Question about Garden
ENGINE VH4D CHARGING SYSTEM NOT WORKING - Garden
I need the torque specs on a Wisconsin vh4d rods and head bolts
The Info You Are Requesting Can Be Found Right Here On This Site Posted By YADAYADA Do A Search And You Will See The Post !!
Aug 25, 2017 | Cars & Trucks
2012 Grand Caravan. How do I turn the battery light off after installing a new battery?
Test the alternator. The battery light is for the charging system. Once the charging system is working with the engine running, the light should go off. If your light stays on with engine running, the alternator may need service or replacement.
To test the charging system, just put a voltmeter on the battery with engine running. The voltmeter should register at least 13.5 volts- alternator is charging. If you only show battery voltage with engine running, like 12.2-12.8 volts, the alternator or charging system is not working. The battery light should be on to signify this.
Jun 17, 2015 | 2012 Dodge Grand Caravan
How to fix voltage regulator
The regulator is inside the alternator. Get a new alternator or disassemble the alternator and install a new one. My option is get another alternator.
Feb 08, 2015 | 1995 Isuzu Rodeo
Got a m610 with vh4d wisconsin had fire at plug and it just vanished no spark at coil but have power to coil
Check wires. You have a short circuit. May need a new set of spark plug wires to include ignition wire.
Jan 04, 2015 | Cars & Trucks
How does the charging system on a 1969 Honda 325 cc motorcycle work to keep engine running?
I think you mean a 69 CB350. It sounds like you have a bad battery since the battery charger won't charge it.
On this bike there is an alternator and rectifier that combine to charge the battery whenever the engine runs. If the battery won't hold a charge, the charging system wont work.
Replace the battery.
Sep 26, 2014 | Motorcycles
I have no power charged battery was ok before now no power check the fuses there ok can you tell me why i have no power please
it seems that the battery is not charged or not connected. When you open any door the light inside must turn on. When not, the battery is not charged. Charge the battery and try again.
When the battery goes again out of the power, it indicate that the charging system or alternator are not working properly.
Start your vehicle turn the headlamps on and check the voltage on battery. It must be higher than the voltage when engine is off.
If the voltage with engine on is about 14,5 V charging and alternator are ok. Maybe the battery is dead.
When the voltage with engine on is higher than with engine off but not 14,5 V, there is problem with charging system. When the volage is the same, it can be alternator or charging system.
Oct 20, 2013 | 1990 kawasaki ZZR 1100
I have a Troy-built gtx2654 lawnmower with a Birggs & Stratton engine mod 47777 typ.0229E1 want to troubleshoot charging sys.
You can test the charging system by starting the mower and then unhooking the negative terminal from the batter, if the mower stays running, the charging system is working, if it dies immediately the charging system is faulty, you can also use a tester at the engine to test the voltage at the connectors
Oct 12, 2013 | Briggs & Stratton Briggs Stratton...
I drive a 93 GMC Sonoma p/u. I drove out of town and noticed that the radio was not working. Next the service engine soon idiot light lit up. Once on the highway, the spedometer was not working. Hmmmm
It is possible that there may be a battery/charging system problem (in which case, the next step will be that the engine will not run). Then again, you may have separate problems. The radio not working and the Check Engine light turning on might not be related at all. However, a failed Vehicle Speed Sensor (VSS) or open/shorted VSS circuit would make the speedometer quit working AND cause the Check Engine light to come on.
Proper diagnosis is the only way to find out for sure.
I would BEGIN by performing a thorough battery/charging system test. Then you need to scan your onboard computer to find out WHY it has turned the Check Engine light on. This should be done BEFORE the battery cables are disconnected for any kind of charging system or battery repair. Once the cables are disconnected, the computer memory will be lost and you will not get any codes to tell you why the computer has turned the light on. You MAY have a charging system-related code like "Voltage Low At Module" or you MAY have a totally different code like "VSS Circuit Open or Shorted". You need to find this out before making ANY repairs.
However, if the charging system tests faulty and/or you have any charging system fault codes, ALL fault codes should be recorded and the battery/charging system problem needs to be dealt with FIRST. (you cannot trust what the computer is telling you if there are charging system faults.) If after this, any symptoms persist, diagnosis of any other fault codes retrieved should be performed.
If all engine control problems are resolved and your radio still does not work, you need to diagnose your radio circuits as a separate problem.
Jan 02, 2012 | Cars & Trucks
Charging system woes continued...
then you have a problem in the dashboard could be the circuit board behind the dash if you would like to i will tell you how to eliminate the dash from the charging system or install a straight wire from the ignition power to the ignition side of the alternator bulb,
but if you still want me to tell you how to elimiated the dash from chargin system let me know
of course this will be a mikey mouse but will take care of your problem.
Jun 02, 2008 | 1993 Ford Ranger SuperCab
Garden Logo
79 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
