Question about Hotpoint Dryers
My Hotpoint Point Dryer (model #123C7939P001) will not start at all. Please advise. Thanks.
5 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: Stuck start/cancel button
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/0047_8.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 22, 2008
  • 464 Answers
SOURCE: how do I change the heat element in a hot point
the number you have provided is not the model #. open the door and look around the hole for a proper model #. then I can help you. tks
Posted on Oct 11, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a Hotpoint Dryer and the belt snapped, we
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt,felt seal, and drum.
Remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
The route of the belt will go around the motor pulley first, then it will go around the idler arm bracket with pulley, then around the drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Posted on Nov 15, 2009
yalmer
  • 552 Answers
SOURCE: problem with hotpoint as66vvxna1 dryer
There are a couple of things that you can check. FIRST go to the electrical box where the circuit breaker or fuse for the dryer is. Sometimes on half of the circuit breaker is tripped allowing the controls of the dryer to work, but not the heating element. Turn off the breaker and turn back on. Or replace the fusees. If this does not work, then you may have a loos wire or a burned out heating element. Sometimes there is a bad high temperature switch. Do the circuit breaker or fuse first. If the washer did not spin out the water well enough, the water can short the element to trip the circuit breaker or blow a fuse.
Posted on May 26, 2010
Replacement dryer for recall dryer has no manual. Can you help?
Can you please provide the model number of your Hotpoint Dryer? Thanks!
Apr 18, 2016 | Hotpoint Washing Machines
Hotpoint TVM572 timer is faulty
It is important not to open the door of the dryer if it is still running. The timer controls the cooling cycle otherwise the clothes will get damaged if kept on hot.
It is very likely the timer contacts are frozen at some point and the timer will need some attention.
It is not hard to locate it. I cannot find the actual parts drawing for your model (it is good you have provided the full model details). But to help you locate the part I have found another Hotpoint model that may be similar to yours. Check this drawing to see if the front panel is similar.
Item 100 is the timer.
HOTPOINT Electric Dryer Backsplash blower moto Parts Model NWSR483EB1WW
The actual timer for your model looks like this.
Hotpoint TVM572P Timer
As the clothes are not getting burnt or singed I will assume the thermostat is ok and keeping the temperature within the range.
Aug 07, 2014 | Hotpoint Dryers
When i set my drier to dry on high heat it keeps tripping the electric with error code f-13 please could you advise me on why this is thanks
Indesit (Hotpoint, Ariston) 'F13's refer to 'thermistor circuit fault', 'dryer fan not working', 'dryer NTC (thermostat) fault' and other similar things! There CAN be problems with poor connectivity between cables and plugs/ sockets which could cause similar symptoms. It realy needs a service call to identify/cure, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 16, 2011 | Hotpoint Aquarius WD640 Front Load...
I have a Hotpont washer/dryer model BWD129 It started making a loud noise for a while when spinning now it won't spin at all. Please could you advise if it would be able to be fixed? Many thanks
I would say your basket drive is broke. Only when spinning, if it was this, it makes loud noises the whole time it spins, big thumps. This may be your problem. You would have to have someone look at it or call for an estimate. It would probably need replaced.
Mar 03, 2011 | Hotpoint Washing Machines
Problem with hotpoint as66vvxna1 dryer
May 26, 2010 | Hotpoint Ariston AS66VXNA1 Electric Dryer
Dryer does not work drum rotates but does not dry on hotpoint aquarius washer dryer model wd64. all other functions operate ok
Probably open circuit heater element, or thermostat/s
Remove top cover, and you will see the heater manifold on the top of the drum.
It is a long aluminium box.
The element and stats are located here..
You will need a meter to test the appropiate components for continuity.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Aquarius WD640 Front Load...
How do I change the heat element in a hot point dryer ,Model number 123C7939P001
Oct 11, 2009 | Dryers
Vibration
Normally, I find lint stuck in the fins of the blower that cause it to vibrate. remove the front panel to access blower.
Jan 27, 2009 | Hotpoint NVL333GY Gas Dryer
Dryer letting in Hot water
Have made suggestion on later note.
Jan 14, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
109 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
