Question about Delta & Single Handle Shower Faucet
The handle stops mid way between hot and cold. The water gets barely lukewarm.
  • 349 Answers
Have you tried adjusting the temp control setting behind the handle. Remove handle and mark the dial or remember where it located and slide it out of place so you can move it counter clock wise maybe a 1/4" turn and put handle on and turn faucet on and check for hotter water.
It is a anti scald valve and it's preset to a certain temperture for safety.
Posted on Oct 06, 2010
Shower takes too long to get hot then runs lukewarm then hot lukewarm then gets cooler & and cooler &cold
There is a temperature adjustment on the hot water tank.
Perhaps it is set too low. They are often red in color.
Feb 24, 2016 | Home
Water in tub is only hot for a few seconds and then turns lukewarm. We have hot water everywhere else.
Check this link: http://www.selfhelpandmore.com/plumbing/how-to-adjust-a-single-lever-shower-faucet.php
Nov 17, 2014 | Moen Kingsley Two Handle Roman Tub Faucet...
Water barely lukewarm
is the heater running ? did u raise the temperature higher that the existing water temperature in pool ? are u running the pool pump long enough to achieve the temperature that you want ? IF CHECK (OK) 1- check the internal flow valve control is located between the cold and hot water little black cap, check the condition ,make sure no calcium deposit build inside, 2-is the water temperature in the heater is the same as the pool temperature ? is the pump got full prime with no air ? is the filter is clean ? is this heater propane or natural gas ?
Jun 12, 2013 | Sta Rite Sta-Rite Max-E-Therm High...
I recently had a Glacier Bay single handle shower faucet installed. The hot water is barely lukewarm. What is the problem?
Inside the handle assembly there is an adjustment for the anti-scald feature. If the installer left you the owners manual,it should have instructions how to adjust it. If not, have the installer come back to adjust it.
Jul 26, 2011 | Home
Water from my shower tower is not hot enough. I have hot water flowing from taps all around the house. Only lukewarm water from my shower tower. What is the problem?
what brand of shower handles do you have and do you have just 1 temp handle or is it separate hot and cold?
Nov 17, 2010 | Home
I have a Delta 1700 bath faucet that now only puts out lukewarm water, though it used to get very hot. We have tried to adjust it according to the instructions on the Delta web site, but it doesn't work. ...
Is it a single handle faucet and the dial behind the handle have you removed it and turn it a 1/8 to 1/4 turn and reinstalled. That will control the temp of hot and cold.
Feb 17, 2010 | Plumbing
Hot water comes out lukewarm
Pop out center of handle, and remove the screw from center, and remove handle. There should be a little nylon gear like sleeve that will pull out from center. Pull it out, and rotate it one way or the other, a little at a time, and slide it back in. Now just slide your handle on long enough to try it, no need to attach with screw yet until your done. May take a few tries to get it where you want it, then simply put handle back on, secure it with the screw, and snap cap back over screw.
Jan 05, 2010 | Moen & One Handle Tub & Shower Faucet
Moen T910 Kingsley two handle, whirlpool tub faucet. The hot water handle only puts out lukewarm water. The water heater is turned up and all the other faucets in the house put out scalding hot water.
if you remove the hot water handle on the faucet you can adjust the stop. if it is a newer faucet it has a built in scold guard. the directions should tell you which direction to move the stop to get hotter water
Oct 22, 2009 | Moen T910 Kingsley Deck Mount Whirlpool...
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Delta & Single Handle Shower Faucet  Logo
593 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
