Question about Creda Washing Machines
How to change door seal on creda W220VW washing machine
  • Creda Master
  • 17,130 Answers
Have replaced door seal in creda w220wv and door light flashing, will not start
Must have disconnected the wires to the lock switch or damaged it it is situated near the door seal to the right were the door locks you can fixet from the top cover once taken off hope this helps you can also test it by inserting a screwdriver small dimention once inserted you shoul hear a clicking sound by pressing it start program and the light should go off if it does not then the result is damaged or you have accidentally disconnected the wires fro it.
Mar 06, 2016 | Creda Washing Machines
I have a W220VW and the machine has started to jump around when starting spin cycle, Why is this and what can i do?
Please check if the machine is leveled or use a spirit level to keep the machine steady or use a rubber mat to check , in case the floor is too much polished. Also check if the machine wobbles. if so check the drum movement or the suspension.
Jan 17, 2013 | Creda W120VW Front Load Washer
I have just 'acquired' A creda excel 1200 washing machine. Model no W220VW serial no 40125977. Unfortunately is have not come with an instruction manual. Is it possible to obtain one please? thank...
In your browser bar type in:
HOTPOINT USER MANUAL and follow the links.
You will find what you are looking for.Although it says Hotpoint, just type your model in the box, and it will come on screen, then you can save it, or download it to your printer
Plz rate my solution.
Jun 21, 2010 | Creda W120VW Front Load Washer
Smells like old smelly socks
this might be coming from the rubber door seal clean it all the way round make sure holes at bottom are not blocked and the rubber door seal is all clean. also clean the draw so there is no power left in there and it is all clean. also a good thing to do is run it though a cleaning cycle with normal detergent at max temperature that the machine can do. hope this helps.
May 20, 2010 | Creda IWD12 Front Load Washer / Dryer
Change door seal Creda 17086
Its not too hard however best answer is to go to utube .co ..They have a video.
Mar 03, 2010 | Washing Machines
How to change a door seal
Look on You Tube for replacing door seals, there are a couple of videos on there that will show you how. All door seals are basically the same for fitting so this will be a good guide.
Feb 24, 2010 | Creda W120VW Front Load Washer
The hinge of the washing machine has broken - Creda W100FW
The door hinge block has fallen inside the front of the washer.To retieve it, tilt the washer back, and you should find it at the left hand side.
Remove all screws securing 2 parts of door together, prise apart with a screwdriver or similar, and the door will come apart.
You can now access the hinge and all other partsd inside the door.
Trust this helps.
Thankyou.
Nov 28, 2009 | Creda W100FW Front Load Washer
Creda W220VW front loading washing machine leaking from bottom of casing. Hoses seem OK, coluld filter need cleaning? If so, how do I access?
Check water flow rate into soap drawer , if very fast water can overflow and run down back of fascia panel and out underneith
Nov 01, 2009 | Creda W120VW Front Load Washer
Creda 1200 w220vw
Door lock light flashing is not normal, check to see if door is shut properly,another problem could be a track blown on control module, you would need to remove front console to check this.
Apr 17, 2008 | Creda W120VW Front Load Washer
Washing Machines Logo
1,438 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
