Question about EnGenius EOC-3220 (EOC3220)
After a windy day lost wireless connection
I have no wireless connection between my access point and my bridge. I cannot log into the access point using the ip address that was assigned when we set it up. I tried to go back to the default address of 192.168.1.1 but that number is assigned to our internet dsl modem. I bypassed the dsl modem thinking that perhaps 192.168.1.1 would then work. No luck. I don't know if there is any way to log into the firmware for the EOC3220EXT that is my bridge without knowing what the ip might have been reset to. I think that Engenius support may tell me to send it in for a new transmitter repair job. Do you know of anyway to get to the firmware, or even install an upgrade to the firmware if I don't know the address of the access point? Any help would be appreciated. Thanks.
  • samshac Jun 01, 2008
    EOC3220 was dead. I purchased a new EOC 3220 EXT and configured it as my access point and everything is now working fine. Your information was helpful as long as I could log in to the IP. I finally determined that since I could not log into it at all, it must have taken a fall...not literally. I was a little disappointed in it's lifespan. It made it to just past it's one year birthday. Boo Hoo.
    Thank you for your help.
  • samshac Jun 16, 2008
    Thanks for trying, however, it was determined that my access point was dead and I may need to send it back to the mfg. for repair.
For a new unit disconnect the eoc from the network and connect directly (through POE injector of course) to your laptop/pc.  then in network connections setup your lan port TCP/IP settings as follows.  ip 192.168.1.10 subnet mask 255.255.255.0 then gateway 192.168.1.1
point your browser to 192.168.1.1 or 192.168.1.2 (one if it is in AP mode and the other address works if it is in bridge mode).
When configuring, I assign it an new static IP outside of the DHCP assignment range.
To see how it is setup afterwords you can use hyperterminal with a null modem cable to view the current config.  instructions on the engeniustech.com support page.
Posted on Jun 01, 2008
I cant access the 192,168,2,1
Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-... Hope i helped you.. great day to you.
Jan 30, 2013 | TENDA A3 150Mbps Wireless Range Extender
How do i set bridge mode?
Depends if you need a wireless or wired bridge?
Here is some info for you.
Infrastructure Mode
With a wireless Access Point, you can operate the wireless LAN in the infrastructure mode. This
mode provides wireless connectivity to multiple wireless network devices within a fixed range or
area of coverage, interacting with wireless nodes via an antenna.
In the infrastructure mode, the wireless access point converts airwave data into wired Ethernet
data, acting as a bridge between the wired LAN and wireless clients. Connecting multiple Access
Points via a wired Ethernet backbone can further extend the wireless network coverage. As a
mobile computing device moves out of the range of one access point, it moves into the range of
another. As a result, wireless clients can freely roam from one Access Point domain to another and
still maintain seamless network connection.
Wireless Bridging Overview
Using Wireless Router as a Wireless Access Point
May 03, 2011 | NetGear RangeMax WPN824 Router
I can't enter the web from 192.168.1.1 or 192.168.1.2 how i can enter web setting AP senao 8610S? what sould i do?
Start>Run>Type in CMD
Press enter
Type ipconfig
Note your gateway
Go to internet explorer and type your gateway in by itself. i.e. 192.168.1.254
Press enter
If this does not work attempt reattempt the gateway address but replace the last number with 254.
i.e. gateway=192.168.2.1 instead type in 192.168.2.254.
Mar 03, 2011 | EnGenius ECB-8610S 802.11a/b/g Wireless...
I lost my cd for setup ipls help me this is my serial number of my netgear 1um8977f03f04tnx
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point's DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network
Feb 21, 2011 | NetGear WGR614 Wireless Router
Do I need to change the password on this product if the password for my wireless network is changed?
I am assuming you are using it as a wireless bridge to connect wired devices to your wireless network. If that is the case, then yes. You must change your key on all wireless devices (including your bridge) if you change the key to connect to the access point.
Oct 29, 2010 | EnGenius ECB-3220
Using a wireless bridge for Dreambox
i dont think it has wirless on it mate but j tag it
Apr 16, 2008 | Trendware TEW-430APB 802.11g/b (TEW430APB)...
OTC Wireless Bridge
Care to check if the ip card software is properly installed?
Oct 05, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
Cannot Connect Gaming Console or Remote Computer to the Internet
1. Make sure the gaming or remote computer has a correct IP address with the same IP subset address as the wireless router or access point. 2. Turn the bridge off. 3. Turn the bridge on. 4. Recheck the IP address for the gaming computer or remote computer. 5. Turn off all network devices. 6. Power on the wireless router or access point. 7. Wait 30 seconds. 8. Power on the bridge. 9. Check to ensure the bridge connects to the wireless router or access point. 10. Power on the gaming console or remote computer.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
EnGenius EOC-3220 (EOC3220) Logo
364 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
