Question about NEC Mitsubishi MGE 2900 Generator- Voltage Regulation:AVR. Frequency: 60
WHERE CAN I GET A GFI BOARD FOR A MITSUBISHI 5800 ROU
  • 3,740 Answers
Here is the parts breakdown:
http://www.mitsubishi-generators.com/pdf/pb_usa_102_and_up/MGE5800RO.pdf
Mitsubishi Generators and Pumps Division is closed.
For Parts and Service, please contact Mitsubishi Engine North America, Inc
Ph 630-268-0750 Fax 630-268-9293
Thanks for choosing FixYa,
Kelly
Posted on Oct 05, 2010
Mitsubishi MGE 5800 generator won't start. Will run for seconds when I put gas directly in the carburetor. I cleaned the carburetor etc.
If the engine will start when starter fluid is sprayed into the carb, you missed cleaning some small orifice in the carb. Recheck/reclean the carb and you should be OK.
Aug 18, 2017 | NEC Mitsubishi MGE 4000 Generator ROU...
My hot tub works for about 20 mins and clicks the GFI off. Then I reset the GFI and the spa comes on for about 7 mns and trips the GFI again. Is this my heater doing this?
Easy way to test for the heater issue is to disconnect the heater from the board. Disconnect both leads from board and let the spa call for heat. There is also a chance the GFI breaker is bad however most times the heater fails and the breaker is doing its job.
Apr 01, 2017 | Hot Tub Works Pool & Spa
Generator stalls out when auto idle switch switched to on position.
It sounds like a blocked jet and or carb issue, may need to service the carb
Sep 17, 2013 | NEC Mitsubishi MGE 4000 Generator ROU...
I have gaz in my oil
you may have a faulty needle valve or a broken float in the carburator. allowing the the bowl to over flow and run into the crankcase
Jan 18, 2013 | NEC Mitsubishi MGE 4000 Generator ROU...
Frigidaire GLRS264ZA refrigerator keeps blowing GFI circuit
The fan and defrost heater are run off the same relay on the board. When on defrost, the fan stops. when the fan starts, the defrost heater is switched off, Sounds like the neutral to the board may be shorting. If you have the ability, try powering the evaporator fan from the compressor relay, disconnecting from the board entirely. To see if this will work, just take a temporary wire to the fan when disconnected and see if it trips while running.
Aug 07, 2012 | Refrigerators
Cannot start mitsubishi mge 4000
This type of generator has an oil-level sensor to prevent operation when it is too low. Check to see that the oil is filled to the right mark on the dipstick, and be sure it is on level ground when you do this.
Mar 12, 2012 | NEC Mitsubishi MGE 4000 Generator ROU...
Mitsubishi MGE 6700 generator. Starts and runs fine, but no longer putting out power. What would it cost to repair this issue?
These generators have a GFI outlet on them, and they do fail. I would suggest you check all output circuits and see if you have any output. If so, pull the GFI and see if it is getting power to the outlet. If so, replace the outlet.
Feb 20, 2011 | NEC Mitsubishi MGE 4000 Generator ROU...
When I have it on it stays on high idle speed. When I push the auto idle it will not change the speed to normal. It idles at high speed all time.
If you have anything plugged into the generator, consuming any electric, it will run at high. It must run at high speed to generate 120V. It will only idle if your turn off the load.
Feb 13, 2010 | NEC Mitsubishi MGE 4000 Generator ROU...
NEC Mitsubishi MGE 2900 Generator- Voltage Regulation:AVR. Frequency:  60 Logo
180 people viewed this question
Top NEC Electrical Supplies Experts
Mike
Rod Hoefakker
Level 1 Expert
obsteiner
Are you a NEC Electrical Supply Expert? Answer questions, earn points and help others
