Question about Gateway LCD17TV 17 in. Television
Philips hdtv flatscreen for a spa
I cannot turn the power on with the remote. there is power to the tv the button is red there in no power button in front of the tv. you can hear the dvd when you put it in but the screen doesnt come on. totally black, how can i turn the tv on, without taking it apart? someone told me to take the tv out of the case and turn it on manually, but who wants to take the tv apart everytime you want to get in the spa?! if you could give me any advise it would be appreciated. its a philips hdtv flatscreen for a spa
  • warlock73 Apr 03, 2009
    I have a Gateway GTW-L17M103. Out of nowhere I cannot turn it on, remote or manualy. The Light is on the power pack. Can't find help any place. Please Help !!!!
  • 4 Answers
I was searching some for help with my GTW-L17M103. It too went black. I could not turn it off (power light was green). Thank goodness, I found your solution, except I need a little more help. I opened my monitor, removed the metal cover and found F3. I see what my daughter refers to a little "white bridge" with the letters FA2 or EA2. My questions are: Is this the correct part that needs to be replaced (2 amp fuse)? Where can I buy it? What instrument or tool do I need to replace the part? You mentioned you could not find a surface mount (not sure what that is), therefore you "piggybacked a 2 amp pico fuse on the blown one and it is working great". Where can I get a 2 amp pico fuse? I'm not a hardware guy but I'm not afraid to work on electronics. In advance, I thank you for this great service you provide via the forum.
Posted on Jun 16, 2009
I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
I have a Philips model Problem with the Philips 50PL9126D/37B 50 in. HDTV DLP TV I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
Apr 22, 2011 | Philips 50PL9126D/37B 50" DLP TV
Have a Phillips flatscreen tv. I can't turn it on with the remote but can turn it on by pushing power button onthe side of tv. Batteries are new.
Hello, you could still have a worn out power key. Turn on the power manually(power key on the TV) then select channels/adjust volume/press the number keys.If all these work on your TV, then you know another remote is needed.
Nov 19, 2010 | Philips Televison & Video
Can I turn on the samsung flatscreen without a remote? The remote got water in it and will not work. Does the tv have a power button located on the tv?
Yes, channel buttons, sound buttons and power button is located at the side of the screen. Look for it. For most TV's its located behind and for some at the side and for some in the front bottom.
Nov 24, 2009 | Samsung 52 in. LCD Flat-Panel HDTV
I just bought a philips 42" flatscreen TV model #42ef73208-37 and it won't turn on. I have a red blinking indicator light but the TV won't turn on, what can be the issue?
  • Your TV has a protective mode in case there is too much heat build-up.
  • Check the clearance around the vents of the device to be certain there are no blocking walls or cabinetswhich would limit the air flow.
  • • Check that the TV’s AC power cord is plugged into the mains socket.
    • Unplug the television, wait for 60 seconds.
    Then re-insert plug into the mains socket and turn on the television again.
If that fails take it back.. Good luck
Sep 09, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 50" tv will not pick up remote signal
Even tho we change settings on Phillips flatscreen Model 50pfp5332, if we turn it off and back it' shows it's RETAIL SETTINGS. We do not have the original manual and would appreciate your help........
Sep 06, 2009 | Insignia 42" LCD Flat-Panel HDTV
Philip hd flat screen
first time I have seen a spa tv lcd fail, sorry but I can tell you it is the capacitors in the tv that have issues they will have to be re[placed call a service tech that can take the tv in for electronic work if you want to spend the money or you can replace the whole thing for probably less money than repairing the old unit, by the way if you have a tv in a spa the humidity is well past the operational limit of the tv components
May 28, 2008 | Philips 15MF170V 15 in. HDTV-Ready LCD...
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Philips 42in HDTV rear projection won't power on.
There is a reason why people give these away. Very expensive to repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
No picture on my Philips HDTV
call a tech let them check your tv if no power it will be the power supply or related circuits.if you have sound then it could be video circuit module.as you said that it dont have pictures you did not mention anything about sound.good luck
Apr 23, 2007 | Philips 42PF9830A 42 in. LCD Television
Gateway LCD17TV 17 in. Television Logo
170 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
