this applies if you have mode KUDG25SH, if you have a different model number on the tag inside the door let me know and ignore the rest here.
You may have a split in the upper spray arm feed tube. If you slide the upper rack out and look under it you will see the spray arm(propeller looking) under and behind there is a vinyl tube also attached to the rack, look that tube over good, if it is broken or cracked you are loosing water pressure that does the washing.
Let me know what you find and I can help more if needed
Phil
May 01, 2010 | KitchenAid 24 in. KUDG25SH Built-in...
Dishes, glasses on the top rack dont get cleaned. The bottom rack is fine. What may be the problem?
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Jan 25, 2010 | KitchenAid 24 in. KUDS25 Built-in...
Residue and small particles left in upper rack dishes and glasses. maytag mbh940aww dishwasher.Is there a filter to clean?
Yes there will also be a filter in the base of the unit to clean. This needs to be done regularly to avoid food getting into the working parts of the unit.
Jan 24, 2010 | Maytag Dishwashers
The dishwasher doesn't clean properly
Lots of possibilities...
1. the sprayer arm might be sticking and not moving, or moving very little. Check to see if you can spin it by hand. Listen when the machine is running and you should hear the sound of the spray changing as it rotates. Check for items that might be jamming the arm like silverware, cups, jar labels, etc.
2. the little holes in the sprayer arms could be clogged. Need to remove the arms and clean them.
3. If it has a spray arm in the top rack, check to see that the piping for that is not broken or missing any pieces.
4. Any filter screens inside the plumbing could be clogged. This would slow down the spray and result in the dishes not getting rinsed properly. Check the inside of the machine for any foreign objects (see #3 above).
5. The machine might not be emptying between portions of the cycle. After the wash cycle, see if it is draining by either checking for water coming out of the drain hose or by opening the machine before it should start filling up for the rinse cycle.
6. Machine could be overloaded. Or loaded with extremely dirty dishes. Or with foods that are hard to clean like grits or oatmeal.
7. The machine could be improperly loaded. Bowls or platters blocking the spray. Tall objects like glasses and jars should not be loaded into the corners of the racks. The corners do no get a lot of spray and tall items can end up dirty.
Dec 22, 2009 | Neff 24 in. S5555X0GB Built-in Dishwasher
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
Dishwasher leaving white sticky residue on dishes
maybe machine is not filling with correct amount of water try adding an extra omunt of water say 2 litres and see if the machine sounds like it is washing properly
open the door when operating and observe wah arm positions as these turn aroun as it washes
also check that the wash arms are not blocked
Nov 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Top rack does not clean, white residue all over dishes, it appears that top does not spin
the white residue is actuially soap
at the risk of a bad rateing
try refilling your jet dry
or dont use those mixed soaps
also check to ensure there is nothing clogging the holes on the spray arm
hope this helps
Oct 24, 2009 | Electrolux Frigidaire Professional Series...
My dishwasher is leaving a lot of residue on dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
197 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
