Question about Microwave Ovens
Ihave a microwave make Inverter and have broken the wheels that turn the dish could I get a replacement
  • Microwave Ovens Master
  • 6,993 Answers
the answer is yes. You can get replacement wheel. You might not get exactly the type of wheel that was broken, but you will definitely get a wheel that will fit the inverter.
You should get the wheels in any mechanical shop/store within your vicinity. Also, carry along the broken wheel so that you can get the exact/correct wheel replacement.
Good luck.
Posted on Oct 05, 2010
Wheels under ring have wore paint off.. Can and what can I RE-PAINT THIS WITH
you can go to www. repairclinic.com and get it the parts necessaryGod bless you
Apr 04, 2013 | Sunbeam Microwave Ovens
Plate wheeled support broken
You will need to go to Sunbeam to get that part, if it were a plate easier to find. ebay is a very good source for microwave parts, also check out a microwave repairman.
Mar 08, 2012 | Sunbeam Microwave Ovens
Would like to know how to use the Inverter. Is it for baking & defrosting? Have never used one before and do not have a manual.
Hi ifcope2000,
The inverter in your oven is for defrosting. It works on the basis of weight of the food to be defrost. To use the inverter follow the following steps.
First place the food on the microwave dish and then close the door.
Now press Inverter Turbo Defrost.
Enter the weight of the food using the number pads.
Press Start.Defrosting will start. The time will count down. Larger weight foods will cause a signal
midway through defrosting. If 2 beeps sound, turn over, rearrange foods or shield with aluminum
foil.
Atul
Mar 13, 2011 | Panasonic Microwave Ovens
Microwave makes noise when turning only in one direction
It sounds like the turntable motor is failing or the turntable requires its wheels cleaning. If it is the motor, it is a synchronus motor with a plastic gearbox reducing the RPM to about 5. The gears fail when the turntable dish is turned as the motor stalls the shafts.
Replacing the motor is no big deal.
There is usually an inspection cover that can be removed on the underside of the cavity.
Remove the cover and remove the motor.
Replace with the same type and the reverse procedure will fix it.
You may however require a self tapping screw to affix the cover back on. A bit of a puzzle but not too difficult to work out!
Hope this helps.
Dec 29, 2010 | KitchenAid KCMS1555R Microwave Oven
Our microwave has developed a very jerky turning condition. Sometimes it makes a horrible "growling" sound when this happens but not always. Is there a fix to this?
there is a gear motor that turns the turntable...it sounds like it may have been overloaded at some time or it's just worn out...this motor would need to be replaced. A word of caution though...there ARE potentially lethal voltages inside the cabinet..especially on the magnetron tube and the capacitor...do not work on the microwave unless you are familiar with high voltage safety and line powered equipment.
Dec 18, 2010 | GE JES2251SJ Microwave Oven
Turntable wheel under glass tray broken
If the microwave comes with a roller ring to rotate the glass turntable then I would recommend that it needs to be used when the microwave is operating, as the turntable rotates the food so it can be heated evenly.
I would recommend checking with your local Panasonic repairer he may have access to a new roller or even a second hand one to tide you over.
Mar 20, 2009 | Panasonic Microwave Ovens
Microwave doesn't work
There is a reset somewhere around the top or close to heating element
Mar 12, 2009 | LG Over-the-Range Microwave
Microwave turntable
The solution is very simple. Unplug the microwave first. Remove the round dish. Remove the circular riing with the rollers and set aside with the dish. Carefully with a butter knife, pry up the coupler and set aside. Examine to make sure it isn't broken or cracked where it slips over the motor shaft. Remove 5 Phillip head screws from the bottom pan and it hinges down out of the way exposing the motor. Remove 2 screws holding the motor, slip off the plastic dual flat connector and slip back onto a new motor $52.25 + shipping from GE parts. Remember your actual MW Model number is NOT XL-1800 but it is on a metal tag inside the MW on the left side. Put the motor screw in as removed so the shaft is free to stick up the hole in the bottom of the MW. Put the pan screws back up, put the coupler on, the ring in and then the dish and line the slots of the dish up with the star coupler so it catches. Turn on MW, touch the turntable button and make sure it is "ON" and not "OFF" and it should be, with the door shut, turning like a quiet little top as new.
Aug 19, 2008 | Microwave Ovens
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
