HP4550 - 49.00FF service error - Computers & Internet
  • 857 Answers
Turn off the RAM disk on the printer.
Follow these steps:
Troubleshooting steps
1.
Verify that the formatter light is blinking or steady. If the formatter is blinking, it is functioning properly and probably does not need to be replaced. If the formatter light is not blinking, proceed to Step 2.
2.
Turn off the printer and unplug the power cord.
3.
Remove the HP Jetdirect card, third-party device, hard disk, parallel cable, or IFR cable from the formatter if one is installed.
4.
If the error continues with accessories removed from the formatter, perform a cold reset on the printer. Ensure the HP Jetdirect card is not in the printer during a cold reset or the card settings will be changed back to default settings. To perform a cold reset, do the following:
1.
Turn on the printer.
2.
Watch the control panel.
3.
When the memory starts counting, press and hold the green (Select ) button.
4.
Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
5.
Release the check button when the Ready, Data, and Attention light are on steady.
The control panel will display SELECT LANGUAGE .
6.
Press (Down Arrow ) button once. The control panel will display COLD RESET
7.
Press (Select ). The printer will perform a cold reset and then continue its power-on sequence.
5.
If the printer comes up to ready, print a Configuration page. If a 49 error occurs from printing internal pages, continue on to the next step.
6.
Turn the printer off and unplug the power cord.
7.
Remove the eight screws around the formatter.
8.
Remove the formatter. See Figure 1.
9.
Reseat the firmware and memory modules on the formatter. Check for any DIMMs that are non-HP and remove them. Non-HP DIMMs are not supported by HP and may cause this error. Replace with HP DIMMs, if necessary.
10.
Reseat the daughter (interconnect) board. The daughter board is connected to the formatter behind EIO slot #1. To release the daughter board, push in the black retaining tab underneath the formatter then lift up the one side of the daughter board.
11.
Reseat the daughter board.
12.
Install the formatter.
13.
Turn the printer on again.
14.
If it comes up to READY , print a configuration page. If a 49 error does not appear from printing internal pages, or at power up, continue to the next step.
15
Install the HP Jetdirect card and hard disk before installing the formatter. Verify that each device is properly seated.
16
Test any EIO devices, by turning off the printer, installing each device separately, and printing a Configuration page. Repeat for each EIO device.
17
If the 49 error occurs with any EIO device installed, replace that EIO device.
Posted on Oct 05, 2010
Chassis settings service required error message. 2007 v70R with all OEM shocks and alighnment done about 1K miles later the error message comes on.
About 3,440 results (0.84 seconds) Search Results
    Chassis Settings Service Required - Page 2 - 2004 - 2007 V70R ...
    v70r.com > Home > Volvo > 2004 - 2007 V70R
    Nov 1, 2011 - So, in our case it seems that the shock / strut itself is totally undamaged (at .... As usual, the "chassis setting service required" message didn't show as I ....All of them will indeed need to be replaced when normal weeping ..... Error codes 0115 and 0201 can be related to a low battery, but 0023 and 0113 ...Missing: oem
    www.fixya.com/cars/t26080647-chassis_settings_service_required_error
    1 hour ago - Chassis settings service required error message. 2007 v70R with all OEM shocks and alighnment done about 1K miles later the error message ...
    Volvo S60 R "Chassis settings service required" warning - Swedespeed
    forums.swedespeed.com > Forum > Ask IPD > General Maintenance
    Sep 26, 2008 - 29 posts - ‎15 authors
    Now I have this message "chassis setting service required" Did the guys hit ... My way costly Volvo Service Department wants me to bring the car in for ... The explanation was that there is a defective shock and they ... First try was to replace a strut that gave a error. ... All is back to normal. .... 2004 V70R - GT. "Anti-Skid Service Required"
    Dec 22, 2012
    "chassis settings service required"
    Sep 4, 2012
    Another "Chassis Settings Service Required" thread
    Aug 13, 2012
    AntiSkid Service Required and Chasis Settings ...
    Dec 5, 2
Feb 03, 2016 | Cars & Trucks
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Mar 26, 2012 | Canon LASER SHOT LBP-2900 Printer
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
Please call for service
If the machine is saying "Please Call Service"..you will have to access the Service Call function to determine the exact problem.
Press PROG,*,6
Press PROG to select "service call" mode, then press ENTER.
The Error Mssge will be displayed.
For example Heater Error, Drum Fuse Error, Inside Fan Error, etc, etc...
**Most common( given m/c age.) would be "Heater Error"...which indicates a problem with the Fuser Unit.....if this is the case you will need to contact local Muratec service for parts.
Oct 23, 2010 | Muratec - MFX-1300 Copier
Message is Service call error 00010014
SERVICE CALL 00010014
Description
Failure of pressurizing
Nov 21, 2009 | Epson Stylus Pro 9800 InkJet Printer
My OKI printer is giving me a message which reads, "Service Call 106: Fatal Error".
YYYY
106: FATAL ERROR
An error has
occurred which
requires service.
YYYY = the general
cause. 106 = error
number.
Try turning off the
printer then turning it
back on. If this does
not remedy the
problem, write down
the message including
the error number
“106,” then call your
authorized Oki Data
Service Dealer for
service.
Note: If you see a
series of octets
containing letters and
numbers scrolling
across the display, be
sure to write these
down also and report
them to the Service
Fuser error. Replace fuser or if no-go, Main board.
Aug 26, 2009 | Office Equipment & Supplies
Computer shows no display
did you try installing newest drivers from intel/gigabyte website? what you described looks to me as a overheating problem. try running the game with case open. are you running on the integrated GMA graphics or PCI-E graphics card(like geforce, radeon)?
Jul 02, 2009 | Gigabyte Computers & Internet
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
Feb 18, 2009 | Epson Stylus Pro 10000 InkJet Printer
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
Apr 29, 2008 | Epson Aculaser C1100 Printer
Computers & Internet Logo
937 people viewed this question
David Payne
David Payne
