Question about Echo Garden
Blower is hard to start. What should the screws be set out to start and then adjust from there.
  • 84 Answers
Most all carburetors are designed to have the screws set at 1 1/2 turns out from bottom. It sounds like you may have a different problem. The screws typically stay put until you move them. But you can certainly give it a try.
Posted on Oct 05, 2010
Carburator Hi / Lo Adjustments
First things first. where are your screws set when you start it is very important to know where you are at when you start adjusting a carburetor so you can put it back in the same position when you move on to the next attempt at a solution if it should turn out that the adjustment was not the cause of your issue. Turn both H and L screws, individually, clockwise until they bottom out GENTLY. DO NOT TIGHTEN these screws down this will damage the needle and the seating surface of your jet as well as the jet itself in some cases. merely turn them until you gently come in contact with the seat, translation until it doesn't turn anymore using VERY LITTLE FORCE. Now back each of the screws out Turning Counter Clockwise 1-1/2 turns each. POINTER: Take a sharpie and put a dot on the side of your screwdriver so that you can see it well. White out works to if the sharpie is hard to see. Turn the screw one half turn at a time counting out loud to yourself 1/2...1...1-1/2. All the while watching the position of your mark on your screw driver. Your dot should end up on the opposite side that it started on. Now adjust your throttle using it's set screw turning it also clockwise. Turn it enough to sufficiently raise the idle Don't Go Crazy about 1/4 throttle should do. Start your saw after you have taken a look around for safety. Start with the l screw or low idle circuit. using your ear to tune it. Adjust the screw in or out till the machine sounds the best then turn it Clockwise about an 1/8 of a turn. Then move on to the H screw or High Idle Circuit. With the trigger fully depressed adjust back and forth until you find the sweet spot. Release the trigger. Adjust your idle screw back down . Now Squeeze the trigger again squeeze it completely and quickly. Does it bog a little between circuits Adjust the L screw and then the H screw a little at a time until you have a smooth transition between them both.O7OUT
Feb 04, 2014 | John Deere 2E Leaf Blower Operators Manual
What is the factory setting for lowand high screws on 25cc craftsman blower
If the two screws are side by side, one is the high speed mixture screw and the other is the low speed mixture screw. To set the high and low adjustment screws, tighten the screws in until they stop, don't force the screw after it stops. Back each screw out 1 1/2 turns. The engine will start and run here if everything else is ok. Fine tune each adjustment screw by closing the screw off (CW) until the engine runs rough. Back the screw out (CCW) until the engine smooths out. Run the engine at full speed and adjust the high screw. Let off the trigger and adjust the low screw. Once the mixture screws are adjusted, you can turn the idle screw to adjust the idle speed. It can take some time getting it all adjusted.
Nov 20, 2013 | Garden
Weedeater FB25 5months old only used once and was hard to start right from the box. Can't get it to run now. What steps should I take on troubleshooting
This sounds much like poor car settings ( set too lean ) you need to richen up the L and H screw on the carb, unfortunatley there will be anti tamper sleeves on the carb or a special tool reqired to adjust them, turning the screws anti clockwise will richen the mixture if you manage to remove the caps or get hold of the apropriate tool.
Dec 14, 2012 | Weedeater 25cc Gas Blower ()
My brand new blower only runs on half choke setting and stalls when I move it to run setting
My name is Dane and I am going to assist you in solving your problem.
You will need to adjust the high speed setting on your Carburetor jet. Turning the screw out just 1/2 turn or so should do the trick. It is not so hard to adjust the Carburetor, however you do need a special tool that is very hard to get your hands on, in order to adjust the jet screws. They don't make many engines with plain screw heads anymore. The newer Carburetors are factory set lean so they can pass emission standards. If you have a local dealer, they should adjust the mixture free with a recently purchased unit or for a couple of bucks otherwise. I hope I've helped. Thank you! Dane
Dec 24, 2010 | McCulloch 26cc Backpack Blower with Dual...
