Hi i think i need a new cpu as my power supply unit stopped working and i had to replace it.I am looking for a compatible processor and beleive this is the one x86 Family 15 model 2 stepping 4 GenuineIntel ~2532 Mhz.My Desktop pc is an Advent 3510.Please can you link a website which sells this cpu please?
  • 11,800 Answers
Exact replacement
http://cgi.ebay.com/Pentium-4-2-53GHz-512KB-533MHz-SL6S2-478-pin-Northwood-/220676402673?pt=CPUs&hash=item336156adf1
Upgrade
http://cgi.ebay.com/Pentium-4-IV-P4-CPU-3-2Ghz-3-2-512k-800-Northwood-478-/370436974978?pt=CPUs&hash=item563fc3a982
Posted on Oct 05, 2010
Fan is running but screen has no signal, ram is checked, i am thinking that something on the motherboard is not working, what can i do
The first thing to check with a desktop computer problem, is the Power Supply.
(Also is the inside of the computer dirty, but I think we have gone beyond that)
A Power Supply with a weak voltage power rail, will not have enough power to turn the Processor (CPU) on.
1) If ALL of the LED's (Light) were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor (CPU) can use 51 to 125 Watts of power.
Just depends on what Processor it is.
(Older processors uses less power than 51 Watts.
Intel Pentium III for one example)
That is why LED's may light up, and fans may spin, but the computer doesn't work. No Processor operating.
Do you have a multimeter to check the 3 Main voltages?
3.3 Volts, 5 Volts, and 12 Volts. ALL are DC Voltage.
[In comparison two D cell flashlight batteries produce 3 Volts DC.
The dangerous AC voltage coming into the Power Supply, is kept contained in the case of the Power Supply ]
Around here ('States') an economical multimeter can be purchased, for around $5 to $12.
I can step by step you through this procedure.
OR;
Do you have a KNOWN to be good, Compatible power supply; that you can use for a Temporary test unit?
[Honey I'm going to borrow the Power Supply out of your computer.
I'll put it back when I'm done.
What's that? I'll be sleeping on the couch?...........lol! ]
Post your findings in a Comment, and then we'll go from there.
Regards,
joecoolvette
Apr 12, 2013 | Computers & Internet
Cpu didnot run ,i cant find any signel on my cpu every thing is ok but there is a problems in motherboard what should i do ?
A) With great tact and diplomacy;
Do not refer to a Personal Computer as a CPU.
CPU = Central Processing Unit.
Another term is Microprocessor, or simply Processor for short.
CPU = Processor
B) Because of the method you used to refer to the Computer, I do not know if you're talking about; the PROCESSOR did not start, or the Computer.
C) If I we are to believe this is a reference to the Computer;
1) Check the Power Supply voltages,
OR
2) Substitute the Power Supply; with a KNOWN to be working, Compatible power supply, for a temporary test unit.
Why?
A) If ALL the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use 51 to 125 Watts of power.
A Power Supply with a weak voltage power rail, will not have enough power to turn the Processor on.
However I am still confused by the statements;
1) "CPU did not run"
Does this mean the COMPUTER did NOT turn on, which implies the Power Supply did not turn on;
OR,
Does this mean LED lights came on, fans may be spinning, but Windows does not load?
2) "I can't find any signal on my Computer........"
Signal = Voltage.
To see if there were voltages going through the motherboard, you wouldn't be posting on here. You would know how to take a multimeter, and test them.
Means to me you see No Signal on the monitor.
D) Are you FOLLOWING Anti-Static Procedures?
E) Power Supply voltages prove to be good, or you are using a KNOWN to be good, Compatible power supply?
Disconnect EVERYTHING from the motherboard.
NO cables to the motherboard, EXCEPT the 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
[NOTE* Color of connector does NOT matter ]
,and the 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Disconnect the data cable AT THE motherboard, for the Harddrive, and optical drive/s. (CD/DVD drive)
Disconnect the power cables to them also.
Disconnect ANY USB front panel cables.
LEAVE processor fan wire connected to motherboard.
You want the Processor, finned Heatsink sitting on it, and the Processor fan.
ONE stick of Ram Memory in Slot 1. (DIMM 1)
Leave graphics card in, IF used; or monitor is connected to the VGA port on the motherboard. (D-Sub connector)
Turn the Power Supply on.
