Question about Canon PIXMA MP240 All-In-One InkJet Printer
1-yellow lamp on 2-I need to install it with computer and I lose the CD
  • Canon Master
  • 19,396 Answers
Hi.
Here driver download page for the specific model:
PIXMA MP240.
In page select OS (Mac, Windows or Linux version), then scroll down the page and click on download link.
Here general instructions on how to install the driver: download Canon software
Regards.
Posted on Oct 05, 2010
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
Dec 06, 2011 | Panasonic Televison & Video
I reinstalled xp home ed. And then reinstalled all the dell resource cd's.iam not sure if there is a certain order that you have to install the resource cd's And the drivers on them but I can't...
Hello there.
I suggest you to download software called Driver Robot (freeware)
http://www.fileserve.com/file/X8pSHAP/ParadiseW.net_Driver_Robo_2.5_Build_3.0.rar
When you install it, open and click scan. When it finished click report to a file, save that file and open it. Click get drivers, find drivers you need, download and install it. Restart your computer.
Otherwise, put your dell resource cd in pc, go to device manager, right click on the yellow driver and choose update driver. Choose browse my computer, and then in the field include in in search, find cd, and click next and it will find it and install for you.
I hope I was helpfull.
Sincerely,
Steve TM
May 29, 2011 | Dell Dimension 2350 PC Desktop
I have a 4 ft 2 lamp flourescent system. I am changing the ballast. The existing wiring has blue / red / yellow / black & white wires. I have a new ballast (yes I confirmed at the store it is the...
The first thiing I suggest is checking the installation instructions (either included with the ballast or on-line) of the ballast you just purchased. Many fluorescent ballasts require that the lamps be wired in series - which I believe is what you had before. One lamp connects between the red & the yellow, the other connects between the yellow & the blue. Other fluorescent ballasts require that the lamps be wired in parallel - which may be what you have now (both lamps connect between the red & the blue). The installation instruction sheets should designate the appropriate wiring configuration.
That being said, just double-check one thing: Make sure the new ballast is rated for 2-lamps. Ballasts rated for 1-lamp will only include the red & the blue (no yellow). So I know you sad you already checked with the destributor, but double-check that one point.
May 15, 2011 | Electrical Supplies
Replaced lamp. Then I turned it on blinking green light and then yellow. can you help troubleshoot
yellow blinking or not? if blinking your lamp cover is open that could be you forgot to reconnect the wires back to the lead that monitors the lamp. It's a 2 wire molex connector either black or white that will be laying next to that light cover you removed to get to the bub. this connection may be labeled "CD". iF SOLID it is a high temperature indicator, the set would have to have a lamp that works for this, so I'm guessing the lamp hasn't turned on yet. the fast blinking green is your set initializing, testing circuits and fans and yup lamp cover switches.
Dec 11, 2010 | Mitsubishi WD-52631 52" Projection HDTV
Just installed jvc kd-s16 and it loses power after 5 seconds. Used proper wiring harness and installed in 1996 f150
Connect Yellow to Battery (always 12V), red to ignition, and black to ground. Disconnect all others. Check it. If the radio stays on and plays CD, then radio is good. You may check other wiring
Dec 27, 2009 | JVC AM FM CD DET FACE CAR STEREO
WEB CAM CD LOSE
install driver genius 2007 then connect ur cam & select the drivers u want to download
please vote for me
May 23, 2009 | Logitech Webcam
CD-Rom drive missing
Go to this webpage and you will be able to solve the problem. http://support.microsoft.com/kb/314060#letmefixit Basicallly, you'll be resetting the registry to recognize your CD ROM again. Be SURE TO FOLLOW STEP BY STEP. Print the instructions first so that you don't lose your place.
Apr 09, 2009 | NEC NR 7900A (NR7900) CD-RW Burner
Trying to install external DVD and it won't load! Why? I get a yellow flag in device manager!
Often you should install the drivers (using device CD), before you connect the external device to your computer.
1) Delete the driver from device manager,
2) disconnect the drive from computer,
3) restart computer,
4) install the driver (using device CD),
5) after driver is successfuly installed,
6) connect the external device.
Nov 30, 2008 | Lite On Computers & Internet
Switching the ignition off loses the preset stations
the red wire and yellow wires are crossed simple fix once radio is off
Sep 28, 2008 | Nakamichi CD-35z CD Changer
No sound on my computor
Right click my computer and choose properties then device manager
Look for anything yellow or has a yellow highlight or a ?
that means its eighter damaged or has a problem
you need to reinstall the drivers there are many ways to do this here are the easy 2
1.) you main board came with a driver cd, insert the cd, install the drivers then restart
2.) if you cant find the cd, download a program like driver magician www.drivermagician.com and install that program, it can detect and install your drivers for you automatically.
are that restart
verify that you have the correct device selected
1.) click start, all programs, windows media player
2.) click tools , options, devices
3.) click refresh and select the propper device ( speakers e.g)
4.) you can try different ones until you get one that works
If all the above fails you many need to reformat your computer, backup everything before attempting to do this,
1.) boot from a windows XP CD or insert in in the compuer
2.) follow the onscreen instructions to install it
3.) reinstall all drivers using any of the above described methods
4.) reinstall all your software
NB> FORMATTING WILL DESTROY ALL DATA ON YOUR SYSTEM
Jul 12, 2008 | Microsoft Windows XP Professional With...
Canon PIXMA MP240 All-In-One InkJet Printer Logo
56 people viewed this question
old marine
old marine
