Question about Kenmore HE2 Plus Front Load Washer
There is a water drip and the basin is filling up with water!
    President:
  • 1,430 Answers
The water inlet valve is failing. They tend to get debris in the seat and leak. They cannot be cleaned out it and will need to be replaced. They are usually inexpensive and easy to replace. Here is a link that should help Water inlet valve replacement
Posted on Oct 05, 2010
Stuck pfister faucet sleeve
  2. Thanks to Danny Paccho I purchased a wrench to use in removing the sleeve from Geers Plumbing
  3. Then , removed the \'87 Price Pfister faucet housing from the basin by disconnecting the 2 pipes under the basin and removing the top basin nut; inserted the wrench into the top, turning counter-clockwise until it locked (er tightened a bit) and hammered it out ,gently?, to not damage the escutcheon threads , or the basin nut.
Feb 19, 2013 | Price Pfister Plumbing
Cwtf is a contant dripping from the dispenser funnel, how do i fix this?
Inlet valve is leaking.Valve is located by removing front access panel.Can be rebuilt using p.n. 1111.0002 repair kit.You can verify by removing top lid and finding water leaking at fill basin tube.
Dec 27, 2010 | Bunn CWTF 15-APS Coffee Maker
We lost electricity very briefly today which caused the dishwasher, washing, drying, clean buttons to blink when the electricity came back on. I opened the door to do a load of dishes hours after the...
it seems unit fill valve is stuck open and water is coming in even when machine is off.fill valve opens up only when u start the unit.2 chks this u can open the door and look at the hole inside from where water comes in.if water is coming in with dooe open then 4 sure valve is bad and needs 2 be replaced.
Aug 11, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Sub Zero 642 side by side stainless steel leaks water from right door. evaporator pan is dry, water/ice dispenser door catch basin is dry. Several times per day water collects right under the stainless...
remove the crisper drawers and you will see a drain trough and a drain line . One or both is most likely blocked. If you pull the drain line off the trough usually you can clear it with a turkey baster filled with hot water
Jul 01, 2009 | Sub-Zero 642
Samsung ac model aw25ecb7
hi! bill,
water drip it should be outsidethe house,beside there is a spout on the basin of your ac unit and hose to drip off outside the house,all you gonna do insert a piece of wood or metal on front side of basin, in between basin and the wall,just small piece object to elevate the basin to outside wall,the water will not stored in the basin.or make a spout, drill a hole 1/4" size at the corner at the backside of basin out side your house,be carefull not to drill condenser tube or the fan blade,insert a plastic hose 3/16" and weld it by glue gun.and end of hose put it an empty bottle so that the water drip will not scattered outside your house.regards and don't forget to rate me,thank's a lot
Apr 29, 2009 | Samsung AW0503B Air Conditioner
THE WATER COMING INTO THE WASHER SEEMS TO BE OBSTRUCTED.
once hose is off water valve take a small flat head screw driver and pull screens out.you will see if they are clogged once they are out.
Mar 13, 2009 | Washing Machines
Water pours from detergent basin-Whirlpool Duet Sport
first remove dispenser pull out and make sure its not clogged inside,w/ hand fill around ,, on any frontload machine i perfer liquid soap,, are you using HE detergent
Jan 03, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore HE2 Plus Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