Husky 125B blower, new right out of the box. starts, runs about 30 sec, bogs and quits. I'm guessing likely needs carb adjustment, but set screws are not regular slotted screws. Looks like it requires a...
You will need to adjust the high speed setting on your Carburetor jet. Turning the screw out just 1/2 turn or so should do the trick. It is not so hard to adjust the Carburetor, however, yes you do need a special tool that is very hard to get your hands on, in order to adjust the jet screws. They don't make many engines with plain screw heads anymore. The newer Carburetors are factory set lean so they can pass emission standards. Since you just bought yours, a local husky dealer should adjust the mixture for free. I hope I've helped. If you found this reply useful, please leave me some THUMBS UP, if you feel I
Dec 09, 2010 | Husqvarna 28cc Hand Held Blower HVH 125B
NEED TO SET IDLE SCREW AND MIX SCREW ON A GAS LEAF BLOWER
The Idle screw should just touch the throttle lever to start, the low speed should be set at 1 to 1.5 turns out from lightly seated, and the high speed should be set the same. Final adjustments are made only after it has been warmed up. If you adjust before 2 minutes of use the mixture will be too rich.
Hope this helps
Nov 10, 2010 | Craftsman Garden
Fuel Mixture Ratio Is it - 25:1 40:1 50:1
not sure if yo are changing the jets out but if your using the original screws and jets screw both screws in till they stop then turn 1 and a half turns out they try starting if it kicks and won't run then turn each screw another 1/2 turn out try starting if it runs rough adjust the gas jet a little bit till it runs smooth once it warms up give it full gas and you should get just a slight puff of black smoke to be set right, if it's too lean it will get hot and will be hard to start if it dies, if that happens then give it extra gas. once warmed up it should idle without dyeing if it dies adjust the idle screw up 1/4 turn at a time till it runs at idle without holding the gas trigger, be sure you replace the in line fuel filter and fuel line first then clean the air filter before doing any adjustments. most problems are caused by plugged fuel filter due to ethanol in the gas.
Mar 10, 2010 | Garden
Can't keep my snow blower running under load, cleaned carb, but do not know adjustment procedure for a tecumseh 7.5 hp 15 year old snow blower
there should be an ajustment screw on the carb. turn it all the way in don't turn it hard then turn the screw back out 1 1/2 turn to start out with then after runing turn till it runs evenly.
Dec 20, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
BX 90 homelite leaf blower two idle screws
The initial setting is 1 1/2 turns out. Screw them all the way in and them turn them 1 1/2 turns out. This is the starting position and should start, it may need some final adjustments to run like you need it to run.
Remember more the screw is out the more fuel it will get.
Good Day.
Oct 14, 2009 | Homelite 'Yard Broom' Leaf Blower
Have a toro power stage max model 826LE electric start, runs irre
Sounds like carb. may need adjusting. Take the heat box off to expose carb., there should be 2 adjustment screws- 1 on the bottom of the bowl and 1 on the side of the carb just above the edge of the bowl ( depending how the carb sets off the engine - if the carb comes straight out it will be on the side facing towards the front of the snow blower or if it goes towards the handles then standing other side of the snow blower the screw will be facing you), turn both screws in til they just bottom out the turn them out 1 1/4 turns out then start the machine. While the machine is running at low idle turn the screw on the side of the carb. in (clockwise) a little at a time listening for the engine to start to rev up and then start to rev down, bog or studder then turn back slightly to bring idle back up. Once the idle is up then the screw on the very top of the carb. turn that out to lower idle to a normal idle. Repeat those adjustments till you cant get the idle to go up anymore. Now for the screw on the bottom of the bowl- move the throttle up to max and turn the screw in till you hear it rev up higher and starts to bog or sputter then turn it back slightly to bring the high rev to a smooth rev. That should take care of it. If it does not solve it then the carb may need cleaning then the adjustments done again. If you need more help on this please feel free to ask. Sometimes you have to do process of elimination and you start with the easiest first. Also the adjustments should help with the carbon build up on the plug.
Jan 15, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Garden Logo
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
