Question about Panasonic Lumix DMC-FS15 Digital Camera
Dmc-fs15 lens locked out - Panasonic Lumix DMC-FS15 Digital Camera
  • Panasonic Master
  • 19,396 Answers
Hi.
It is called a lens error. Problem is called by dert inside lens gears or by a part that has became defective. In some case, the lens try extending, as they cannot reach full extension they retract or stall, until the camera shuts down. In your case the lens extended and got stuck.
First step is resetting the camera by removing battery for one minute. Ensure that you put fully charged battery and restart. In some occasions the reset may work.
First try removing internal battery and restarting the camera, also ensure that the camera is not set in PC mode, but in shooting mode.
You can attempt pushing the lens gently back in the camera while turning the camera off. Sometimes this can help the lens back in.
If that does not work, then the lens must be taken apart.
The lens assembly is very delicate and it is made of small gears and parts. If you do not have enough experience, with DIY disassemblying there is always a good chance that you end up with the camera turned into a bulk of tiny bits and pieces.
I summarized the problem in this article: Lens Error.
Try following the steps in the article if that does not work I suggest calling Panasonic at the number listed on manual. You can also get a quote from a third party service here: Repair.
Posted on Oct 05, 2010
How to slove system error(zoom) of my panasonic lumix dmc-fs15
You can't. it is cause by something blocking the gears or the lens being knocked to the side. Here is the online service form
http://www2.panasonic.com/webapp/wcs/stores/servlet/RequestCenter?storeId=15001&catalogId=11017
Jul 01, 2012 | Panasonic Lumix DMC-FS15 Digital Camera
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
System Error (Focus) ...Lumix DMC-FS15 works, pauses, then results in a white error screen with the following error message:
My camera started bringing up "system error (zoom)" and it was completely inoperable. I would turn it off, but the lens wouldn't retract unless I applied slight pressure to it. I was able to FIX this problem by applying some lubricant oil to a Q-tip and swiping it around the telescoping parts of the lens, being very careful to stay away from the actual lens. I turned the camera on and off a few times so the oil could work its way into the parts, and it fixed the problem. I don't know if it will be a long term solution, but I can at least download my pictures to my computer now!
Oct 08, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
I have an FS15 and get the error message, 'system error zoom' the lens is not centred and does not retract. The camera has not been dropped and is c15m old.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 18, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
Have a Panasonic DMC-FS15 and get message saying "turn off and back on" followed by "system error (focus)" Have tried taking battery out for length of time and making sure charged, blew...
I have this exact problem. I note, your issue is happening at the same time. Weird.
Tried a variety of other "fixes" but none seemed to solve this issue. Thoughts?
jeremy.wolf@gmail.com
Dec 03, 2010 | Panasonic Lumix DMC-FS15 Digital Camera
My LED screen for my Panasonic Lumix DMC-FS15 has broken, I have seen replacement screens on ebay from Hong Kong. How do I take the camera apart to replace the screen???
the best answer.. very carefully...
becarefull with replacing your screen, if you don't have the right precision tools and other equipment you might further damage your camera
Free quote for this repair at:http://www.teleplancamerarepair.com/manufacturer/repair-camera-model-problems.asp?mo=680
May 29, 2010 | Panasonic Lumix DMC-FS15 Digital Camera
I have lost my manual for my new camera Panasonic lumix DMC-FS15 were can i get another one
You can download the complete user manual by clicking this link
  • You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Feb 25, 2010 | Panasonic Lumix DMC-FS15 Digital Camera
My panasonic dmc-fs15 camera's memory card is locked
hi there
on the side of te mermory card there is a turn on and a turn off just look on the side of it
Dec 22, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Panasonic Lumix DMC-FS15 Digital Camera Logo
347 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
