Question about Sharp AL 1631 Copier
Our Sparp AL-1631 is flashing 4 then H what does it need?
  • 1,110 Answers
To reset the H4 condition on your Sharp AL 1631 copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
Thank You for using Fixya. Our solutions are being rated this month based on positive testimonials so please leave a testimonial for me if this solution works for you.
Thanks!
Posted on Oct 06, 2010
AL-1631 is flashing "H". How do I fix this which appears to be heat related.
the h means that your fuser needs to be replaced. it might be fixable by changing the thermal fuse but most of the time the whole fuser needs to be replaced
Sep 28, 2014 | Sharp AL 100DR Laser Toner Drum Works for...
I HAVE A SHARP DIGITAL COMPUTER (AL 1631) pushed the button to make a copy the,procedure came up with (4 h)flashing continuously in it place. How do you eliminate the (4 h) flash and continue copying. And...
4h not sure what you are reffering to ?
wired or a wireless printer
check the leads attaced make sure connected securely
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow? ! question exclamation mark or a red X
this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Sep 27, 2011 | Sharp AL 1631 Copier
AL 1631. Indicates that a drum has to be
To reset the drum light press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
Feb 13, 2010 | Sharp AL 1631 Copier
Copier flashing "H4" code
Hello sir;Follow these steps within 4 seconds; press 'clear', "exposure" ,"clear" "exposure" then enter 14 hit print, should be OK.
Jan 30, 2010 | Sharp AL 1631 Copier
Sharp al-1631 copier. drum error code
You can reset this indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
Nov 16, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
Sharp AL-1631: Flashing H-4. Paper tray light is
H4 indicates that you have no power for your heater lamp. Either the thermostat or the lamp is open. For the thermostat, you can reset it if you know how to remove the fuser section and its cover so you can see the thermostat and reset from there. For the heater lamp, check its continuity using a tester.
Jul 21, 2009 | Sharp Office Equipment & Supplies
Asharp AL-1631 won't print anything but a mess.
E7 is a few different things. Are there two more numbers flashing after the E7 appears?
F5 has to do with the copy lamp.
It should be looked at by a technician. It needs to be looked at for the E7 issues.
Jun 13, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
244 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
