Question about Kitchen Ranges
No tengo el manual de la estufa MAGIC CHEF Serial 24316793 OD Model 3468 VVV, y no se como utilizar el Horno
SOURCE: codigo de seguridad para ingreso y su funcion
puedo desbloquear una radio kdc-mp522 sin el control remoto
Posted on May 02, 2009
  • 10865 Answers
SOURCE: REAR RIGHT AND LEFT FRONTBURNER WON'T IGNITE
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
Posted on May 12, 2009
SOURCE: falta instalar " la controladora simple de comunicaciones PCI"
Fijate en esta página que tenes los drivers de las PCCHIPS viejitas. Tenés además, que controlar que el jumper JP3 que habilita la placa de red.
Jumper JP3: Enable/Disable Onboard LAN Use this 3-pin jumper to enable or disable the onboard network adapter.
Function
Jumper Setting
Enable Onboard LAN
Short Pins 1-2
Disable Onboard LAN
Short Pins 2-3
SUERTE!!!!
Posted on Aug 09, 2009
ginko
  • 19396 Answers
SOURCE: se activo alarama dogde grand caravan 98 3.3l y no tengo control
Hola estoy intentando siguir su problema. esta es hora punta y tenemos muchas preguntas.
Asegurarse que no hay otra alarma que no es de fabrica. En este caso deberia de haber otro modulo de control de alarma. Alarmas no de fabrica suelen tener un boton de deactivaccion (Valet Key) debajo de la console de instrumentos.
Si el pin 34 esta libre, el alarma deberia ser inactivo. Probabilmente se activo' cuando hizo los trabajos en el coche.
Uno de los pins connectados al ~BCM es el alarma.
La unica manera de deactivar este alarma es enviar un impulso al pin del alarma, descargandolo a terra.
Hay que poner una resistencia de 9KOhm en el medio , de otra forma el alarma no se deactiva.
Aqui la esplicaccion:
"Factory Alarm Disarm Wire (-): This vehicle will disarm with (-) negative through a 9000 ohm resistor, must use single pulse to disarm and a double pulse on this wire will also unlock.
Factory Alarm Disarm Wire Location: N/A"
La esplicacion termina con "Factory Alarm Disarm Wire Location: N/A", sin decir qual pin es el alarma.
yo se de otras fuentes que deveria de ser el pin 34. Por esperiencia personal puedo decir que el connector deveria de estar conectado all bloque de aranque.
El hilo deve de ser blanco y rojo o bien violeto y azul.
Si no se pone una resistencia de 9Kohms en el pin apropiado, el alarma no se quita.
No hay otra manera.
Posted on Nov 06, 2009
  • 171 Answers
SOURCE: tengo un problema seme rompio el control de la
Aqui esta el manual para programar copie esta direcion y entre en el internet.
http://audiovox2.info/docs/voxx_mob/man/APS997A_DOC_TPG.PDF
Posted on Feb 09, 2010
Style Pro 602 y no puedo prender el horno
Que es eso? No encuentro Style Pro 602. Es estufa? Con horno? gas? electrico? Si es horno electrico, busca el fusible o "breaker" que pertenece al horno, mas probable en la caja de fusibles afuera de la casa. Quiza es doble fusible. Apaguelo bien, y despues re-prendelo.
Si no, puede que es falla del alambre de conneccion, o del control, or del elemento de califaccion mismo..
Jan 01, 2018 | Cars & Trucks
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
TENGO PROBLEMAS CON LOS VIDRIOS ELECTRICOS EL DEL LADO DEL COPILOTO SE PONE LENTO Y SE DETIENE COMO SI SE CORTARA LA CORRIENTE Y DESPUES DE UN RATO VUELVE A FUNCIONAR COMO SI SE RECARGARA
Puede k sean las conecciones de los controles de la puerta. Asegurate k esten bien connectados. Para eso vas a tener que quitar el panel de la puerta y chekarlos, tambien el del motor de la ventana. Eso hacen cuando estan haciendo falso contacto.
May 04, 2010 | 1994 GMC Safari
Tengo una Dogde Grand Caravan 98 3.3L, y al Efectuar un scaneo se activo la alarma de fabrica el carro y ahora no me da encendido, como lo desactivo para poder arrancarla. Me pueden ayudar. Chaves, Juan
Hola trata esto, Sientate y abrocha el cinturon,espera 10 sugundos y gira la llave de lock a on (no lo arranques) has esto 4 veces terminando en lock preciona el segura de la puerta a lock .Escucharas un silvido. Ahora abre la puerta lateral sin usar el control 2 o3 veces. Ahora trata de ponerla en marcha suerte.
Nov 06, 2009 | 1998 Dodge Grand Caravan
Que significa cuando enciende la luz OD/OFF es un sensor o es problema de trasmicion
es posible que es una problema de transmicion. es posible que es el interruptor de OD/OFF tambien. si Ud empuje el boton y la luz no se apgaue pero no aye otros problemas, creo que es probablament el interruptor.
Oct 09, 2009 | 1999 Ford Expedition
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
Se quiebra mucho la aguja y la puntada esta floja
Vaya a Singer.com seleccionan su país. Bajo búsqueda barre donde dice que “estoy mirando para: ” Chasque encendido eso y selecciónelo de los manuales de instrucción del menú de la gota abajo. En la barra de la búsqueda mecanografíe adentro 3116. No mecanografíe adentro apenas 3116 simples. Le llevará a la transferencia directa que usted necesita. La transferencia directa está libre. Estoy utilizando Microsoft Word para traducir esto así que espero que usted pueda leerlo. No soy realmente seguro como de bien es la traducción en esta cosa. La esperanza I ha estado de una cierta ayuda.
Nov 15, 2008 | Singer 3116 Simple
Kitchen Ranges Logo
104 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
