Question about Sanyo DVW-5000 DVD Player/VCR
Overheating/ shut down
My dvd player will turn on and run for no longer than 5 minutes until it shuts down and power quits running through the player. I removed the top panel and placed my hand one silver block or column- possibly this is called a contacter- I dunno- anyway it's ridiculously hot. If this tremendous overheating is what's causing my player to shut down what can I do?
    Champion:
  • 232 Answers
THE VOLTAGE REGULATOR IS MALFUNCTIONING, THE ONLY SOLUTION WOULD BE TO GET IT REPAIRED IF ITS UNDER WARRANTY. IF NOT ITS CHEAPER TO BUY A NEW ONE
Posted on Aug 05, 2008
Hi I have a Sanyo Convection Microwave EM-C5779V and when the timer goes off the fan seems to continue to run and won't turn off when I hit the cancel button and have to turn it off at the wall.Help?
the fan may keep running to keep it from overheating until it cools down, if you let it go and it shuts down eventually should be no problem, maybe 3 to 5 minutes it should shut down. fan running is not dangerous however if it never stops then the fan will wear out
Jan 01, 2016 | Sanyo Microwave Ovens
My kenwood vr-616 keeps cutting off while listining to the radio or watching the dvd, I have plugged the dvd into a different power supply and the dvd keeps playing but the system shuts off and the power...
The unit may be overheating and shutting down to protect itself.
Please check the fan grills and make sure they are not clogged up with dust as can often happen to amps and receivers. If that is the case then a vacuum cleaner can be used to remove the dust.
If the unit is inside a cabinet try running it outside the cabinet. If it runs for longer before shutting down then this would indicate that it is overheating.
I had the same problem with my Sony home theater amp/dvd and cleaning out the dust cured the problem.
Please rate my answer if this helps.
Many thanks,
Chris
Mar 02, 2011 | Kenwood VR-616 Receiver
This question is for the 24v model which I don't see on here. The problem being my trimmer will just stop like it's out of charge. Then I wait a while and it will go again for a few minutes. The longer I...
Assorted users have had issues with the chargers and batteries on these units. Check that any air vents that go to the electric powerhead are clean and clear. It could be getting overheated and shutting down.
Oct 21, 2010 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Come on, boots up, then shuts down 5 - 10 minutes later.
check your power options make sure you don't have hibernation enabled, its in the system control panel. try booting from a linux live cd like Ubuntu which you can download for free. If it runs fine under linux, its a windows problem, if it keeps shutting down its a hardware problem. Could be bad ram, or CPU overheating.
May 09, 2009 | Computers & Internet
Whirlpool LER8620 electric dryer, shuts off at random. When it
Whirlpool Dryer Won Start
Sounds to me like a thermal fuse. The link gives you multiple scenarios and you can even order replacement parts. I have used it myself with success on washers and dryers. Good luck!
Sep 13, 2017 | Whirlpool LER7646E Dryer
The power shuts off after a few minutes
There could be several factors. Are there any indication or failure lights/codes prior to the unit shutting down? You didn't mention where the unit is located. Does it initially start to read the disc then shut down or is there no activity at all? Please respond with some additional info & we'll go from there.
Feb 21, 2008 | Televison & Video
Shut down
check coooling fan too. or replace the heat sink.
the problem that i see in your case is overheating.
Jan 15, 2008 | Toshiba Satellite A15-S157 Notebook
Sanyo DVW-5000 DVD Player/VCR Logo
186 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
