Question about RCA P56923BL 56" Rear Projection Television
RCA-Churping Noise I have a RCA 56" (P56927) Floor Model TV that we bought in 2000. It makes a churping noise(like a bird is in it) when you turn it on. No picture will come on. Is it worth fixing or recycling?
  • Anonymous Jul 07, 2008
    RCA P56923BL 56 in. Rear Projection Television 1998 it makes a beeping sound when i plug it in...how much to repair it..i still want to keep it..can u give me an estimate and what part i need to order? thanx :)
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
It needs horizontal supply repaired and all will be well....
Posted on Jun 04, 2008
Is it possible to disable the churping noise when enabling and disabling the alarm?
How would you know if the alarm was armed or not if you disabled the chirp?
Dec 17, 2015 | 1992 Chevrolet Corvette
Can harmonic balancer be replaced without pulling motor?
yes you can remove the harmonic balancer without remuve engine
Sep 21, 2014 | Cars & Trucks
Heater makes churping sounds
the heater blower motor shaft bearings are the source of the noise, replace the heater blower motor.
Mar 19, 2010 | 1999 Jeep Grand Cherokee
I have the D52W23 RCA TV and it will turn on but no picture will come on the screen. when you turn it on it makes a churping noise every 2-5 seconds do you have any idea of what this could be?
You have may be two bad eletrolytic caps and a high voltage safety cap that are bad. And maybe a bad flyback. This is the common problem for this TV. Sorry!!!
Mar 01, 2010 | RCA D52W23 52" HDTV CRT TV
Problem with my hp 640 fax
once you dial the number you fax will automatically start sending the the Fax signal which sounds like short beeps. This is done so the receivers phone (when answered) will recognized the beeps and switch to fax receive mode.  If you are getting the recording that you mentioned above, that means the number you dialed was not successful in making the connection.  Once you dial the number you should hear the phone ringing followed by some churping noises when the other end answers the call... then other churping and gargle like sounds initially as the fax proceeds.
sounds like your are having trouble with the number you are dialing.
Hope this helps..
~enov8
Feb 24, 2009 | HP 640 Inkjet Fax Machine
Bucking or cutting out when pedal to the floor
check your fuel filter. i might have to be in the needof changing. i am also having the same problem. not the chirping but when i get up to 3500-4000 rpm it cuts out and buckes. from previous vehicles i own usally its a bad fuel filter to carb rebulid. but with the new cars it usually is the fuel system. i would start with the fuel filter cause that is the cheap route. if problem exsist. then take it to a qualified mechanic that you trust that has knowledge and they can hook up pressure,vaccum meters to see what is going on.
Sep 08, 2008 | 2002 Ford Taurus
Will not turn on
this sound is the power supply trying to fire,leaky caps notholding proper b+ voltage.you can check the error codes once the set does fire to view the fault code and narrow it what section is possibly at fault.rca sets take three tries then you out feature. thats why when it does fire check the codes,get a service manual also to help you out.
May 20, 2007 | RCA P52926 52" Rear Projection Television
POWER PROBLEMS????????
If the set trys to turn on and makes noise three times then you hit the switch again and it will try to come on again churping three times , its a shorted horizontal output transistor and a bad flyback transformer. And Im sorry to tell you the transformer is no longer available according to RCA. Its a shame. I just threw out a 56" and a 32 " set that needed a flyback and could not get them.. Well good luck ps please rate this thread.
Oct 19, 2006 | RCA P52835LV 52 in. Rear Projection...
Televison & Video Logo
144 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
