Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Your television cannot display this video service over HDMI. Monitor does not support HDCP (H1001).
2 Suggested Answers
SOURCE: Samsung hl61750a - unable to display video service over hdmi
restart the att cable box by unplugging the power cord.
Posted on Jul 02, 2010
Sharp TV problem LC-40E77UN Sharp Blu Ray
PLEASE place your question in the appropriate forum/section under TELEVISIONS, because this is the VACUUM section. That way, someone knowledgeable about your problem can help you.
Oct 19, 2013 | Televison & Video
I have a Samsung C230 LED monitor and I'm wondering if I can use it with a Roku XD/S in place of a TV via the hdmi cable?
as far as i can tell this monitor is not HDCP compliant ( High Def Copy Protection ) and therefore will not be suitable as a TV monitor. Computers can use non HDCP compliant monitors but TV Tuners, Satellite Receivers, DVD players etc with HDMI are HDCP compliant and must have a HDCP display... HDMI has two formats basically HDCP and non HDCP
Sep 04, 2013 | Samsung Syncmaster 940BW LCD Monitor
Will not play movie - continually displays "Copyrighted Movie HDMI HDCP frail with TV "
There are several reasons for this but exactly knowing which is one isn't possible without first knowing what products you are using such as your connector, player and television.
HDCP is the acronym for high definition content protection. It is a digital signature embedded into the disc software designed to prevent copying of the disc. On certain occasions due to the hardware such as the HDMI port on the television, or the connection type, the signal will not be allowed to pass through. The HDMI port on the television may not be HDCP compliant for example. In this case if possible you can try a different HDMI input on the TV if available or use the component video input instead.
Jan 09, 2010 | LG DR787T DVD Recorder
How do I get rid of error message across top of TV that reads "Your television cannot support HDCP video over your high definition connection (H1001)".
Use component cables instead of hdmi cables. I know this isn't the best solution, but HDCP is not used over component and the video quality is just about as good.
Jun 04, 2009 | Westinghouse SK-26H240S Television
I was using an hdmi cable purchased online. A friend told me that it might be the 'cheap' hdmi cable. I tried a set of Monster hdmi cables and problem solved. So all hdmi cables are not the same.
Jan 29, 2009 | Samsung HLN5065W 50" Rear Projection...
Pioneer VSX-818V-k wont work with PS3 or AT&T U-Verse
That model does not support audio via hdmi. That is the problem.
Jan 04, 2009 | Pioneer VSX-818V-K Receiver
Dvi input for watching tv
the DVI input must be HDCP compatible in order for HDMI to work. It's a DRM encryption protocol. Condolences. Blame hollywood for it. The monitor model is too old to have had HDCP support built in to the DVI input.
Jul 30, 2008 | Dell W3000 30 in. HD-Ready LCD Television
Philips 32' lcd hdtv
are you using a DVI to HDMI converter? Radeon cards older than x1*** series or roundabout didnt support hdcp on dvi which is required to run Hi-Def rez thru an HDMI cable on most TVs. A video card with hdmi prebuilt in or HDCP compliance listed on the box should be able to handle it. And you should find a resolution both your normal monitor and HDTV can handle to set the coimputer to before you switch it over to the HDTV to be sure it will still show you picture. If you arent using 1080P you might as well use a component input which doesnt require HDCP.
Oct 12, 2006 | Philips 32PF9966 32 in. HD-Ready LCD...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
570 people viewed this question
Henry  Thomas
Henry Thomas
