Question about Canon iR 2016i Black and White Copier
After changing the toner..still indicating OUT OF TONER... please advise
    Problem Solver:
  • 3 Answers
Try power cycling the copier. (off then back on)
Posted on Oct 05, 2010
My sharp ar5316e is showing a red triangle blinking light and no key is responding nether the start button
That indication is Toner Indication.You should change the toner,Now May be the toner chip also damaged. whether the machine worked after changing the toner then no need to change the toner chip,other wise the same indication still, then you change that one also.
Jul 08, 2011 | Sharp AR-5316 Advanced Digital Imager...
Hi, I have kyocera km c850D. Please could you explain why machine keeps saying replace waste toner box although it is quite empty. please advise if tere are any other parts of the machine to clean or...
Are you using a new waste toner container or did you empty the one that was already in the machine?
The machine uses a sensor that looks at the container to determine if it is full of waste toner. If there is toner on the inside sides of the container were it looks for toner it will indicate that it needs to be replaced even if you have emptied the toner out.
It is a good practice to replace the waste toner container with a new one, that is the way the machine is meant to be used.
If you have correctly installed a new waste toner container and the message hasn't cleared you may have a faulty sensor.
I hope this information is helpful,
Shawn
Jan 26, 2011 | Kyocera Mita (km-c850d) All-In-One Printer
CLP-315 - CLP-315 Laser Printer: I have changed all the color toner but not prining...
any error indicated?
run your Smart Panel and check what is the fault that is being detected.
If all the color toner had been replace. what about the OPC & waste toner tank?
note. Please replace the waste toner tank once it is full do not reuse the same waste toner tank. as it will course the internal of the printer to be spread with waste toner and your print out will be dirty and patches.
May 16, 2010 | Samsung CLP 315 Laser Printer
Canon Ir2018 always indicating ''no toner, change toner''
Because you need to clean and shake the toner unit. When you say " ive been fixing" does it mean that you now what you are doing or?
If yes dismantle the toner unit and vacume it, it may be that toner stucked on "antena" for toner recognitions.
If not - call service
Pls. rate
Apr 27, 2010 | Canon Office Equipment & Supplies
Yellow light on Toner light on) Cannot print a thing
take out the toner.. at the left side of the toner, there is a level, unscrew the 3 screws and turn the level to the other side, this will reset your toner.
make sure the printer is on when you put back the toner.
Jan 18, 2010 | Xerox DocuPrint 203A Laser Printer
OKI C8600 Printer Toner Sensor Reset
I've had two toners that have done this, they register as used as soon as you turn the dial to open the toner compartment. So if they don't work properly, as soon as you remove them.. you can no longer use them. (they empty contents into the drum).
I got in contact with my supplier and sent them back as faulty cartridges.
Sep 30, 2008 | Office Equipment & Supplies
Samsung 2010 printer
Mine did the same thing, turned out to be an empty toner cartridge. The one that comes with the printer when you buy it only prints about 50 sheets before it dies.
Mar 13, 2008 | Samsung ML 2010 Laser Printer
Canon iR 2016i Black and White Copier Logo
old marine
old marine
