Question about Kyocera FS-3900DN Laser Printer
Help my kyocera fs-3900dn just keeps adding toner and dumping it into the waste toner tank continuesly. how can i stop this . i have already fitted a new dev unit and toner cartridge, but no difference.
  • melissa_morr Oct 05, 2010
    dev unit? Could be your drum.
leroyal
  • 2120 Answers
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Posted on Jan 23, 2009
  • 66 Answers
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Posted on Mar 10, 2009
  • 66 Answers
SOURCE: CALL SERVICE 7410:0002988
the 7410 error may be a drum unit that is not pushed in properly or it could be the following
defective drum EEPROM drum needs to be replaced or
defective engine PCB
the above suggestions assume that it is an original Kyocera drum
hope it helps
Posted on Mar 21, 2009
SOURCE: Hi, moved my FS 3830 and it now says check waste
If you are in Ho Chi Minh City,you can go to Dinh Cao Trading and Service Company at 63 Vinh Vien street district 10 and we'll solve the problem for you.
Posted on Mar 16, 2010
Testimonial: "We took machine there this morning. Will lwt you know how it goes..."
  • 241 Answers
SOURCE: kyocera fs-3900dn showing 7410:0024216 error code
The 7410 is a drum installation error code. This is typically caused when the waste bin is replaced. Open the left door and push on the drum unit just above the waste bin, usualy a click will be heard when pushing it in. Then power cycle the printer. This should fix the error message.
Posted on Jun 09, 2010
FS 3900 "Unknow toner istall" shows in display?
The message is indicating that you do not havea real Kyocera toner installed in the machine.
Apr 04, 2011 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
Kyocera FS-3900DN Ecosys Call Service 2200:0100998 Help please our printer has stopped working
The Call Service 2200 is a drum motor error. The motor or gears might need to be replaced. First remove and re-seat both the developer and the drum unit. The developer is directly under the toner cartridge - lift it up then out first, then open left side door remove the waste bin and press the button on the drum unit just above the waste bin pull the unit out (carefull not to touch the drum surface). Re-seat both units. If this does not work call in a Kyocera Tech.
May 07, 2010 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
Kyocera fs-3900dn showing 7410:0024216 error code what do I do
Apr 15, 2010 | Kyocera FS-3900DN Laser Printer
MY fs3830n kyocera printer is dumping the toner
try emptying the waste toner bottle... if that doesn't work then change the drum... if that doesn't work then change the developer
Dec 22, 2009 | Kyocera Mita FS-3830N Laser Printer
Display says 'replace cartridge' & 'clean printer'. after cleaning out exces toner from where the waste bottle goes and around the toner cartridge and the cartridge that the toner sits in.
Try shaking gently the toner cartrige!!! This may help mix the toner which may be stuck together especially if the printer is not used often enough or stored in a place that is not as specified (humidity, ventilation, etc...).
Nov 13, 2009 | Kyocera FS-3900DN Laser Printer
Change drum kyocera fs-3900
open printer front cover and remove drum unite ,two side screw open two side spring **** two side open drum
if you are not possible it then buy a new one unite in your service authorized delar
Aug 27, 2009 | Kyocera FS-3900DN Laser Printer
I am getting Call Service 7410:00 32266 on FS-3900DN Kyocera Laser Printer.
You have pulled the drum unit out of position possably after changing the waist toner ? Open the back cover, open the frunt cover and remove the developer unit, the full unit not just the toner, open the side cover where the waist toner bottle is and push the drum unit back into place until it clicks, put the dev unit back in place and close everything reboot the machine
Apr 18, 2009 | Kyocera FS-3900DN Laser Printer
Error mfessage: check wastt tonner bottle
Try a new bottle. I've seen where the there's enough old toner clining to the sides of the bottle that prevent the sensor from seeing through it. Of course the sensor and led may be covered with old toner. Get in there with a vacuum when the machines off and clean it out.
Mar 30, 2009 | Kyocera FS-3900DN Laser Printer
Call service 7410:0037916
Hi, just swith off printer, and open left cover.Push drum unit(with grey lever on it -just by waste toner bottle) in the printer.Switch on printer.Drum unit was out of position.
Regards
Apr 08, 2008 | Kyocera FS-3900DN Laser Printer
Kyocera FS-3900DN Laser Printer Logo
539 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
