Question about RTO Aqua Pro Systems Pro 600 60,000 BTU Heat Pump w/ Cupro Nickel Hx
I have a Aqua Pro heat pump,and have a white powder all around the cooling fins,piles of it. Could you explain why? Sincerely,Jan Koper
What minimum space is needed round the AQUA PRO HEAT PUMP 17KW for it to function efficiently?
couldn't tell you exactly without model number but every manufacturer will tell you some ridiculous amount expecting you to put the thing in the middle of the yard. I've seen rows of units with less than 6 inches of clearance on three of your sides that run for years and years. obviously it needs to breath but I think manufacturers take it to far, give it 10 to 12 inches and it will be fine but sure, the more the better.
Feb 08, 2018 | Heating & Cooling
I have a 2013 rincon 680 with 26" mud lights on it and almost every time I ride it over heats been through 2 water pumps. always pressure wash everything off after every ride only 650 miles on it. Had...
if it is water cooled check for mud in the radiator fins. If air cooled check fpr mud at the base of the head and barrel fins. You may need a compression test to see if there is a head gasket problem if water cooled .
Dec 21, 2014 | Cars & Trucks
How r15 radiator works
r15 radiator works under the same principle as most systems work in regards to radiators, water is pumped throughout the bikes cooling system that is under pressure so it can pass through the system in a circular method this means that the water passes over parts of the motor that have a heat build up due to combustion and is then passed through the radiator which is getting cooled by fresh air either by the bikes fans or the movement going forward that forces cool air to flow over the radiator and cooling down the hot water that can then get recycled and pass over the parts of your motor dispersing the heat back to the radiator for cooling , this heat transfer was done by the motor having fins built into its shape therefore the passing air would pass through and around the fins taking much of the heat with it, but most modern motorcycles use a radiator much the same way as a car does .
Nov 29, 2013 | Yamaha YZF-R15 Motorcycles
I have a Aqua Pro heat pump P130 with error code F5 does anyone know what that means
Error FS?
Unit has started defrost cycle and will reverse operation in 5 minutes.
If coolant has nor res=ached desired temp, unit will shut down and display FS
Other models:
FS can mean not enough water flow in cooling mode.
Mar 25, 2013 | Aqua Pro Swimming Pool Heat Pump 125000...
Model z-110 white powder build-up around the outside end of the motor. no water leaking at this time. motor runs on 240 v. BOB ADAMS
White powder build up would indicate to me calcium deposit but calcium is usually a pretty hard caked on product once produced.
Coming out of the back of the motor is usually caused by the friction of the windings working.
Rod
www.uspartscenter.com
Jan 21, 2013 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I need a diagram for aqua pro 600 heat pump
if voltage to unit and calling for heat check ignitor and gas
Jul 27, 2012 | RTO Aqua Pro Systems Pro 600 60,000 BTU...
How do I wire the AquaPro 600 correctly? Do I need 3 or 4 wires> L1 and L2 Hot, Ground and Nutral or just the 2 Hot and ground?
Depends. L1 and L2 would indicate two hot wires. Definitely need a ground. I would pull a white just because. Is there ANYTHING in the device that operates on 110 - if yes, you will definitely need the neutral.
Sep 04, 2011 | RTO Aqua Pro Systems Pro 600 60,000 BTU...
Cooking info
You can print a new manual off of www.chargriller.com. But, the basics are:
1) Take cooking grates off of grill
2) Put enough charcoal on the grill to cover the desired cooking area two coal layers high
3) Pile up desired amount of charcoal (laid out in step 2)
4) Spray lighter fluid all over charcoal pile
5) Light the pile
6) Let the pile burn until the flames die out and most of the coal has turned white
7) Spread the coals back out (use tongs they will be hot). Put any coals that are still black on top of the white ones.
8) Put your cooking grates back on the grill and let the last black coals turn white and the grates heat up.
9) Now cook!
Apr 14, 2010 | Char-Griller Super Pro
Copper coils of aqua pro corroded and leaking on heater
Replace coil. This damage is a result of a continually low ph and alkalinity condition or an extremely high level of chlorine. Test water frequently
Aug 07, 2009 | RTO Aqua Pro Systems Pro 600 60,000 BTU...
Corrosion on the fins of my heat pump
Do you have something close to it like a hot tub or spa or pool? If so the Chlorine is reacting with the aluminum causing it to corrode.
I suggest moving one or the other if this is the case.
If this helps you please rate me as high as you can If not please post back with an extended detail of your problem. thank you for using fix ya. Good Luck.
Nov 13, 2008 | Hayward Heatpro 100,000 Digi. Thermostat...
RTO Aqua Pro Systems Pro 600 60,000 BTU Heat Pump w/ Cupro Nickel Hx Logo
56 people viewed this question
Top RTO Pool & Spa Experts
john h
old fart58
Craig Butler
Craig Butler
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
