Question about Philips 42PFL5332D 42 in. LCD Television
Just recently I have been getting the rumored shadows on my tv. I have DIRECTV and some channels leave that shadow effect when I change the channel. Sometimes it takes a while for it to go away. I also have noticed that going vertically that the screen has a somewhat permanent shadow along the whole screen. This tv is only 3 years old. What is the best possible solution to fix this. And I do have the HDMI cables hooked up.
  • Scott Frye
    Scott Frye Oct 05, 2010
    Does the shadowing take place when watching a DVD?
  • sjthpotas622 Oct 06, 2010
    yes it does.
    Genius:
  • 1,175 Answers
That will require some service. My opinion?...A power supply voltage not up to spec. Check the web for service people near you
Posted on Oct 06, 2010
How do i fix the shadow on my Samsung TV?
Well, it has a bad T-con board. You'll have to pay for the part, but you can fix it yourself. The board can be replaced easily. The T-Con board is usually near the center of the screen when you have the back removed. Just look at the ***** holes with arrows pointing to them and take out only those screws. Once the back is off, you'll see a board under a metal cover(not always) The board has flat wide ribbon cables that go to the bottom of the screen. Get the numbers off the board and go here for parts: TV Parts Universal TV Stands DLP Chips ShopJimmy
Mar 18, 2016 | Samsung LN32A330 32 in. LCD TV
Toshiba 46XV645U Shadow Effect Problem
thats usually caused by a flex tab bond on the panel itself especially if the screen appears slow motion in that area.
Aug 07, 2012 | Toshiba 46XV645U LCD TV
My RCA Scenium looks like there is a shadow of another channel on the screen
I am scraping out my tv all boards are good the tv played great just wanted a wall hanger if you need a part call me 270 589 8074
Aug 03, 2012 | RCA HDLP50W151 50" Rear Projection HDTV
Shadows in display
what Digital reciever do you have? try to push the cart cable or the other cables a bit stronger in av outputs. it helped me.
Apr 07, 2010 | Vizio L37 Television
We have DirecTV and is is on channel 4. My
Use the tv remote to put the tv on ch 4. Use the direct tv then to select channel of the direct tv box. The box is broadcasting to the tv on ch 4. Also check that tv is on correct input . Again use the Panasonic remote to select correct input. If this does not work call direct tv for assistance.
Dec 03, 2009 | Panasonic TC-32LX60 32 in. LCD Television
Letters blurr in spots and black boxes leave a shadow on the screen
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Nov 23, 2009 | Acer P221W LCD Monitor
I tried to program my remote control to power my sharp tv and it will now turn the tv on and off but I cannot get any directv channels and the screen is fuzzy.
PUT THE DIRECTV REMOTE BACK INTO THE TV MODE TURN THE TV TO CHANNEL 4 OR 4 THEN PUT REMOTE ON DIRECTV TO CHANGE CHANNEL ENJOY
Aug 24, 2009 | Directv RC-64 Remote Control
How to hook my directv to digital input to lcd tv j32l637
I don't know what flat screen tv you have,but you must be aware of the coaxial input behind the TV.It could be analog input,digital input and OUTPUT!!
Anyway,if you connect your basic directv box to your digital input,it will not serve you any purpose to get HD channels and you don't have the HD directv box.The TV will not display digital channel for you because if you use coaxial input to TV,you should be under either channel 3 or 4 and be sure either channel had been saved under memory.In order to change channels,you will need to change it from your directv box.
JUST LIKE a VCR connect to TV.TV will be under channel 3 or 4,and you will change your channels from the VCR.Don't forget to scan all the channels from the VCR!
solutiondoct
Nov 11, 2008 | Televison & Video
Not able to scan stations
I don't understand why you would bother to scan channel when you have directv or dishnetwork???
directv or Dishnetwork required their units in order to watch any channel,which means:
A. Depending on your TV setting,if you use RF connection from your basic directv to the tv,you would have to leave the TV on Ch.3 or Ch.4.to view the rest of the channels,you have to change it from the directv or dishnetwork box. You are NOT able to scan the rest of the channels from the TV,bottom line!!
If you have comcast or your local cable provider,once you have activated,you could use the RF signal coming out from the wall plate straight to the tv and go to TV auto programming,it will auto scan the available channels for you.
Don't waste your time on directv.
If you are thinking about recording from your BASIC directv or dishnetwork box, you would connect SAT. signal from the wall plate to the directv box,then use composite video/audio output and connect straight to your VCR/DVD player under composite video/audio input. Now you could record the viewing channel to the VHS.
Aug 19, 2007 | RCA DRC8335
Philips 42PFL5332D 42 in. LCD Television Logo
205 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
