Question about Kenmore Kitchen Ranges
I have a Kenmore Stove and the bottom (bake) element does not heat up. The top Element is fine. I have replaced the bottom element and checked the fuses and they seem fine. Could it be a control panel that is faulty?
  • 7 more comments
  • chrish25 Jun 03, 2008
    The oven is a Kenmore model # C970-65223. Is this a common issue with these appliances? Is it a do-it-yourselfer project to replace the part? if so, where is a good place to locate the part? Sears?
    Correction, model# C970-652231
  • chrish25 Jun 08, 2008
    The model # seems to be correct (see photo) The only other number I can find is the Sears # 223 665 223 and it seems they do not have info on this model. It was purchased in 2001. Some photos of the stove, model# sticker and controls:
  • chrish25 Jun 09, 2008
    Thanks. I will look into that. I appreciate all your help, you have definitely pointed me in the right direction. I will try to let you know how I make out.
  • chrish25 Jun 14, 2008
    I was able to get and install a replacement part for Electronic Oven Control (EOC) and it was a quick/easy change as you mentioned. The part came with the overlay pad which was nice. Unfortunately it seems that is NOT the problem because there is still no heat on the bottom (bake element). Any other suggestions??? I have read/heard that the thermostat could be the problem, but I question it because the oven will heat to the desired temperature (with only the one element heating) and continue to regulate that temperature.
    Just for fun I set the stove to broil and to my surprise the bottom element is glowing red hot! At least I know there is power getting to both elements and the new element actually heats. The top element heats in BAKE mode... (sounds backward to me???) I can't recall if I tried broil with the old EOC, and now I'm not sure if I am any closer to a solution with the replacement EOC. Does any of this get us closer to the solution? Are there other test I should do? Could I have crossed wires???
  • chrish25 Jun 26, 2008
    Thanks again jsrock. I double checked the wires and even switched them
    to see if it would make a difference and had the same results. I used
    the photo to make sure it was the exact same connection. I also
    re-installed the old EOC to see if the elements would heat up on broil
    and the bottom (bake) element did heat up (only on broil). It seems the
    problem must be elsewhere? Could there be a thermostat, wire or sensor
    that is faulty? Do you have any other suggestions. Is it time I make a
    service/repair call? New stove?
    I am extremely thankful for your help!!! You have been awesome (and more important, very patient and prompt) THE STOVE WORKS!!! I'm almost embarrassed to post this...You are likely going to laugh at the final solution and might even question whether you want to rethink insulting my intelligence :D As it turns out (after checking the wires again and still being puzzled) I realized all the settings on the oven dial were giving opposite results... This was apparent when I noticed the "bake time" setting seemed to turn the oven OFF! Hence, Broil was Bake and Bake-Time was OFF. So you likely see where I am heading with this... It turns out someone must have put the knob to the oven dial on upside down. Geesh and I was so close to buying a brand new stove or paying hundreds in service costs. Please feel free to add this to your list of "lame ducks." I know I am going to have a few good laughs at my own expense. I'd rather that than the hundreds of $$ it could have cost me. "Sometimes it is the simplest things that are the hardest to find." Once again thank you so much for all you help and time.
  • Anonymous Mar 25, 2014
    element heat control malfunctioning and stay on 'highh'
  • 5,911 Answers
You could very well have an Electronic Oven Control (EOC) board problem. There two separate circuits that control the oven BAKE and BROIL functions. If you have replaced the BAKE element, and have ensured it connected properly, the only other component that controls that function, is the EOC. If you post back with your complete model number, I can double check to make sure. The model number will be located on a nameplate somewhere around the oven door opening or lower drawer opening. The reason I need to confirm is because some ranges have a separate relay control board.
Posted on May 28, 2008
  • 4 more comments
  • Jeff Rockwell
    Jeff Rockwell Jun 03, 2008
    Are you sure the model number is correct? I cannot find a cross reference for the number you provided. Double check the nameplate data (located around the oven door, or lower drawer opening) to be sure.
    To answer your question...Yes, this is a pretty straight forward repair that anyone can do. This will save you in having to pay for labor charges. The EOC is usually held in place by a few mounting screws. You will need to remove the rear panel of the range to access it. Make sure you UNPLUG the range before attempting any repairs inside the control panel. The wiring is normally printed on the circuit car, but sometimes it is not. Make sure you mark all wires and where they go, to make reinstalling easier. If the EOC does not come with a new overlay (number/dispay pad) you will need to carefully peel the old one off the failed circuit card and install it on the new one. They can be reused.
