I Have several stereo components by Mcintosh which I would like to setup. 1. mx115 preamplifier fm tuner 2.101 equalizer 3. mc 2105 solid state stero power amplifier 4. spekers I have lost the setup shcematic, can you help me with this.
Plug the Equallizer into the tape in and out of the Fisher. Any tape decks go into the Realistic. The Tuner simply goes into the the tuner socket of the amp.
You will be safe to use any as long as the voltage specs are higher than any in the circuit around them or any stated voltages on the diagram. It will probably a question of the space needed to fit them in the end rather than the working voltages. For example if everything around it is marked 50 volts, than that or above, should be OK.
Since you have 2 receivers, you can either use the Sony STR-AV570X or the TA-AX380. You will need 3 Stereo RCA Cables to connect your CD Player, Tuner, and Tape Player. The speakers connect to the receiver you choose using the speaker input terminals.
Here is the diagram (click on picture to enlarge):
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
is output amplifier is burned, check any burned fuse on the back. is high cmos power amplifier, need to be repaired. send to your top audio repair center.
