Question about Whirlpool Duet GHW9150P Front Load Washer
In the middle of a load my washer will stop and starts flashing F23? It is a whirlpool duet steam.
  • 2,382 Answers
Hi, F23 means that there is a fault in the heating circuit and the heater is not working This fault is triggered if the water fails to rise by 30C or 86F in the first 8 minutes of the heating process.
1. Unplug washer or disconnect power.
2. Check the connections to water heater.
3. Check resistance and continuity of the heating element.
4. Check the water temperature sensor and connections to it.
5. Check the water temperature sensor and connection to it.
Posted on Oct 05, 2010
  • Mike9s Feb 03, 2011
    I fixed my F23 error code. Seems F23 is not just for the heater or the flooded pan. I opened the bottom front and there is a large knob that opens a drain pump trap. After cracking open the trap slightly and manually draining the soapy water I found a dime and a plastic floss tooth pick. The controller recognized that the pump had an over current condition or simply could not completely drain the water. After removing the items and replacing the pump trap the unit powered up and shut off properly. So I successfully ran a wash cycle with no detergent and finally a normal complete cycle. You must take out 3 T20 torx head screws to remove the front bottom door and expose the trap. No tools are required to unscrew the trap. Best of luck.
Can you stack this washer and dryer?
You can stack, will you be able to reach. Racks can be made to stack any normal washer and dryer.
Mar 14, 2016 | Whirlpool WFW9750WW Duet Steam Front Load...
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
What is a flashing F23 Error
blank.gif F23 Pressure switch failure Should the main electronic control unit detect that the wash level contact (or level) is on and the switch level for wash heater safety is off for any more than ten seconds during a wash this error code will be displayed.
Resetting the program may clear this error but unlikely.
  • Check the pressure switch or sensor for operation and electrically
  • Check the wiring from the main electronic control card to the level sensor
  • Check all connectors between the main controller and pressure switch
  • Run test program
  • Also see F08 and F12 as heater failure can cause this error to occur
Nov 12, 2014 | Whirlpool Duet Steam WFW9700V Front Load...
Whirlpool duet wfw9640xw00 won't turn on
my whirlpool aquasetam washer get fault code f23?
Apr 01, 2012 | Whirlpool Duet GHW9150P Front Load Washer
F35 code
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35 on my washer
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE F71
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
NOTE: If the error remains on the display, then call for service.
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Jul 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Have just got new whirlpool aqua steam washing machine and it keeps stopping with the code f 23
F23 codes indicates an electronics communication problem with the washerThe following list of codes indicates an electronics communication problem with the washer. To remove the error display, press Pause/Cancel twice.
Jul 18, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
831 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
