Question about LG 42PX5D 42 in. Plasma HDTV
Iterference my LG 42PX5D shows little red dots when on black screen no signal. Is this cable Iterference or screen problems
  • rjrapheal02 Mar 13, 2009
    i also brought a 42px5d and it is also showing me a red dot and some people says that the tv's lamp is out
  • Anonymous Mar 23, 2009
    I have the same problem, back screen, can be interference in signal?
The issue is the voltage is not tuned properly for the panel, could be due to panel aging or gradual component failure.
Posted on Jun 02, 2008
Everything working fine, then home screen no longer displays on TV. On startup, pink dots go across TV screen, then TV goes black. Signal from most recent input is not coming trhough the audio or TV.
I have the same problem. I have an LG lcd tv as well. I have my cable box connected to via hdmi into the reciever then from reciever to the tv via another hdmi cable. I can watch tv and like the problem above see the pink dots on boot-up but I can't get the home screen to display.
Jan 08, 2013 | LG LHB975 Theater System
LG W2361V 23 Vga to HDMI Cable Not Working
You have a cable problem as no such thing as a VGA to HDMI cable exists.
HDMI is a didital signal and is thus not compatable with an anolog VGA signal. HDMI to DVI cables however do exist as both are digital signals.
Hope this helps.
May 28, 2010 | LG W2361V-PF 23 in. Widescreen LCD Monitor
I have dots running across the screen
If the dots are red and green, that's normal. Just enjoy your hd picture. actually, I think the dots make it look clearer. The only time I can really see them is when the screen is black.
Feb 23, 2010 | LG 42PX5D 42 in. Plasma HDTV
Plasma tv has little red dots in the black
This problem (known as sparkles) can be cured by adjusting the ramp control on the Y-Sustain board. If this does not cure the dots then there is a software remedy for the control board which an LG repair centre could fix. Failing that a replacement board is required. The orbitor & whitewash are like screen savers to help to prevent a screen burn from a permanently displayed image.
Dec 31, 2008 | LG 42PC3D 42 in. Plasma Television
Red dots on screen
just video only what cable uusing how syour dvd player older ?
Oct 06, 2008 | LG 42PC1DA 42 in. Plasma HDTV
Red screens cause flickering
if normal tv is fine then ,likely the signal from the box is too hot.
if using composite switch to cable ch 3 or vice versa,
or use hdmi cable or change the box .
Apr 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
Lg plasma tv 42 px5d
Most times this can be corrected by the correct alignment of the diffusion. The unfortunate part is that will require a tech that knows how to set all of the power supply voltages and then align the diffusion pots on the ysus pwb. This could mean a defective ysus bd. but most times the alignment will correct this problem.
Mar 01, 2008 | LG 42PX5D 42 in. Plasma HDTV
HD TV
This problem cannot be corrected without disassembly, and the proper adjustment of the power supply voltages and the diffusion adjusment of the ysus pwb. This will take a qualified service tech that understands plasma technology.
Feb 27, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG 42" Plasma Red Spots/Mist on moving Black images
I was told this was a ramp voltage setting and any tv engineer can fix it quickly.
Feb 08, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
339 people viewed this question
Computer Repairing
Computer Repairing
