It wont turn on.no click sound or anything when i push the power button
  • 901 Answers
Check whether the power is reaching the TV. Check fuse inside the TV.
Then check the SMPS, +dc power.
Posted on Oct 05, 2010
Yamaha 6130 receiver wont turn on
Could be an open internal fuse or power supply failure
Apr 11, 2018 | Yamaha Televison & Video
Car wont crank or do anything no clicking or noise when key is turned sems like alarm is engaged
look around under the dash area etc there should be a red or black push button. This is called the valet button. If you find this button turn the key to the on position and hold the button in the alarm should beep twice I believe and this turns the alarm off.
Nov 29, 2013 | 1995 Nissan Pathfinder
Wont start makes clicking noise
Sounds like you need professional service from your local Apple store. There is a click maker inside them which you can disable. Why yours is clicking on its own is because there is a fault.
Try a Soft Reset. Hold the Play Button and the Centre Button
ipod touch just makes clicking noise Google Search
Dec 13, 2017 | Apple Ipod Touch 1st Generation 16 Gb Very...
Rear hatch wont open, with push button,or remote on my 2007 D0dge Durago
It sounds like a relay or interlock is bad. Get close to the hatch and listen for a click sound while pushing the remote button. If you don't hear anything, it will be the relay under the dash or the wire has disconnected from the interlock.
May 06, 2012 | 2007 Dodge Durango
The lights come on fine but when i push the start button in just clicks very softly. engine wont turn over at all...
Find the starter solenoid and short across the two terminals, if the starter works you have a bad solenoid. If you hold the starter button and tap the starter with a plastic hammer and the starter works, you need new starter brushes. If anything else is wrong with the starter you need to buy a new starter no new parts are available.
Sep 18, 2010 | 2006 Yamaha V Star 1100 Custom
I have a sharp-aquos flat screen tv model#LC-37GB5U and my problem is it turns itself off and then wont come back on.yesterday it worked perfectly,today it wont even turn on.when i push the power button...
Power supply board it dead.Replaced the power supply board should solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board. .
Jan 20, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I was running updates with my phone connected to itunes on my computer, power went out during the middle of syncing. now it wont turn on. i hold both buttons and the apple icon appears for about 5 seconds...
Open up itunes first.
You need to restore iphone in DFU mode.
Restart computer and use a different USB cable if possible.
Hold power button 10 seconds, don't let go, now push in home button 6 seconds.
Now release only the power button.
Keep holding 'home' button until itunes sees it and allows you to restore.
click restore.
If this still does not work then do all of this on a different computer.
Dec 21, 2009 | Apple iPhone Smartphone
Getting power but wont boot up or anything
pull out everything in the computer except what's required to boot...so any pci cards or video cards (if you have onboard video). you can also try pulling out the ram (while unpowered AND unplugged) and then booting to hear beeps...if you pull the ram out and the computer doesnt make a sound, its probably a bad motherboard and needs to be replaced. if you hear beeps, try replacing the ram or disconnecting other parts...like harddrives, optical drives, modems and what not.
Apr 26, 2009 | E-Machines T2792 PC Desktop
OLDER 32" TV WON'T TURN ON/KEEPS TURNING OFF
re solder your tv,if its not works, check the horizontal output transistor
Oct 01, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
Top Televison & Video Experts
