Question about Electric Cycling
Powabyke euro nothing happening when i twist the throttle, battery fully charged, throttle seems to be okay. motor in front wheel.
4 Suggested Answers
  • 200 Answers
SOURCE: Indicator light fully charged...but barely enough power to move
Clean and tighten all wires connected to the battery, motor , controller etc.being doubly sure of all grounding wires . Don't take any shortcuts ...remove wires ,clean and inspect for cracking or burning, clean and or replace....this will pay off for you...Good Luck....Tim
Posted on May 12, 2009
  • 30 Answers
SOURCE: I picked up a bike
It sounds like the throttle cable needs to be adjusted/connected. Check all the cables/wires going to your throttle.
Posted on Jun 28, 2011
erickedubbs
  • 15 Answers
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Posted on Apr 13, 2013
When i turn the key on the scooter, nothing happens and nothing lights up, i have checked connection and all show power, the power indicator does not move, yet batterys are fully charged any ideas TIA
hi Shane, i recommend you check the fuses on the tiller ..
if all okay check the fuses located on the battery leads , if fitted and check the connections to the controller which is located under the foot panel..
Regards
Rob
Nov 05, 2015 | Pride Celebrity X 4-Wheel Electric Scooter...
2013 EW36 ewheel scooter. Why doesn't it start?
I think the the fuse is under the head light cowling glass type 25 amp fuse. Your throttle, motor wiring, or controller maybe causing this problem.
Oct 24, 2015 | Electric Wheels Ew36 Mobility Scooter Red
I have a three wheel wuxing mobility scooter when i twist throttle to get moving it cuts out (kind of like the brake is stuck on) thinking that maybe the batteries might be bad or a connection problem
hi Diane, it does sound like the batteries are very weak, can you confirm they are fully charged ? is the charger okay ? can you try another charger ?
however it could be a bad connection...
Regards
Rob
help me help you ...
Sep 20, 2015 | Health & Beauty
My schwinn stealth 1000 shows I have power but when I twist my throttle nothing happens?
Melted means overload, blown means a short, possible causes-bad connection on battery leads, motor brushes worn, shorted wiring in motor or bad bearing, brake dragging on wheel, motor controller going bad. Check it with wheels off the ground , try to isolate what is binding , causing overload on the motor.
Jun 03, 2015 | Schwinn Motorcycles
My Zip'r 4 is flashing the green light 7 times which means, "A throttle fault has occurred." The Throttle seems to be working fine, How do i fix this issue?
One of the cells of the battery seems to be bad. Though you charge it, and it shows full charge, but at the time of using the throttle the kinetic power is not there. I recommend that you take the battery to battery ware house so they can confirm the problem. If the problem is not with the battery then the issue is with the circuitry, but most likely it is the cranking power of the battery, though it is fully charged, but it get exhausted right away..
Jul 07, 2014 | Zipr Mobility Zipr Xtra 4-Wheel Hybrid...
I have a 240W electric scooter with 12V X 4 batteries of 20AH each. The battery current meter, headlamp, trafficator lights, horn etc work. Throttle does not produce motor rotation.All connections checked....
Make sure that the manual brake release/freewheel lever is enaged as if it is not, this will allow you to push the scooter, but will not engage the drive motors. It is usually located on the rear of the vehicle; check your owner's manual.
If this does not work, contact the manufacturer for additional troubleshooting.
Oct 25, 2010 | Electric Health & Beauty
My honda cbr 125 wont start. Battery okay
i think youneed to start the bike with a fully charged battery and the choke open with no throttle and keep turning it over till it stars failing that check the fuel hoses and vacum hoses to the carb
Jan 25, 2010 | 2004 Honda CBR 125 R
Does not run when I push the pedal, it is brand new and has run once for 2 hours on an 18 hour charge, called PP and they told me to move the red pedal wire to the blue location (bypass) nothing happened....
OMG! The exact same situation here! Bought through Amazon, no warranty. I am so bummed. It was rode 5 times by a five year old on flat ground. Now it is a brand new, non operational, made in China piece of $500- junk! I am furious!!!When you press on pedal, nothing happens, fully charged battery, etc. Volt meter even confirmed fully charged battery. What ever happened in your situation? I am so hesitant to buy other parts, or send it here, to put more money into an overpriced piece of ****. Way to ruin Christmas!
Dec 02, 2009 | Polaris 800 Twin Sportsman Ride on Toy
Mar 30, 2009 | Razor MX350 DIRT ROCKET - BLUE
Cycling Logo
195 people viewed this question
Top Electric Cycling Experts
ebike
Level 1 Expert
Eric Hidle
Level 1 Expert
Are you an Electric Cycling Expert? Answer questions, earn points and help others
