Question about Sport & Outdoor - Others
1995 tigershark water craft suzuki powered model ARJO5234 A595 engine06201J 554794 PJ 640A
Tigershark comes out of the water too far
You need to reduce the flow through the impeller - there should be a baffle (something in plastic, round, that will be installed at the top of the shark) in the box that it came in.
May 29, 2014 | AquaVac Tigershark Plus Robotic Automatic...
Head bolt torque for 1998 75 hp yamaha out bord engine
this forum here, is SUZUKI Aerio
if you post to water craft engines id bet , the responses are 100x better. pure guess.
Feb 23, 2014 | Suzuki Aerio Cars & Trucks
I cannot open my cambridge audio 640A compact disc
This is a common issue with all belt-drive cd players, all you have to do is to change that belt and you should be done, or take it to a shop for servicing, as this is a part of a simple service maintenance routine, cheap fix though.
Nov 02, 2013 | Cambridge Audio Azur 640A Amplifier
HI, Can the Cambridge Audio 640a integrated amp be used as a preamp if I buy a separate power amp.
Of course, just run an audio RCA pair out from the Pre Out to your next amp and any input. All control for volume, tone, etc will remain with the 640A.
Jan 26, 2011 | Cambridge Audio Azur 640A Amplifier
My 1995 Suzuki Swift floods at startup untill the engine warms up
Check for vacuum leaks. WIth the engine running, wiggle all hoses around and listen for a hissing sound. Look for a cracked broken or loose hose.
Dec 24, 2009 | 1995 Suzuki Swift
230 Voltage
Good Day sir, yes the 640a has a voltage selector switch.
http://www.cambridgeaudio.com/support_products.php?PID=105&Title=Support
Jul 21, 2009 | Cambridge Audio Azur 640A Amplifier
Have power to the floating cord but tigershark will not run.
My tigershark would start working then stop 20 seconds to 20 minutes later. I found that the power switch was loosing good connection after self check cycle, I turned it on and off rapidly to hopefully clean the contact! I now disconnect and restart by pulling the power cord. I have run two cycles with no problem> I will replace the switch when I get a chance.
Good Luck
Apr 25, 2009 | Aqua Vac Tiger Shark
HP 640a cd/dvd burner
methinks you have a major device issue. Check it through control panel, hardware devices to see if driver is happy or not/
Feb 18, 2008 | HP Pavilion a1240n (EG136AA) PC Desktop
Sport & Outdoor - Others Logo
208 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