    Searspartsdirect.com is great place to start in locating your part. Just type in your model number and follow the prompts on the next page. There are helpful part locator drawings to assist you as well. Repairclinic.com is another site I have used and have been pleased with their service. The two sites have competitive pricing, so it may help you to look at both of them for the best price.
    Double check that model number, though. Let me know if you need further advice.
  • Jeff Rockwell
    Jeff Rockwell Jun 09, 2008
    Do you live in Canada? Your range was manufactured by Kelvinator of Canada. That's why I'm having a hard time locating parts information for it. I found a Sears parts inquiry for Canada, but unfortunately, it requires you to fill out a form and post an inquiry instead of allowing you to browse their parts index.
    http://www5.sears.ca/e/hc/partsinquiry.s...
    There is the toll free number posted on the site that you can also call to see if they can lead you in the right direction. My apologies for not being able to offer you better guidance. I'm having difficulty tracking this model number. I tried nearly a dozen different appliance parts websites with no luck. The best advice I can give you is to try the Sears Canada website I linked you to, or call the toll free number to see if they can offer you a cross reference part number for your range.
  • Jeff Rockwell
    Jeff Rockwell Jun 16, 2008
    It sounds like you have your BAKE and BROIL wires crossed chrish. Turn off the power and look at the wires on the EOC. They should be marked for BAKE and BROIL on the card. It should be a simple process of swapping the wires on the terminals on the card.
  • Jeff Rockwell
    Jeff Rockwell Jun 26, 2008
    A thermostat usually causes oven heating problems or temperature regulation issues. I doubt it would cause the symptoms you've described. It doesn't make sense to me that you have BOTH elements working, but with the wrong controls with the new EOC. When you switch the leads, the symptoms DON'T change? Am I getting that right? I just don't see how that is possible. It still sounds like you have some wires crossed somewhere. When you re-installed the old EOC, your original symptoms came back. There's something going on with the control circuits if you can get the symptoms to change like that. Are the boards configured the same? Did you trace the wire leads from the elements to the board to ensure they are connected where they are supposed to be? I'm not trying to insult your intelligence. I just want you to be sure. I admire your diligence in staying with this problem, but I'm sorry I haven't been able to get you past this point.
  • Jeff Rockwell
    Nope...I don't have a list of "lame ducks". I've learned not to insult individuals that try, because I'm guilty of some real knuckle head moments myself (not referring to YOU as a knuckle head). I'm glad you stayed with it and managed to figure this out on your own. Even though it may have caused you a little embarrassment, you still managed to save yourself a hefty service call. You would have really hated yourself had the repairman showed and fixed a simple problem you inadvertently caused, then promptly charged you a whopping repair bill. You did an excellent job, by my book. Good Job!
  • Jeff Rockwell
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchenaid superba stove baking element does not heat
There has to be a baking element. Find it and replace it.
Aug 19, 2017 | KitchenAid Kitchen Aid Superba Series...
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Jan 30, 2014 | Kenmore Ovens
The oven, which is mounted on the wall next the the stove, doesn't get hot. I had an elecrician in and he said it wasn't the heating element. In fact he said the heating element for the broiler is working...
1. There are 2 elements, bottom one is the bake-element, top is the broil. Does the bake element glow when it cycles on?
2. The temperature sensor could be faulty.
3. The control board may have failed. We see this symptom frequently due to a control board problem. We repair these at www.fixyourboard.com
Oct 08, 2009 | Kenmore Ovens
Stove top burners and lower baking element not heating up
If all the elements are dead, check for blown fuses/tripped circuit breakers. There may be some in the range unit itself in addition to your electrical service panel. If one element is completely dead on all heat settings, the control is probably bad or there is a broken wire. If it is stuck on high for all control settings or is erratic, the control is bad - replacements are readily available and easily installed.
On ranges with push button heat selection, a pair of heating elements are switched in various combinations across 120 and/or 240. If some heat settings do not work, the most likely cause is that one of the heatings elements is burnt out although a bad switch is also possible. Kill power to the range and test the heating elements for continuity with resistance meter or multimeter.
For the lower baking element:
Again, check for blown fuses in the oven or tripped circuit breakers. The remove any wiring to the bottom element and test for resistance. If you get no reading (or a very high resistance) then your element is dead.
May 09, 2009 | Kitchen Ranges
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven heat
There is a bottom hidden element that is the main element used for baking and cleaning. If its not heating then the element has gone bad and needs replacing. If you have a volt meter then you can confirm this by checking the voltage between the two terminals sticking out of the rear of the range. There should be 240vac across the two. If you have that then you need a new element if you don't then you need a new control board.
Nov 03, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
Kitchen Ranges Logo
1,970 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
