Question about HP Office Equipment & Supplies
HP Dskjet F300 printer Cartridge light says there is a problem with the cartridges. They are both fairly new and not often used since installed. I have removed both and re installed them without fixig the problem. It printed one side of paper but only half printed the second page. Wht is the solution? Thanks for any help you can offer. John Cardoo
Buffalo12980
  • 625 Answers
SOURCE: HP DskJet 5150 will not print black
re-install the print drivers. if it still doesn't print problem lies in the bubblejet power supply - not user fixable
Posted on Sep 06, 2007
Inky
  • 691 Answers
SOURCE: HP deskjet F300 series
Most likely cause is that the refilled cartridge has not been reset. If the cart has a chip on it, this must be "zero'd" with a zapper or similar to make the printer believe the cart is again full. Simply refilling chipped carts is no good.
Posted on Sep 28, 2007
  • 9 Answers
SOURCE: right cartridge incorrect
If it says to check the right cartridge (Black), replace it with a brand new one or one you know is good.
Walgreens will test and refill your cartridge for ~$10.00 (black).
I have heard of new OEM HP cartridges being bad.
The printer checks the cartridge level sensor and the electrical stuff.
Posted on Apr 25, 2008
bobjrdns
  • 84 Answers
SOURCE: print cartridge is stuck to the right - shall I force it
IT MAY HAVE PAPER UNDER THE INK CARTRIDGE TRY TO UNPLUG THE INK CARTRIGDE
Posted on Oct 18, 2008
How to stop stop HP f300 blinking cartridge light
Remove both cartridges, clean cartridge contacts as shown in link,power on the printer install one by one check which cartridge showing faulty, replace it..http://www.youtube.com/watch?v=fDlbQNsrHsQ&feature=related
Oct 06, 2011 | HP DeskJet F380 All-In-One Printer
The black printer cartridge leaked a fair amount of ink in to the printer. I am getting all lights flashing and the printer won't even turn off when I hit the power button. I did some cleaning and it...
Sorry to hear that.. here are some instructions that should help you out:
Instructions
things you'll need: Microfiber cloth
1. Ink Cartridge Errors
2. Turn the printer on and open the ink cartridge cover. Wait for the cartridge carriage to stop completely before reaching into the printer.
3. Press on the top of each print cartridge, then pull the cartridges free from the carriage. Make sure you are only using HP cartridges labeled as "HP 60" or "HP 60XL."
4. Reinstall the ink cartridges and close the cover. If the ink cartridge error message displays again, remove the ink cartridges as before.
5. Clean the copper metal contacts on the cartridges using a dry microfiber cloth. If you still see the error message after you reinstall the ink cartridges, replace hem with new cartridges.
Print using the device's ink backup mode if you do not have a replacement for one of the cartridges. Remove the cartridge you cannot replace and close the cover and continue printing. The printer will automatically use the backup mode until you install a new cartridge.
Mar 21, 2011 | HP DeskJet F4280 All In One Printer InkJet
Error message, cartridge error "cartridge
I'm not sure what ou mean by fairly new. Is it a color cartridge and have you been printing photographs? Is it an HP cartridge or a generic brand? Cartridges are used up very fast if you are printing photos. I print a lot of photos and have found that although they cost more, the cartridges made for each particular printer usually last longer and do a better job. Are the cartridge lights blinking, as they do when yo have low ink?
It could also be a problem with the cartridge. Try removing the cartridge and very carefully use a damp paper towel to gently clean the printer head of the cartridge. Do you get any ink when you do this? If you do, try putting the cartridge carefully back into place. Check the socket where the cartridge goes when you do this. Does everything seem to be in order?
Do a power reset (turn the printer off with the off button, unplug it for a full minute, then plug it back into the wall socket.) turn the printer back on. If you still have the message,
go to this site http://h10025.www1.hp.com/ewfrf/wc/product?product=1119598&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20â
You will find a video here for your printer as well as frequently asked questions, a manual download, etc.
Good luck to you.
Jan 11, 2011 | HP Officejet 6310 All-In-One InkJet...
Hp lasserjet printer 1200 motor will not stop with a loud noise
It could be a flipped wiper blade in the printer cartridge. Does it make the same noise if you take the cartridge out? If it does not then you should try rotating the green drum on the bottom of the cartridge towards the back of the cartridge (the bigger half) and then reinstall it. If it persists and you're fairly positive it is the cartridge installing a new one will fix it. If it is not the cartridge the machine might need servicing. We are fairly proficient with laser printer repair in our Cartridge World store, and our corporate office started recommending similar training nation wide for our stores. I would call you local Cartridge World and see what they can offer you.
Oct 29, 2010 | HP LaserJet 1200 Printer
I am getting a red light and an E showing where the # of copies should be. What is wrong? It is a HP F380
You have a problem with your print cartridges. Please check to see if the print cartridge door is open. If that does not solve it, please refer to this document on the HP web site on how to resolve printer cartridge conditions.
Though the title of the troubleshooting guide says HP DeskJet F300, the symptoms described in your request for help exactly match the descriptions contained here.
Good luck !
Sep 06, 2010 | HP DeskJet F380 All-In-One Printer
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
I can't get my HP DeskJet F300 series back online.I ve done everything, I ve even stopped the print spooler and started it again but the same problem still exists.And another problem that the ink cartidge...
First, the cartridges. This printer uses a 21 for Black and a 22 Tri-Color. The 58 is a Photo cartridge that replaces the 22, not the 21. Make sure that the cartridges are properly placed in the printer. The next step is the easier one. Might sound like some work, but it is the best way to correct conflicts with HP branded printers. First, uninstall the printer from the PC completely. Use the uninstall function. When that is done, re-install the printer onto the PC and test it. This should solve your problems, as long as there is not physical issues with the printer itself.
Sep 26, 2009 | HP DeskJet F380 All-In-One Printer
Top light blinking, will not print
I believe that the top light is the low printer cartridge signal. Did you replace the cartridge or just take it out and reinstall it? Did you use a new HP cartridge or refilled cartridge?
Try a new ink cartridge from HP and double check that you have the correct cartridge for your printer. If that doesn't solve the problem, contact HP.
Sep 15, 2009 | HP DeskJet 5550 InkJet Printer
The reasons are many 1. bublejets which this is have the heads in the cartrige and have a limted life- the heater burn oun out. So more detail when you say 'wont red your cartrige' what do you mewan It wont print at all nothing happens? or 'Prints' but delivers a blank sheet? Be more specific
Sep 27, 2007 | HP Easy Refill Kit for (HP) Black Inkjet...
Sep 06, 2007 | HP DeskJet 5150 InkJet Printer
69 people viewed this question
Seeker5211
Seeker5211