You should be able to bring the BIOS Setup screen up.
If no, consider the motherboard to be bad.
http://www.msi.com/product/mb/G31M3-L-V2---G31M3-LS-V2.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130217
Post back in a Comment, as to the information I need.
CPU = Processor
PC = Computer, or just use Computer.
Regards,
joecoolvette
Mar 13, 2013 | MSI G31M3-L V2 Motherboard
Changing acer t690 processor
Yes, you can change the CPU, but your Motherboard will only support certain processors, Take a look at this Acer Support, you will see the compatible CPU's: http://support.acer.com/acerpanam/desktop/0000/Acer/AspireT690/AspireT690sp2.shtml Remember : Your machine's component work with one another, within parameters, one component,CPU, will not give you the improvement you might think. CPU, Memory, Graphics Card, Etc.,Upgrades, require more Power/Watts, therefore a new PSU. Which create more heat, new fan. One relies on the other. Do your research, their's a lot more to it than replacing one component. Do a comparison, what will all the components cost, to a new System? The prices for new Good Systems , are low due to slow sales of Desktops/Laptops.
Feb 05, 2013 | Acer Aspire T690 (AST690UP820A) PC...
My motherboard keeps on overheating @ 70C and over plz what must i do?
Hello and Welcome to FixYa!
If the overheating is not due to hardware issue, faulty components, you can control the temperature by using Heat sinks and Temperature controlling fans, and by regulating a proper Air flow to the unit. For this, you can also use Cooler Master casing specially designed for high end purposes, or can use any such available brand to control the temperature...
Concerned.
Jun 28, 2011 | ASUS P5KPL-AM SE Motherboard
I got an aspire 4520 running on amd turion 64x2 processor and found that the processor is faulty. Can i replace the processor and where can i purchase the processor as i came to known its quit expensive.
You can replace the CPU if the new one is compatable with the computer.
Basically get the same CPU from a site like
  • newegg
  • ebay
then take the laptop apart and discharge yourselve after taking out the power supply and battery.
Make sure to apply new thermal compound to the CPU prior to starting the laptop back up.
Hope this helps
-Ryan
Mar 08, 2011 | Acer Aspire 6530-5143 Notebook PC
I have a Foxconn G33M02 motherboard with a Intel Dual Core 1.8 ghz processor. I recently bought a Pentium D 2.8ghz which is supposed to be compatible - but it's not working. The power turns on and the fans...
All PSus (power supply units) with the correct pins (most of them) should work; take a look on a tech website, like Fry's, for a PSU thats 500w. That should be more than enough; its always better to have more power than is necessary.
Feb 28, 2011 | Computers & Internet
Power supply for Philips HEPC 7501/05 failure, can't start my pc! where can I find similar products to replace it?
hi zibby,
power supply are you sure of this,when turn on is the fan inside is not blowing,it easy to replace psu,my power supply is 4 1/2 years before i replace,the price of this made in china more or less $30.00.the important on specification is capacity how many watts
your psu.check on www.psuebay.com
on frigure as sample disconnect psu besure power off and disconnect all connection at the back of cpu.open cover of psu
two quick lock in bolt loosen and slide off cover,
on psu there are multiple colors cable that are supplying your
mother board and others devices such as cd room,floopy anf hardisk, pull out or disconnect supply cable on mother board and other devices,then at the back side of cpu beside psu there are 5
screw loosen this and pull out your psu(power supply unit).then if you have new one just reverse the process of disconnecting psu on connecting back new one.
have anice day,rate me if your satisfied to my solution,thanks a lot.
Apr 29, 2009 | Computers & Internet
Replaced Mobo & Processor Nothing Working
May I know the model of your gigabyte mobo, you just replaced your unit with.
'cause it may not be compatible with the new power suply you have upgraded with.
Thanks
Sep 26, 2008 | Computers & Internet
There is a problem in starting the system
check the battery and check the hdd belt also and also check the smps
Jan 17, 2008 | ASUS P5PE-VM Motherboard
CPu fan turns for 1 second and then stops.
If all was working fine before, then, you have either not connected the cpu power cable, as is sometimes required other than being powered by the processor socket, or your power supply unit is not pentium 4 compatable and is unable to power the processor.
Apr 07, 2007 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Computers & Internet Logo
448 people viewed this question
David Payne
David Payne
