Question about Dell Photo 964 All-In-One InkJet Printer
My printer just began printing with squiggly lines in about 5 or 6 places. How do I fix it? Thanks!
The printer wont print, the symbol with the squiggly line and 2 dots is on
The light on the symbol indicates a paper jam. Refer to this article from the Lexmark website at http://bit.ly/98qRxO for troubleshooting steps. If problem continues, you can also contact Lexmark technical support(under warranty) or your local authorized service provider for professional assistance. Thanks.
Sep 22, 2010 | Lexmark E232 Laser Printer
Dell 3110cn - getting grey tint and wavy lines
It sounds like you have leaky toner or the imaging drum needs to be replaced.
Feb 17, 2010 | Dell 3110cn Laser Printer
My Wii console has little squiggly lines on my screen...
Take it to a place where they fix the games!!
Oct 11, 2009 | Nintendo Wii Console
Canon MX700 printer - vertical lines aren't straight
Have you tried to do an alignment. Also check encoder strip
Aug 19, 2009 | Canon PIXMA MX700 All-In-One InkJet...
When I calibrate colour Magenta and Lt.Cyan fail to print
boil the head printer in a hot water for ten minutes and wiped it smoothly
Aug 09, 2009 | HP DesignJet 130NR InkJet Printer
Docucolor making lines
Hi!
Have you tryed to switch drums (magenta - yellow)? There may also be a problem with developer. If it is not your Magenta drum, it might be the fuser as well - if you pull out your fuser and look on that outside area, you may see a bunch of squiggly lines on it. If so, replace it. If neither your drum replacement or fuser replacement does it, then it is the developer which needs replacement.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Xerox DocuColor 12 Printer
Printers lines are squiggly
calibate the print cartridges
if not solved then clkean encoder strip ( a thin Clear Strip )
check Carriage movement Belt , If REquire Replace
Feb 04, 2009 | HP DesignJet 750c plus InkJet Printer
The blinking light
Hi, The problem your having with the two circles and the squiggly line mean you have a paper jam. Hope this helps!!!!
Dec 05, 2007 | HP LaserJet P2015dn Printer
Dell Photo 964 All-In-One InkJet Printer Logo
199 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
