Question about Frigidaire FER311FS Electric Dryer
Top and back get too hot , clothes won't dry - Frigidaire FER311FS Electric Dryer
    President:
  • 1,430 Answers
First check the venting for clogs, both inside the machine and out. Here is a link that should help
Professionally cleaning a dryer
While your in there check the blower wheel. Make sure it is spinning and tight. Here is a link that should help http://appliancehelponline.com/dryernoisyge.html
Posted on Oct 05, 2010
Maytag model #: med5770tq0 won't dry. Please help
Dear Emily.
Several problems.
First, did this dryer ever work properly hooked up as it is?
I mean hooked to the roof event?
If it used to work just fine, then I suspect the vent to the roof is clogged with lint and is not allowing the heat to escape.
If it never did work right,(for example: it is new to us) then I'd venture dryers are not supposed to vent their hot air that far away, they do not have a strong enough blower to push that air that distance.
Then, you might try to find another place to vent the hot air, with a total distance of only 10 feet from the dryer, even if you only vented it while you were actually drying clothers.
I doubt if the last item is for you, but I have sometimes seen where the washing machine did not spin all the water out of the clothes, and then the dryer needed all day to get the clothes dry.
Be blessed.
Apr 17, 2013 | Maytag Dryers
Hot Point Dryer won't dry, gets hot on top.
An educated guess would be either the lint tube or the tube that exhausts the air outside is blocked with lint----no airflow or greatly reduced flow will cause this symptom.
Nov 06, 2012 | Hotpoint Dryers
My cloth dryer won't dry. It is not hot.
is it gas or electric, vent could be clogged. could need starting device. solonoid, or ignitor.
May 20, 2012 | Whirlpool Dryers
Does not dry cloths. dryer gets hot,top and sides during drying cycle. it takes 2-3hrs to get cloths dry.
most probable cause of heating yet not drying in a crushed or restricted vent (imagine only inhaling while breathing yet not never exhaling)
Jul 22, 2011 | Kenmore Washing Machines
WON'T DRY CLOTHS..NO HOT AIR
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'';';
Jun 27, 2011 | GE Dryers
Dryer is hot on tpo
You should check to make sure you don't have a kinked or obstructed exaust line . The exaust is what allows the air from the clothes to escape as well as moisture and heat and is very important for efficient drying.
Jul 24, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Back & top of dryer get hot, clothes take long time to dry.
First thing to check for is blocked airflow. Check the dryer as well as the venting from the back of the dryer to the outside of the house good airflow is neccessary. You could remove the venting from the back of the dryer and run a load to see if that helps. Do not leave it off as it is exhausting lint and if a gas dryer spent fuel.
Jan 08, 2009 | Maytag MDE2600 Electric Dryer
Heating, draining water(enough?) but not drying clothes, they're just HOT, so is top of machine
You have a problem with the condensing duct.  Possibly clogged with excess and lint and needs to be cleaned out.  This requires disassembly of the unit to get to it.  Not a difficult job but not easy.
Oct 22, 2006 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Frigidaire FER311FS Electric Dryer Logo
62 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
