Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Paper jam I have a paper jam. How to work on getting it out. Can't get my hands in to pull out jammed paper, when I do it is so jammed it tears. Help I can't use it for anything right now. Tied us up right in the middle of an improtant project, scanning, faxing everything. Help Please
  • 34 Answers
Open the front and rear access door and try to pull the paper gently you can also unplug and replug your print so it would spit out the paper.
Posted on May 29, 2008
How do i clear paper jam after tearing half of the paper leaving other piece locked inside machine?
IF the jammed paper tears and you cannot remove the paper either from the paper output slot or from the transport unit, or the jammed paper remains inside the machine, remove the paper following the procedure below. 1. Turn off the machine, and unplug the power cord of the machine from the power supply. 2. Open the paper output cover. Remove the paper on the front tray if any.
Important:
    Do not touch the clear film (A). If the paper or your hands touch these parts and blot or scratch them, the machine can be damaged.
3. Make sure that the FINE cartridge holder does not hang over the paper. If the FINE cartridge holder hangs over the paper, move the FINE cartridge holder to the right edge or the left edge whichever is easier to remove the paper. When you move the FINE cartridge holder, hold the FINE cartridge holder and slide it slowly to the right edge or the left edge.
4. Hold the jammed paper with your hands.
If the edge of paper is jammed near the paper output slot, pull the edge of paper to the position where you can hold it with your hands.
5. Pull the paper slowly not to tear it, then pull the paper out.
6. Make sure that all the jammed paper is removed. If the paper is torn, a piece of paper may remain inside the machine. Check the following and remove the piece of paper if it remains.
7. Close the paper output cover, then reload the paper.
All print jobs in the queue are canceled. Reprint if necessary.
Jul 20, 2014 | Canon Pixma Mx432 Wireless Inkjet Office...
Tip
Paper jam
Start by following the steps below to get the paper out from the machine.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Advanced
If that doesn't help then you would have to start taking apart the machine to find the jammed paper and remove it, its not something a just anyone should do unless you have experience.
you may have to take the machine to a repairer to get the jammed paper bits out of the machine, if you don't see paper jammed in the machine it does not mean that there wouldn't be a paper jam somewhere in the unit along the paper path.
on Jun 03, 2009 | Brother HL-2070N Printer
There is still error 2 even after restart the printer (canon mp145). How to reset this error?
(remember to vote this solution plz)
I use a Canon MP210 myself, its a Pixma like yours. Anyways, Error 002 or 02 means theres a paper jam. Sro if you can fix that jam it will go away. If your looking at the printer and you cant see any jams still, the printer still thinks it is jammed, so heres what I would do.
  • Turn off the printer.
  • 3
  • 4
  • 5
    If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
  • 6
    If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  • 7
    If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
  • 8
  • 9
  • Still? Take a cereal box of cardboard (cut the back/front , push that through the paper trayand get your hand on the other side and work it like your flossing your teeth)
    Yes that works.
    Thanks
    Rhos Barnes, MCSE, CCNA
    Squamish, BC
    rhos_2k@yahoo.com
    Jan 23, 2011 | Office Equipment & Supplies
    Printer will not work after paper jam fixed
    alternative :
    Jul 09, 2009 | Canon iP4500 Photo Printer
    Paper jam: cannot reach the paper, how do I get
    This video was created for the C7280, but works the same for your printer.
    Jun 10, 2009 | HP Photosmart C5180 All-In-One InkJet...
    Canon MP600 paper jam
    alternative :
    May 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
    E-04 Clear Paper Jam, no paper in printer
    alternative :
    May 15, 2009 | Epson Stylus CX7800 Color Flatbed...
    Misfeeds paper pulls to the right--says paper jam-no jam
    there could be a paper jam or some paper still inside.
    alternative :
    Mar 17, 2009 | Lexmark X3350 All-In-One InkJet Printer
    Paper jam paper jam error message continues even no jam, have to feed by hand sever times before paper will feed into printer.
    try this
    alternative :
    Dec 23, 2008 | Canon Pixma MP450 All-In-One InkJet...
    Jam
    alternative :
    Oct 28, 2008 | HP 920 Plain Paper Fax
    Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
    123 people viewed this question
    Top Kodak Office Equipment & Supplies Experts
    Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
