Question about Zenith R56W36 56" Rear Projection Television
Picture moved about a foot to the left and is not clear
  • Zenith Master
  • 5,138 Answers
Try the Zoom button on remote,for picture size.
Posted on Oct 05, 2010
How do you move the foot left or right on the 1530?
As far as I am aware, the foot is in one location only and cannot be changed. The needle can (depending on your machine) sometimes be moved right or left.
Jan 18, 2017 | Sewing Machines
Stitch length bunches up using walking foot on quilt sandwich
sounds as if your bobbin is getting caught up not feeding right , also had some luck in past adding clear tape to cover serrated foot for finer fabrics and things like real silks and such but it has to be replaced a lot
May 08, 2015 | Brother PC420-PRW Project Runway...
Need instructions for Singer side cutter model CY9000L. I have a Singer Talent 3323
http://www.amazon.com/SINGER-Attachment-Low-Shank-Sewing-Machines/dp/B00G6TW7ZK
There is a video tutorial on this Amazon page on how to use this attachment. Basically,, the forked arm fits over the needle clamp, and it attaches to the machine the same way any presser foot does. Check the video, it's very clear. The video is the last one of the group of small picture icons on the far left side of the page near the top of the page.
Oct 09, 2014 | Singer Side Cutter Attachment Presser Foot...
Computer stuck on "Raise presser foot lever" when I want to embroider
I fixed myself. When you take off the front left cover to expose inner workings o0f pressure foot lever, move the pressure foot lever see, the small metal plate move, when looking from back of machine see a small post upper left rear with what kooks to be a spring, lightly touch causing to spring back to the left and you will hear a snap. This is realigning pressure foot and your embroidery unit will register and you will have a normal lcd screen.This helped me, hope helps you.
Jul 19, 2012 | Brother Se400 Computerized Embroidery &...
I just bought the Singer 1409. The needle is off center to the left. So far off I cannot use the zipper foot. Is there way to adjust to center or do I need to exchange the machine for another one?
If, it is like my Brother machine (CS6000) the needle is set to the left, I have to move it with the button. See, if yours is like that, If not, call Singer at 1-800-4singer Monday at 9am and ask them what is the thinking that decided this so that you cannot even use a zipper foot? Maybe, there is a trick that they do not make clear in their manual. Very strange.
Jan 02, 2011 | Singer Vacuums
I have a singer 4552 (portable) and I am having a prblem getting the zipper foot attached. Also I am having a problem getting the design stiching to work. I can get the red design stiches to work but not...
Hi. Here's how to attached the zipper foot.
To Attach the Zipper Foot
1. Loosen the large screw at the left of the presser bar and remove presser foot (You do not need to remove the screw).
2. Hook the prongs of the Zipper Foot around the presser bar from the back, and tighten the presser-bar screw.
3. If the raised edge (zipper or cording) is to the right of the needle, adjust the Zipper Foot by loosening the thumb screw at the back of the foot and sliding foot to the left of the needle. If the raised edge is to the left, slide foot to right.
4. With presser foot down, check its position by lowering needle into side notch, making sure it just clears the foot.
5. Tighten thumb screw to lock foot into position.
When raised edge is placed to right -- adjust foot to left of needle.
When raised edge is placed to left -- adjust foot to right of needle.
Sep 04, 2010 | Singer Sewing Machines
Blocks puzzle # 57 in Nintendo DS 50 Classic Games impossible?
  1. Top Icon right (3 moves)
  2. Left Icon left (1 move)
  3. Sedond Left Icon left (1 move) clears 2 Icons
  4. Left Icon right (1 move) clears 3 Icons
  5. Top Left Icon left (2 moves) ends up on bottom
  6. Middle row Second Icon left (2 moves)
  7. Middle row Third Icon left (2 moves) clears 2 Icons
  8. Middle row Second Icon right (1 move) ends up on bottom
  9. Middle row Right Icon left (4 moves) clears 3 Icons
  10. Top Icon left (1 move) clears 2 Icons
  11. The Rest Is EASY!! (2 moves) clears 4 Icons
Jan 24, 2010 | Nintendo DS Lite
Can I move the needle to the center of the foot?
there should be a button (wheel) that has a picture of a zig zag line above it in the window there are numbers and 3 letters L M R these are the letters for the needle to be at the left, middle and rgiht when you move the wheel makesure the M is in the center of the window you can see the needle move also
I have a brother x-5700, you do not say what model your is, I think it should be similar to mine
Hope this help, if so please rate
moni
Sep 07, 2009 | Brother Sewing Machines
How do I attach a walking foot
Okay let's get started.
  • First let's look at the walking foot.
  • Turn the bulky body so that it's away from you.
  • On the left you see a groove that is going to be where you attach the foot to your machine.
  • On the right is a u-shaped arm which you can move up and down. It will go over the needle clamp
Now, let's remove your present foot from the machine and look at it.
  • Loosen the foot screw until it almost comes off. (if it does come off, screw it back on a bit.) The screw is on the left of the foot-bar.
  • On the right you'll see the needle bar with a needle clamp (what you tighten when you replace a needle) on the right of the needle-bar.
Okay the walking foot business.
  • slide the walking foot into position so that the foot screw is in the slot on the right and the u-shaped arm is over the needle clamp, with the needle clamp in the middle of the u-shaped opening.
  • Tighten the foot screw securely, it's going to be under more strain than normal.
  • While you're at it, check that the needle-clamp is nice and tight as well.
Okay, then! There you go... Happy sewing.
Are you happy? Than please vote
Here are a few helpful pictures.
Feb 01, 2008 | Singer 7436 - INGENUITY
Zenith R56W36 56" Rear Projection Television Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
