Question about Candy CBL166 Front Load Washer
Candy CNA 166 can spin when in spin mode but will not spin when in washing cycle.
  • 25 Answers
SOURCE: Spin problem on Candy CN450 Washing Machine
nice
Posted on Dec 14, 2007
SOURCE: Candy CNA 145 stops
Found that pipe leading from the drum to the filter was blocked. Machine at first appeared to be draining but on closer inspection was not draining fast enough. Machine now working perfectly. Hope this helps anyone who may have a similar problem.
Posted on Jul 28, 2008
barkencoa
  • 3463 Answers
SOURCE: i am trying to change the element on a candy cna 166
Yes, you do have to lever it out, if you have removed the center nut completely, try and pull the metal plate as far forward as you can, this should expose the rubber seal, this is what is holding the heater in.
Lever round the edge of the seal, and try to force it out, be careful,as you can break the plastic moulding (expensive)
If this does not work, then try cutting through the seal with a stanley knife, and remove it piece by piece.
You will have no trouble getting the new one back in.
Plz rate my solution.
Thanks.
Posted on Jan 16, 2009
SOURCE: Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Posted on Jan 04, 2010
heatman101
  • 43501 Answers
SOURCE: WASHER SPIN CYCLE WON'T WORK. IN ANY CHOSEN SPIN
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 18, 2010
Candy grand o go1682
you should clean the knob with alcohol careful there is spring and a small ball in it
Feb 09, 2014 | Washing Machines
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
Jan 15, 2014 | Candy Washing Machines
My washing machine Candy CE10 does not spin and drain water
HI. firstly have you checked that all dirty water outlet pipe is clean and not blocked. or the cycle circuit could be broken.
Jan 13, 2012 | Candy Washing Machines
My Candy automatic washing machine will not spin
Try the drive belt from motor to the drum it could have stretched a little? The noise you can hear could be the heating element catching the inner drum or something like a wire from a bra came loose in a wash and is trapped between the drums ?
Nov 05, 2017 | Candy Washing Machines
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
I am trying to change the element on a candy cna 166
Thanks.
Jan 16, 2009 | Candy DQW150 Front Load Washer / Dryer
Candy CBL166 Front Load Washer Logo
50 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
