Question about Dishwashers
Dish washer tablet does not desolve in cycle so dishes are not cleaned
    Brigadier General:
  • 3,006 Answers
You haven't stated the make and model, but what you describe is typical of a dishwasher which is no longer heating the water.
This can be most typically a failed heating element, a failed thermostat or a circuit board failure. You'll need to get a repair technician to diagnose and repair the fault.
Posted on Oct 05, 2010
Tablet not desolving after quick wash cycle
Find out whether your quick cycle is a wash cycle or a rinse only. If it is a wash it's obviously too short, and the tablet is not dissolving. You do not want undissolved tablets because they will contaminate your rinse water and u end up with soap on the dishes. You can switch to powder if a tablet isn't going to dissolve quick enough on your quick cycle.
Jun 03, 2011 | Bosch Dishwashers
Smeg DI 409CA Dishwasher - Doesn't wash properly, tablet doesn't desolve and cycle lasted all night
The first thing is have a look at the instruction manual from HERE
If the dishwasher is not washing properly then please follow these steps:
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
As you said that the water builds up at the bottom see If it comes out 'foamy' then liquid dish soap is getting introduced into the dishwasher. Liquid dish soap is different than automatic dishwasher detergent. liquid dish soap needs to be COMPLETELY rinsed from anything that has been pre-soaked prior to putting in the dishwasher. after a couple of regular cycles the foam will go away. Nowadays liquid dish soap is also 'concentrated' or 'ultra concentrated' which doesn't help.
If further this does not solve your problem the the only solution is to get it repaired.
Goodluck..
Feb 23, 2008 | Dishwashers
I have a Dishlex Global 300 and sometimes the detergent was not empying out when i did a wash cycle (seems that the top rack would prevent the door of the detergent holder to open fully) I just purchased...
it could be your water preasure or the water is hard,,,but like with most dish washers the tablets dont desolve all the way,,,you need more of a liquid soap type of a cleaner
Feb 19, 2011 | Dishwashers
The tablet will not desolve and there is a white hard residue in the cups after the wash cycle. What is the solution?
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 21, 2010 | Bosch 24 in. SGS66E02 Exxcel Built-in...
Dirty Dishes
Hello Peter, Welcome to Fixya. I'm going to start by asking a couple of questions, but that is part of a proper and thorough diagnosis from afar...in my opinion. Does a "normal" wash cycle take longer then 2 - 3 hrs ? Do the dishes appear to be dry when the dishwasher completes the cycle ? Further to this question, does there appear to be any heat in the machine upon completion of the cycle ? I ask these questions specifically because heat is a crucial factor in desolving the detergent ( usually a minimum of 145F ) and thus cleaning the dishes as well as allowing the dishes to dry properly when cleaned. If we could start here I will be better equipped to helping you solve your dishwasher troubles and with any luck assisting you in repairing it yourself. I'll watch for your reply and we'll go from there. macmarkus :)
May 23, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Not rinsing soap still on dishes
try washing the dish washer out with a good drain unblocker the system gets cloated up with grease, then use a dishwasher salt with the washes this will help to remove the suds ets, most dishwashes have a compartment to put either liquid or solid dishwash aid in try a different aid, also if you use tablet form i desolve it first in hot water in a small container
then place that into the dishwaser on the lower shelf, that helps
Aug 16, 2009 | Dishwashers
Dishwasher not cleaning dishes
If you are using a name brand powder detergent and still getting the film, the next most common cause is a failed heating element.
Even if the water filling the dishwasher comes in at 120 degrees (f) but the time the powder is released from the dispenser, often the entering water is not hot enough to desolve/activate the powder.
I bet replacing the element will fix you right up!
Apr 05, 2009 | Roper RUD3000GQ Dishwasher
Dish Washer soap does not dispense during wash
You don;t list the make and model number or its aproximate age.
The simpelest cause is switching to an ultra-cheap dry detergent. Recommed you use a name brand powder (like Electrosol or Cascade) Never use gel or tablets, ever.
Check all spray arms for blockages. Now is a good time to remove the filter (non trivial but do-able on most dishwashers.)
Clean empty dishwasher by filling a bowl or large cup with white vinegar and placing it in the dish rack. Run a short cycle with no detergent added. You may need to repeat.
If problems persist, the pump motor is probably failing. Schedule a service call or consider replacement of DW. Good Luck!
Mar 29, 2009 | Dishwashers
I have a tricity bendix dishwasher.It is not washing properly,also the washing tablet dose not desolve.the model n.o is TDF 200
Dishes not cleaned properly....
Nov 23, 2008 | Dishwashers
Dishes not being cleaned properly - large portion of tablet still remaining in the bottom
I have a 4114 and the problem was not enough water entering the washer. You can check by adding extra water (kettle full) to the washer just after start. ( opening the door just suspends the cycle) If your dishes clean well then you will need to adjust the pressure level switch to allow more water in. There is an adjustment screw on the switch which needs to be turned 1/4- 1/2 a turn. This puts more tension on the spring so more water needs to enter before the switch is activated. On the 4114 the switch has 2 adjusters. It is the taller of the 2 that require adjusting. Do little turns until the water level just covers the filters.
Nov 18, 2006 | Electrolux 18 in. ESL4114 Slim-Line...
Dishwashers Logo
66 people viewed this question
Top Dishwashers Experts
Owen Barnes
