Question about Whirlpool Duet GHW9150P Front Load Washer
Front door leaks - Whirlpool Duet GHW9150P Front Load Washer
  • 121 Answers
The door gasket is bad this page will help http://www.appliance-repair-it.com/GE-front-loader-washer.html
I know the page says GE front loader but replacing the door gasket is the same.
Posted on Oct 05, 2010
Water leak in front left corner of unit. Rusty leveler near strainer.
Is the leak on the same side as the hinges? If yes I'm guessing someone overstressed the hinge when opening the door too widely or by leaning on the open door and the seal is just barely tight enough now. Crack the door open half an inch and eyeball the door gap from top to bottom on the open side to see if the door is unevenly hinged - you can use a ruler to help measure but you need to keep the door immobile while comparing top and bottom gap widths. Tape a hard wedge in place in the doorframe to help with that. Fix for that? Pressure on the door in the right direction to straighten the hinge mount.
Feb 25, 2014 | LG WM2688HWM TROMM SteamWasher
I have a LG front load washer seem to leaking front area. Hoses OK Need o see what causes it to leak
you will need to narrow down where the water is leaking from. under the door...? behind the bottom drain door..? underneath machine..? behind machine..? leaks can be found in many areas.
May 16, 2011 | LG WM-2277HW Front Load Washer
Washer leaks when it isn't packed full of clothes.
check your door seal if leaking in the front if the back its probably one of the water lines leaking
Feb 24, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Whirlpool fron loader washer leaks at the door
The water should be able to come up to the door level without leaking. Chances are you have build up on the bottom side of the glass on your door. If so take a razor blade and scrape the build up off. Your door will quit leaking.
Aug 12, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Water Leaks Out Front Door
It seems as if the lock in NOT working properly. Try replacing the door seal. If that doesn't solve it then also replace the door lock.
Apr 05, 2009 | Maytag Neptune MAH6500A Front Load Washer
Kenmore Elite HE3 water is leaking out the front door
These are notorious for the door boot leaking. Look for any tears, rips, pinholes in the door boot. Also make sure the door is parallel with the machine. Most likely it's the boot. Parts about 100.00. Labor can run from 110-140 depending where you go.
Mar 16, 2009 | Kenmore Elite 45986 Front Load Washer
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Leaking....front door won't close
Carefully look at the door gasket to see if any irregularity in seal. Could be problem with door seal; or you could easily change door mechanism thru a spare part shop quoting your model and spare-part No or "door mechanism"
Mar 28, 2007 | Kenmore 43042 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
447 people viewed this question
Dan Webster
Dan Webster
Sal De
