Question about LG Washing Machines
LG model WD-12150FB the washer beeps and the motor wont start. the display is an SE code. Any ideas? Thank you Mike
SOURCE: LG Washer
brilliant! I had the same problem with the same symptoms so i ordered the hall sensor from mcm as well put it in and $17.70 + s&h later my machine is purring like a kitten once again thanks guys D.
Posted on Jan 21, 2008
Brussels
  • 16 Answers
SOURCE: Error code SE on LG washing machine means what?
SE is a sensor problem as per LG support. I will post a follow up after I have recieved the technician in 2 days
Posted on Nov 03, 2008
  • 5 Answers
SOURCE: LG Washer
I had the same error code along with the drum "freezing" up. The first unit that was delivered 2 years ago leaked water from the detergent compartment and they sent a second unit. I have only had this unit for 2 years and I am very disappointed in the LG product. LG was no help on the phone and I the only people that could service it were 45min away from were I live. I took the advice of a posting on this website that it could be a part called the sensor assembly (#6501KW2002A) and ordered it from an online electronics store (www.mcminone.com). To get to the sensor assembly, you first unplug and take off the back plate that has 4 small screws. Next, unscrew the big bolt in the middle and take off the hubcap looking part the bolt was securing. Next unclip the two sets of wires on the bottom of the circle you are looking at (the set of wires to the right are connected to the sensor assembly you want to replace). Next you will unscrew the 6 or so smaller bolts to take off the circular piece that the sensor assembly is snapped to. Take it off, unclip the old sensor assembly and clip on the new one – and reassemble. This worked perfectly for me and the part only cost $18 bucks plus shipping. When working, this product works well but I will not be purchasing any LG products in the future.
Posted on Dec 08, 2007
  • 148 Answers
SOURCE: OE displays and washer will not drain
you have to check the pump,remove the hoses from the pump first and check for any blockage could be lint or a sock,if there is no blockage and the pump spins its the propellar for the pump is worn and you have to replace the pump
Posted on Jul 08, 2008
geemarie
  • 876 Answers
It probably means System Error. Have you tried a simple reset. Pull the machine away from the wall carefully, make sure you do not have wet hands or feet, etc and unplug it from the wall. Leave it unplugged for 20 minutes. (Also check to see if it is plugged into an outlet with a little red button on it? is the button pushed in? It should be? ) After the wait, plug the washer back in and see what you have. I hope this helps.
Posted on Aug 15, 2008
I need a troubleshooting manual for an LG intellowasher 7kg wd-1274FHB which is displaying an SE error code.
LG error code SE LG washing machines displaying error code SE are indicating a "motor fault" although the technical information also says it could be a main PCB fault. They recommend to, "try the motor first". It's vague and not too helpful, especially for a DIY repairer so you really need an engineer to try and sort this one. You can't possibly justify "trying the motor first" if you interpret that as buying and fitting a new motor, they are very expensive. You need to at least know how to test a motor for faults and check its connections and carbon brushes (if fitted) if you want to try and diagnose the cause
Nov 23, 2016 | LG Washing Machines
Have WD1295fb model with error SE , tries to start but fails ?
Check the door lock motor and switch assembly to ensure that the switch works correctly. Check with Ohm meter to ensure continuity when operated.
Nov 30, 2013 | LG WD-1295FB Front Load Washer
I have an LG Tromm washer. I start it up it start
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 25, 2010 | LG WM0642H Front Load
Wont finish the load
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Jul 21, 2010 | LG WM2701HV Washer
We have a washing machine WD-1274FHB which is not working and showing error code SE which is not in handbook - help - wife has a pile of washing & is stressing out. Jim
SE fault on this washer is a failed hall sensor on the motor. You will need to replace the drive motor as the sensor is not replaceable.
Part No. WMD-300C2
Apr 25, 2010 | LG Washing Machines
LG WD-14401TB SE error code
the motor position sensor or the hall sensor part number is
6501KW2002A
May 05, 2017 | LG Washing Machines
5 year old LG WD-1219BD has error code LE, ''overload in motor''
LE is a very bad error unfortunately. It means that your motor communication is being lost. Generally on these LG washers it means that you need to replace the motor sensor. You will have to take the back panel off so that you can access the motor, remove the pulley and take the motor off, there is a little plastic sensor that clips onto the edge of the motor. The sensor is not sold separately from the motor so you will have to replace the motor unfortunately.
Part would cost you around $120 plus labor.
This is a common error on LG. Better to repair and use it or fix it yourself.
Hope i helped you,
Thanks for using ' Fixya ' and have a nice day!!
Oct 11, 2009 | LG WD-1295FB Front Load Washer
Error "SE" on LG WD-14381FBB
That is a system error code. Try to unplug the machine for 20 minutes to reset the program module.
Jul 31, 2009 | LG WM-2277HW Front Load Washer
ERROR CODE ''SE''
sensor error The connector (5-pin, male, white) in the wire harness is not connected to the connector (5-pin, female) of hall sensor in the MOTOR. ' Reconnect or repair the contact in the connector.
Jun 26, 2009 | Washing Machines
LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Aug 02, 2008 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
219 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
