Where can obtain parts for a Tadiran split system air conditioners in the United States?
bobotfel
  • 236 Answers
SOURCE: air conditioner
Turn off unit supply and check the blower wheel inside the indoor unit by rotating it manually by your finger if the blower wheel rotates freely then there is something wrong with your fan motor or fan motor capacitor. But if the blower wheel is not rotating freely try to check the fan motor for lubrication or some bushing dried of and no oil
Posted on Dec 31, 2007
bobotfel
  • 236 Answers
SOURCE: Split System Air conditioner
If it is water leaking check the indoor drain pan if overflow with water.If the pan is overflow with water then you need to clean your drain pan and drain pipe. While the unit is operating check the drain pipe if water drip, if no water coming out from drain pipe you need to flush it with water to flush out the restriction.
Try also to check if no icing build in the evaporator fins. If icing is present then you need to clean your indoor evaporator pins and air filter. But if it is clean and still icing is present then your unit is out of gas.
Posted on Jan 29, 2008
SOURCE: centrex split system air conditioner
i replaced my batteries and its worked (der- had a blonde moment)) um to heat i just set my air con on 28 - 30 c and its lovely BUt ususally leave it on 25c..... there is an over ride button under the flap thingie where the filters are try and find that ??? the only thing i would suggest is keep hounding the realestate for your manual they have a duty of care to provide that to you...
Posted on Feb 21, 2008
Johnny Reb
SOURCE: Remove and relocate split air conditioner
The simplest way of explaining this is as per the following. On your outdoor compressor unit there should be two pipes, one smaller diameter [high pressure] and a larger diameter pipe [low pressure]. Turn your A/C on inside the house and then shut off the smaller diameter pipe. Run the unit for a around 3 to 4 minutes and then check if the cooling is reducing from the unit inside the house. When you feel room temperature air [not cool] being emitted from the indoor unit shut off the larger diameter pipe and turn off unit. Isolate electrics, disconnect A/C piping and immediately seal the piping with good quality tape to prevent egress of dirt. When re-installing a quick purge of gas is usually only required to clear the lines if they were sealed properly and kept clean. Ideally running a vacuum pump is recommended but if care was taken then it may not be needed, as in many of my installations.
Posted on Nov 13, 2009
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
My tadiran split system air conditioner is blowing warm air
if its warm air like really hot then you switched the unit to heat mode
if its blowing air in room tempereture then there is a gas leak somewhere ,so you'll have to find the leak source and after that fill the unit with freon gas.
Aug 26, 2014 | Heating & Cooling
Tadiran mini split unit shuts down after 10 minutes and the pressure light is red
Hi Kathleen, Sounds like you may need a professional come out to charge the unit with freion. Hope this helps.
Oct 21, 2013 | Heating & Cooling
What does E1 mean in tadiran 250 R, it works then stops and screen shows E1 when it operates as a heater
h Air Conditioners
Nov 24, 2012 | Heating & Cooling
Frigidaire FRS12PYS1 E-6 error code
I have a united minisplit fridigiar 12. 110 volts
E6 drive failure. to that is the error.
Apr 03, 2012 | Frigidaire FRS12PYS1 Split System Air...
Can you download to me an English Operating Manual for a Tadiran R15 Air Conditioner... Catalog Model GWH12MB-K3NNA3B Specification GR-020
Apparently, your model, which is manufactured by Carrier Corp in Israel, has been replaced by a newer, yet similar model to yours, which I have included a link to.
http://tadiran-aircond.ru/02/0202.pdf
If the above doesn't suffice, here is a contact link for Tadiran Customer Service.
http://www.mdigital.co.il/tadiranIntl/contactUs.asp
Hope this helped you.
Jun 01, 2011 | Heating & Cooling
Good Day! I saw Fixya.com, and its describe that through this site, anybody could get the diagram of Ref. even an aircon unit, But since last year 'til now, I cant reaaly imagine how to get the...
For Aircon, click here:
www.pdfee.com/wiring-diagram-split-system-air-conditioner.html - United States -
For Refrigerator,
mtbest.net/chest_fridge.pdf
Hope, it's helpful.
Jan 16, 2011 | Heating & Cooling
Where do I add the new r 410a refridgerant on 2004 Pontiac vibe?
410a cannot be used in a automotive system it will cause damage to your compressor, other other a/c components.
410a is used for home use only.as a substitute for R-22
see below definition.
Although the United States Environmental Protection Agency has mandated that R-22 along with other hydrochlorofluorocarbons (HCFCs) be phased-out in the United States, few window-mounted air conditioners are available that use R-410A. However, all of the largest central air conditioning systems manufacturers in the United States offer R-410A. As an alternative to window-mounted systems, a ductless "split" system is available which uses R-410A refrigerant, and can be installed with a 3-inch hole through the wall (or window opening).[4] R-410A has replaced R-22 as the preferred refrigerant for use in residential and commercial air conditioners in Japan and Europe.
Parts designed specifically for R-410A must be used as R-410A operates at higher pressures[5] than other refrigerants. Thus R-410A systems require service personnel to use different tools, equipment, safety standards and techniques.[6] Equipment manufacturers are aware of these changes and require the certification of professionals installing R-410A systems. In addition the AC&R Safety Coalition has been created to help educate professionals about R-41-A system.
manufactures recommendations for vehicle
NOTE:
  • R-134a is the only approved refrigerant for use in this vehicle. The use of any other refrigerant may result in poor system performance or component failure.
  • To avoid system damage use only R-134a dedicated tools when servicing the A/C system.
  • Use only Polyalkylene Glycol Synthetic Refrigerant Oil (PAG) for internal circulation through the R-134a A/C system and only 525 viscosity mineral oil on fitting threads and O-rings. If lubricants other than those specified are used, compressor failure and/or fitting seizure may result.
  • R-12 refrigerant and R-134a refrigerant must never be mixed, even in the smallest of amounts, as they are incompatible with each other. If the refrigerants are mixed, compressor failure is likely to occur. Refer to the manufacturer instructions included with the service equipment before servicing.
Oct 19, 2010 | 2004 Pontiac Vibe
I have an Amcor AMB10000E and need a hose plus the part that attaches it to the air conditioner - can you help please?
Your best bet will be to contact the manufacturer directly. They will help you either obtain the part(s) you are needing or will point you to someone who will have those parts. Here is the USA information. Let us know if this was helpful and Good Luck!!! :-)
USA
Amcor Inc.
685A Gotham Parkway, Carlstadt,
New Yersey 07072,
United States of America
Tel: +1 201 460 8100
Fax: +1 201 460 9481
Email: amcorusa@amcorgroup.com
Feb 22, 2010 | Amcor AL10000E Air Conditioner
Heating & Cooling Logo
621 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
