Question about Canon imageRUNNER 5000 Copier
Canon IR5000 replaced the fuser heat roller and sep claws now machine will start but no fuser activity and no errror. metered all parts of fuser no problems, any type of reset besides the one in service mode?
    Problem Solver:
  • 7 Answers
See if the heater turn light...if not the unit one is not inserted properly....
Posted on Oct 06, 2010
My photocopy machine minolta ep4000 its up and bottom side of the page are coming black
When was the last time you had a Konica Minolta Tech come out and give it a cleaning and replace parts such as developer, Drum, corona wire xfer and sep wires, cleaning blade. Botton fuser roller mite need to be replaced. A Minolta legacy machine, try the web site below to get a start on the above parts Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 20, 2011 | Minolta EP4000/5000 CS/PRO Copier
We have a imagerunner 210s. we just replaced the fuser unit and now when you try to copy, it copies the original but when it feeds through the exit door, it jams and when you open the door, the paper is...
please to see the claws. they are 5 claws which pluged on exit unit.
if you open the cover exit you will see them.
the shape like as a tigers claw. but more like as triangle.
they are move by spring, you try to moving. what are they work well?
problem usually cause
- the spring was loose or (you can plug or replace the spring)
- the claws have broken or (you replace a new)
- the claws dirty by crust toner. (you can clean up by your finger or your claw)
good luck.
May 22, 2011 | Canon imageRUNNER 210S Copier
How do you remove a paper jam at the site where the paper exits the printer (causing an accordian-style fold)
Turn off and unplug the machine you can open the front door open the exit side where the paper exits out gently remove paper the issue is caused by the upper fuser claws on the fuser unit they are worn you will need to replace them or replace the fuser unit assembly as other internal parts in the fuser may also be worn like the rollers
This should be done by a trained certified engineer
WHEN YOU TURN OF MACHINE MAKE SURE TO OPEN DOORS AND WAIT A FEW HOURS SO THE FUSER AREA CAN COOL DOWN CAUTION THE FUSER AREA IS VERY HOT
Feb 10, 2011 | Canon imageCLASS D320 Digital Copier
Canon ir5000 copies have horizonal bands of light copy quality. How do I get even, good quality down the entire page?
The machine probably needs a service paying attention to the development and the cleaning areas. Also, clean or replace the corona wires and check that there is no flat spots on the fuser roller.
Jun 18, 2010 | Canon Office Equipment & Supplies
I have an old IR5000 and I woudl like to know when did they recall the part for heat image unit which stop the machine working properly.
On my knowledge parts for ir5000 is still in circulations.Especially the fixing rollers and gears, web,... atleast for EU
Apr 08, 2010 | Canon imageRUNNER 5000 Copier
I have an old canon NP2120 Copier. I am getting an error code E000 when I turn it on. Is that something i can fix?
Are you mechanically inclined????
If yes the problem is most likely the fuser lamps are burned out.
This is to take out the fuser unit (the two heat rollers where the paper exits---------let machine cool first!!!!!!!!!!)
1-unplug machine
2-open left side door
3 open front door
4- remove the green knob on the left
5-remove the left side cover ( i beleive you need to take off the two screws on top that hold the glass also)
6-remove the back cover(it is hooked onto the side cover)
7-after removing the side cover look at the fuser left top corner unplug the connector- there should be one on the right also big black wires with a white connector remove the screws that hold the fuser in place
8- once the unit is out there is a lamp that runs the whole lenght of the roller that is the fuser lamp there are wires on each side, remove the lamp bracket holder and one wire, you should be able to tell if it is blown, it will be black and smoky looking not clear.
if you go through these steps you should take advantage and replace the thermistor, thermofuse, claws, and oil roller.
I use to love the 2120 they are one of the best machines Canon put out a true workhorse, do these things and don't worry about hte fuser for another 3-5 years .
If you don't have a parts supplier try precisionroller.com
Aug 19, 2008 | Office Equipment & Supplies
Panasonic printer dp4520 error code j40
This indicates there is a paper in the fuser area(very Hot section be cautious).1. open the front door.2, open the left side door. look inside for a green plastic handle & lift up he metal guide plate sometimes the paper gets wrapped around the upper heat roller or curled up and around the separator claws. if so be very careful not to scratch the rollers or break the sep claws. there is a green handle/knob located in the machine that can be turned, this turns the fuser rollers and makes it a little easier to remove a fuser paper jam. After you remove the paper jam close all the doors/panels you first opened. the copier should reset itself. I have seen the pj errors change to a new one indicating another pj still exists. if so look again and remove as indicate by the Lcd screen. Please leave positive feedback if this helps
Jun 07, 2008 | Office Equipment & Supplies
Paper Jam
1st, you need to find out exactly where the paper is getting stuck.
Is the paper stopping just as it gets to the rollers, or
stops when it goes through the rollers and are getting stuck on the little fuser claws?
If the paper is stopping right when it gets to the rollers, then there is a problem with the fuser drive or drive gears.
This you would probably need to place a service call to have repaired.
If the paper is getting stuck in the claws, then make sure that the claws are not stuck down. All claws should be up against the rollers, both upper and lower claws.
Sometimes they get stuck down or the spring gets knocked off.
Other than that, as long as both upper and lower fuser rollers are in good condition, paper should pass through.
If you have any other questions, feel free to repost.
Good luck.
If I have helped answer your question, please remember to post a rating.
Mac =)
Mar 18, 2008 | Toshiba 2060 Copier
Canon Image Class D860 copier purchased 2005 - KAB-15948
dog ears are usuallycaused by paper hitting something before the fuser or at the fuser. the claws or fingers that ride on the hot rollers are getting worn or are out of place.
to determine the exact location, stop the copy at different locations by
1- make a copy
2- stop the copy by turning off or openning a door
look at the paper does it have the dog ear at that location? no stop it a little further until it does.
My guess is going to be the claws or fingers on the fuser roller.
Good luck
Dec 11, 2007 | Canon DHD860 Copier
Samsung scx4216
Open heat error, you have a fuser problem, replace fuser. Fuser consists of Upperheat roller, lower heat roller, exit claws/rollers, and a heating circuit with a lamp, thermal temp sensor (thermistor) and a thermal fuse/cutout.
You could measuring fuser removed from machine, checking lamp etc for open circuit, thermistor should be neither short or open circuit.
These days we dont, we just change assembly due to it being a common constantly wearing part, and if for example I pull it apart, fix the lamp, put it together then soon enough I will need to pull it apart again to fix worn roller etc.
I could give you the part number ... JC81-01690A but dont use it, cause that part is for 220volt cause thats what we use in Oz, so contact Samsung and ask for dealer in your country who can supply you.
P.S. Fuser is the Hot bit (180 deg c) at back near paper exit that bonds(melts) the print into the paper.
Nov 14, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Canon imageRUNNER 5000 Copier Logo
198 people viewed this question
old marine
old marine
